I have a run/drives well, 1987 4000q, 148,xxx miles ($1250). Reasonable shape, some scratches low rust spots hit with POR-15. And a pile of aftermarket/swap parts including;
-7A 20v engine with;
new valve cover (sold), cam, throttle body, intake and exhaust manifold gaskets and studs/nuts or bolts($50 for all). Dist cap($10), thermostat(8), cleaned the TB($50 with switches/tps), painted the intake manifold ($45)and valve cover flat black($50)*sold*, spark plugs (oem type bosch)($10), rear main seal ($20), 3b flywheel and clutch with new throwout bushing and pilot bearing ($125).
-6 new cv boot kits (4 outer, 2 inner) ($45 for all)
-New lug conical lugs
-Extra rear diff doesnt leak, with good actuator ($100)
-Extra radiator/fan/shroud ($100) -broom not for sale
-4 90q axles for swap ($50), 1 pass frt 4000q axle (new in box) ($90)
-New driveshaft support bearing ($40)
-Various clips, screws, seat bushings (new oem)
-New door strike pins
-New black OEM, type 85 vintage "audi" badge for trunk ($20)
-2 extra each front and rear subframes ($50 each) can modify/seem weld to suit, with unused 034 aluminum bushings ($100 for both sets *sold*)
-extra front and rear control arms with bushings removed, new powerflex bushings to install. ($200 with poly bushes) * bushings sold*
-Bilstein sport cartridges used good shape ($200)*sold*, with one pair eibach ($100) for 90q 20v, one pair coupe Q springs
-Girling 60 calipers with rotors/pads ($100), and new stainless lines ($35) and 90q 2 piece strut tubes($100)/front bj's ($30)/wheel bearings 83mm ($60) for swap and extra pads
-New rear brembo rotors, new pads ($45)
-New Poly filled trans mounts (4)-($50) *sold* and motor mounts (2)- ($30)
-New moog strut mounts -($35)
-Powerflex rear diff bushing -($35)
-MAF adapter for cone filter -($50)
-034 Silicon coolant hose set and block breather ($100)
-034 poly snub mount bushing ($20) and can supply a cromoly/ss custom bracket
-034 7a FI upgrade kit lightly used, with new oem injector bushings -($150)*sold*
-New VW Fox manual steering rack for swap ($150)*Sold*
-Mb motoring 15x7 5 spoke wheels with good dunlops ($300)
-Borbet BS 15/7 (no tires) ($200)
-Set of oem ronals (mounted) with good tires another with almost new snows ($100)
-Set of oil temp/press and volt gauges (oem VDO) ($35)
-Extra fuel pump ($60) with braided stainless/-an lines with aeroquip check valve
-Stebro stainless exhaust (for 90q, fits 4kqwith minor mods) with hollow and non hollw cats ($400)
-Bag of snakes SS header (with a new $30 gasket, and new hardware) ($100)
-New front tie rods ($75)/end ($25)
-Full set of door glass 4kq ($100)
-Used zermatt DS fender ($75)
-New slave cyl ($30)
-90q 25mm front ASB with greasable poly mounts, so the stock one can be moved to rear. ($50)
-Thule bike rack
-Extra front turn signals ($20)
-So many other little bits.
-Complete intact 7A ECU and harness ($150)
7A head with cams, came from a good, running car.
Also have a pair of GLI power recaros in awesome condition ($350)-
Due to a series of unfortunate events, I must relinquish this project to someone with more time and or money to put it all together. Terribly, I just can not get/find the time.
Please feel free to email/PM me to discuss the details.
*Prices do not include shipping*
-Thule bike rack
