I've made the tough decision to sell my Tornado Red/Black '85 urQ due to changing priorities.
I am the second owner. Bought the car in October '94 with ~85k miles. There is now just over 119k miles on the clock. It has been garaged for the 13 years I've owned it and hasn't seen any snow and has rarely even seen rain in the last 6-7 years.
Upgrade and maintenance info:
- Interior is in excellent condition with only minimal wear to outside seat side bolsters
- Original paint still shines and is in good-to-very good condition. There are paint chips, but probably less then typical for a 22 year old/119k mile car. The passenger side rear quarter panel was repainted by the previous owner and it slightly faded compared to the rest of the car. Barely noticeable though.
- No rust
- All synthetic fluids
- Intended Acceleration ECU upgrade & waste gate spring (~215 HP)
- Eibach Pro-Kit springs and Koni Sport Yellows shocks
- Hella halogen headlight replacements (have the OE junkers still in boxes)
- Euro dual filament rear light holders
- Diff, tranny, and engine mounts replaced at ~105k
- Suspension (i.e. tie rods, ball joints, control arms, all subframe mounts, front sway bar bushings, etc.) overhauled at ~106.5k
- New OE Ronal R8 wheels & Toyo T1-S tires put on June '04
- A/C compressor and receiver/dryer in July '05
- Fuel injectors and seals in Nov. '05
- Other maintenance/R&R over the years include oil cooler lines, p/s hydraulic line, brake pressure, accumulator ("bomb"), SS brake lines, rear diff seals, radiator hoses, vacuum hoses, coolant expansion tank, trunk shocks, and more
- Heated seats work!
- Replacing the fuel pressure accumulator, fuel pump check valve, and cold start valve next weekend (8/18-8/19)
Things that don't work (from inside out)
- Passenger-side window stopped working last year. Not sure if it's the regulator or switch, but I think it's the regulator as it has been making noise for years.
- Clock. I have an extra instrument cluster from a 4000cs quattro that has a working clock for swapping.
- The OE stereo cuts off one side of speakers intermittently.
- A/C leaked out all the Freon over the winter. It blew strong and cold last summer. It looks like a bad hose or compressor, but I will determine and get it repaired prior to sale or account for the cost in the sale price.
- Tranny release bearing started make noise about two years ago, but hasn't gotten worse and since I drive it so little I haven't had it replaced.
I also have a bunch of new and used spare parts that would go with the car including including a rear diff, drive-shaft, a set of BBS 15x7.5 "basket weave" wheels, 4kq instrument cluster, new sunroof seal (the current one seals fine), new turbo-to-I/C hose, G60 front calipers, rear calipers from a urS4, and various other engine, a/c, and interior trim parts, and a Wolf Evolution 4 custom fit cover
Asking $15.5k for the car and all the extras if I get the A/C fixed. Will discuss adjustment of price without A/C repair.
I also had plans for an AAN/RS2 conversion for the car and have a completely rebuilt AAN (from a '92 urS4) engine and RS2 parts (intake manifold, Swain coated exhaust manifold, turbo, injectors, airbox and wiring harness). If the car is sold, the AAN and all the RS2 parts will be available as well.
I will also "package" the car with the AAN motor and RS2 parts. Sort of a 20 valve, I-5, turbo "conversion kit". Will discuss price if someone is interested.
Contact me with questions and for more pics.
Marc
quattrosparky@metronets.com or
mnguyen@audiclubna.org
- No rust
Marc
