Post new topic Reply to topic  [ 6 posts ]
1.8T AEB GT2871r Ignition Timing - 034EFI Stage Ic
 Post subject: 1.8T AEB GT2871r Ignition Timing - 034EFI Stage Ic
PostPosted: Sat Aug 20, 2016 9:17 pm
Hi guys,
I'm about to rebuild my 1.8t AEB engine after I threw a rod running 20psi on my GT2871r. After disassembling the engine I noticed the other 3 rods had slight bends/warps in them. I can now appreciate why everyone says to replace the rods before attempting to make decent power!!!
I've sent the AEB head and new block (from new motor) away to my cylinder head machinist and everything looks good apart from the exhaust valve guides which require replacing.
My current tune pulled well but I'm now a little wary as I don't wish to blow another engine after I rebuild it with SCAT rods. As my car is in bits at the moment, I'm unable to download my tune and upload my current timing figures but I'm wondering if anyone would be able to look at my gear and perhaps send me through some tuned timing figures?
034EFI Stage Ic
4bar MAP sensor
GT2871r turbo
550cc Injectors (fueling no probs - sits around 11:1 peak boost WOT)
Stock pistons
Stock head
Stock block/crank
SCAT rods
Hoping to run around 20psi or more on 98 octane here in Australia.
Thanks in advance.
 Post subject: Re: 1.8T AEB GT2871r Ignition Timing - 034EFI Stage Ic
PostPosted: Tue Nov 01, 2016 2:38 am
Thanks for all of the comments and assistance. Glad to know the community is willing to help. Please close this thread.
PostPosted: Tue Nov 01, 2016 10:41 am
why blame the community?
ask the maker of the product directly.
¯\_(ツ)_/¯
PostPosted: Tue Nov 01, 2016 12:07 pm
you might find a little more support here if you were looking for a larger cock or a new kitchen.
Dana
-1990 90q 1.9tdi swap w/holset turbo
-4kq efi'd 10vt
-1990 90q 20vt: 3b swap
-1990 90q 20vt: 11.7 @124.5
-numerous other various junkers
PostPosted: Tue Nov 01, 2016 1:48 pm
ahahahha
¯\_(ツ)_/¯
PostPosted: Tue Nov 01, 2016 3:12 pm
  |  It is currently Sat Apr 29, 2017 10:14 pm
