motorgeek.com :: Board index :: The Tech Lounge :: Abnormally aspirated
Blown engine, pictures showing washing in the head, ???
 Post subject: Blown engine, pictures showing washing in the head, ???
PostPosted: Thu May 18, 2017 1:52 pm
Just had a bad dyno day, the engine was freshly buildt and machined, both block and head. so all av this marks came in one day, Cant find any pictures online showing simmilar to this.
Just trying to find out what happend, ot was it just too much power
 Post subject: Re: Blown engine, pictures showing washing in the head, ???
PostPosted: Thu May 18, 2017 4:31 pm
defect head gasket? maybe a crimped fire ring
PostPosted: Fri May 19, 2017 3:55 am
MLS gasket?
If the head or block had a low point there it would make it weaker.
causing a failure point, but power and cylinder pressure is always going to be a factor.
1990 Coupe quattro - AAN swap (o7k inprogress)
2007 RS4 APR1320 Supercharged
1991 90q Tornado Red 3B swapped - The hoopty - Sold back
2007 S4 Brilliant black 6 spd - SOLD
2001 A4 2.8L laser red 5 spd - SOLD
PostPosted: Fri May 19, 2017 12:58 pm
Bad injector leaning out one cylinder. Bad FPR leaning out all cylinders and this one went first. Hard to guess. How much power were you making? What fuel, what timing?
John Anderson
04 XC90
91 200 20V - not stock
01 S8 - stock
97 GMC Sonoma - 436rwhp
84 928S - 270rwhp
73 MGB
PostPosted: Fri May 19, 2017 1:20 pm
Hi
Thanks for all the replyes
Its my coupe quattro with twin turbo v8
We was making 1240 nm and 790 hp to the crank at 1.7 bars.
Fuel is 99% Ethanol and max ignition at 1.7 bar was 14 degrees
It could have been lean, i will do a flow test.
Have also found out the studs on both sides of the blow out are a bit more lose on the threads to the sides than the rest of the studs.
This arera in the block has been repair welded, so that could be it
PostPosted: Fri May 19, 2017 9:05 pm
Coupe V8 wrote:
Hi
I'd say you answered your own questions and also HOLY BLOODY FOOKIN SHOITE, MATE!!!! That's a lot of power and using a repaired, untrue block when you can get another block for a c-note... well, that's just silly. I think the lesson here is don't be silly.
Laguna Seca B4 4.2 - The Smurfinator!
My turbocharger is a dog.
Your argument is invalid.
PostPosted: Sat May 20, 2017 12:26 am
Hey, thanks :)
Yes i probably did, I vill be finding a block for the next season,
Here is an older clipp, to little power there on 3. gear under drift. Thats why i was remapping with bigger turboes
https://www.youtube.com/watch?v=CioTBmYAN_Y
  |  It is currently Mon May 22, 2017 8:31 am
