motorgeek.com :: Board index :: Motorgeek Madness :: Chit Chat
Location AC Adjustment Bolt Plate 90 CQ
 Post subject: Location AC Adjustment Bolt Plate 90 CQ
PostPosted: Thu Nov 10, 2016 6:23 am
Does anyone happen to know where and how the mounting plate in the picture below mounts? When making a minor adjustment to the AC belt tension, it simply fell off on the floor. It was not possible to see where. It looks like a plate to screw up against the ac adjustment bolt?
Edit, ac belt tension problem, see below:
 Post subject: Re: Location AC Adjustment Bolt Plate 90 CQ
PostPosted: Thu Nov 10, 2016 7:49 am
Don't think that is part of your car http://www.shelf-clips.com/product/borr ... helf-clip/
90 90Q 20v 91 200 20v avant 92 urS4
 Post subject: AC Belt Tension CQ
PostPosted: Thu Nov 10, 2016 9:29 am
It may have been located above something, when the accessory was moved, it fell on the floor.
The ac adjustment bolt is not long enough to put pressure on the ac unit, holding it in place for belt tension. Every belt I have tried, whatever length, does not fit the adjustment range.
The ac adjustment bolt is significantly shorter than the slot the ac compressor can be fixed, in place, for proper belt tension. When using the bolt, it does not have enough range to put tension on the belt, it squeals. That is why I thought there was something behind the bolt, that it did not just bottom out on the side of the block. Just trying to get my belt adjusted,
Any Ideas?
PostPosted: Thu Nov 10, 2016 10:10 am
Maybe post a picture what you are calling the adjustment bolt. The adjustment bolt has a nut on it that need to be loosened.
13X915 is correct a/c belt pn# 034260849 http://audi.7zap.com/en/usa/audi+coupe+ ... 60-260060/
  |  It is currently Wed Apr 26, 2017 8:36 am
