motorgeek.com :: Board index :: Motorgeek Madness :: Chit Chat
Post new topic Reply to topic  [ 13 posts ]
Porsche front brake conversion questions
 Post subject: Porsche front brake conversion questions
PostPosted: Mon Nov 14, 2016 2:27 pm
Hello, well i am in process of rebuilding my suspension and i was thinking about putting Porsche 993 Carrera, black brembo brakes on my 1995 Audi S6. Here's what i have in the list so far:
Porsche calipers - $400
Apikol RS2 Bracket with all hardware - $259
323mm Zimmerman rotors for an Audi A8 - $46.99 x 2
What brake pads would i use and what would be the cost? Also, what lines should i get? Is there others thing that i am going to need? Any other suggestions? Also, i was looking at a Stoptech brake kit, but those go around for $1700 brand new..
Tornado Red URS6 = Front suspension rebuilt and lowered! :)
Pearl White CQ = Hanging in there.
Facebook pages:
Audi Lithuania Fan Page - Audis posted daily :)
Euro Tuners
DSM / JDM
I hate electric cars
 Post subject: Re: Porsche front brake conversion questions
PostPosted: Tue Nov 15, 2016 4:26 am
As long as the hose connections at the caliper is the same, you can probably use factory lines. Otherwise, a good DOT approved S.S. line will have less expansion under heavy application than the factory rubber lines. The S.S./teflon is also less forgiving than the rubber lines, I had a set kink on me when I ran 993C2 calipers on my old CQ.
As far as pads, I have run Pagid (endurance race compound), Textar (OE) and Jurrid (OE). An OEM pad will be the nicest on the street, which I suspect is where this will see the most use.
http://coupe.gofergusons.org
'07 Q7 4.2
'07 Q7 3.6
'98 A4tq
'90 CQ
'90 CQ
PostPosted: Tue Nov 15, 2016 11:16 am
Thanks. Which rotors did you use? It seems these calipers are also from a Carrera 2. Also this is what i am looking at for Stoptech: http://performance.importrp.com/i-210187.aspx?gclid=CjwKEAiAgavBBRCA7ZbggrLSkUcSJACWDexAI_jhzYb_ZS-zv9g8pGYP6U2FQ0m9xdp5QEp1blGc9xoCVEvw_wcB. They seem to be bigger and they are also brand new. Would it be a better option to just go with these since they come with everything? Has anyone used Stoptech on a URS car before? Thank you.
Facebook pages:
Euro Tuners
DSM / JDM
PostPosted: Tue Nov 15, 2016 12:14 pm
What brembo calipers are they ?
17z or 18z ?
You could look into Carbotech pads they have always been my fav (around $150).
As for hoses just get some Stoptech ones for an S6 from Rockauto like $45 for the pair.
I am not going to keep a list of what I have here, it changes often.
PostPosted: Tue Nov 15, 2016 3:04 pm
17z or 18z ?
I am not sure, but heres the link: http://www.ebay.com/itm/OEM-Factory-Porsche-993-911-Carrera-2-Front-Left-and-Right-Brake-Calipers-Brembo-/311052551292?fits=Make%3APorsche&hash=item486c2d447c:g:iJgAAOSwVFlT7j9G&vxp=mtr I can get them for $400 shipped. And thanks for the other info!
Facebook pages:
Euro Tuners
DSM / JDM
PostPosted: Tue Nov 15, 2016 4:22 pm
Personally, I like Carbotech pads. I use one set for the street and another set for the track.
The stock CQ line, from the strut to the caliper, will be too short for use with a Porsche caliper, at least they are with the 996s, I used. The stock strut to caliper line is 160mm. You can replace it with a stock rear CQ line which is 250mm line. These lines are NLA from Audi, but you can get aftermarket. Centric comes to mind. I personally don't like SS lines are they have a tendency to fail at the crimps, especially on lines that are flexed a lot. You also don't know what grad of SS is used in making the lines. SS is rust resistant, not rust proof. The poorer grades of SS with less Nickel will rust sooner. Just my 2 cents.
Greg W.
PostPosted: Tue Nov 15, 2016 5:08 pm
The 993C2 caliper is slightly different than the 993S/tt calipers, and require a slightly smaller rotor diameter from what I remember. I ran a 12x1.25" (aka 305x32) Coleman rotor with custom hats. The caliper brackets were also custom, but I believe were the same critical dimensions as the RS2 bracket.
My new setup uses Q7 Brembo rear calipers with Wilwood rotors and hats (I had the hats machined locally). I do not have it on the car yet because I need to go through the suspension at the same time. The 993C2's worked very well, but for various reasons I had trouble (not because of the type of caliper, but that the guy that made the kit for me used too short of flex line, so both sides kinked, then he used non-anodized aluminum for the hats and brackets, so they corroded terribly, and then to top if off he used two calipers off the same side of the car, so the piston sizes were backwards on one side but correct on the other side). I'm going to be using rubber lines this time around and since I've done all the design work and parts sourcing myself, I can control the outcome.
'07 Q7 4.2
'07 Q7 3.6
'98 A4tq
'90 CQ
'90 CQ
PostPosted: Tue Nov 15, 2016 6:11 pm
The 993 (non-turbo) are 'medium' brembos. They're the same as an RS2 caliper. Designed for a 304mm rotor, but will fit up to 332mm with some slight shaving and spacers. You might be able to use the standard A8 323mm rotor without shaving, but you'll need to add a few mm of washers/spacers radially to space out the caliper for the larger rotor.
I've got the same calipers that I plan on using with 312mm 2pc 4x108 rotors (and later with 323mm 5x112). I actually have two pairs and paid $100-150/set. You can find them for cheap from Porsche guys (928S4, 951S, 951/968 M030, 993) because they all upgrade to 'big' (993tt/928gts) calipers.
Lots of options for pads for them, all depends on what kind of driving you're going to do. You can also modify the 'medium' calipers to fit the larger 'big' caliper pads with the 'big' caliper pad holders and slight mods.
-Alex- @vexartmedia on Instagram
1992 Porsche 968 (07K transplant in progress)
1983 Aud UrQ (20vt swap in progress)
1986 Audi Coupe GT (7A swapped and more)
2003 Audi S8 (DD)
2010 VW Touareg TDI (DD, tow rig)
2001 Ducati ST4
Past Audis: 87 CGT, 87 4kcsq, 93 S4, 90 CQ, 87 5ktq, 95.5 S6Avant, 86 CGT CE, 95 90qs 1.8T
Past P-cars: 80 931, 87 924S, 87 951
PostPosted: Tue Nov 15, 2016 6:14 pm
Other things to think about, the old-style brembos require a LOT of spoke clearance as they're very wide. The newer monoblock style are thinner and are pretty cheap nowadays too. I'd personally look into Boxster S/996 calipers unless you get a set of the earlier calipers for cheap or free. I certainly wouldn't pay $400.
2003 Audi S8 (DD)
2001 Ducati ST4
PostPosted: Tue Nov 15, 2016 7:17 pm
So from what i understand these would be the better option: http://www.ebay.com/itm/PORSCHE-911-996-997-FRONT-BREMBO-BRAKE-CALIPERS-OEM-PAIR-LEFT-RIGHT-/391563245403?fits=Make%3APorsche&hash=item5b2afcf75b:g:sG0AAOSwzaJX25jd&vxp=mtr#viTabs_0 What would be a fair price to pay for them? As i understand with 996 calipers i would need this bracket: http://www.apikol.com/index.php/products/braking/urs4-s6-boxster-s-brake-brackets.html and stock Audi A8 rotors would do fine? Also when looking for brake pads i would just specify that they are for a 2003 Porsche 911 non-turbo?? Also, would my stock 16" Avus wheels fit over them?
Facebook pages:
Euro Tuners
DSM / JDM
PostPosted: Tue Nov 15, 2016 9:25 pm
Alex, the RS2 uses 322x32mm rotors from the factory and a different caliper with increased mounting surface offset. It is not a 928/993/968 caliper meant for 304x32 rotors. Caveat - there IS a part number for the 304x32 rotor and caliper to go with it for the RS2. The 322mm setup lists as "17 wheels only", which makes sense. I think most RS2's had the 17" Cup wheel option and therefore the 322 diameter rotor.
'07 Q7 4.2
'07 Q7 3.6
'98 A4tq
'90 CQ
'90 CQ
PostPosted: Wed Nov 16, 2016 12:38 pm
mine:
Porsche 993 Turbo (Big Red) 4-piston caliper
Porsche 993tt/GT-3 322x32mm rotor w/ BIRA rotor hat
RS2 front caliper bracket
¯\_(ツ)_/¯
PostPosted: Wed Nov 16, 2016 4:57 pm
Ah, thanks for the correction!
2003 Audi S8 (DD)
2001 Ducati ST4
  |  It is currently Sun Jun 25, 2017 12:17 pm
