Post new topic Reply to topic  [ 56 posts ] Go to page 1, 2, 3  Next
IIc hiccup.
 Post subject: IIc hiccup.
PostPosted: Tue Sep 25, 2007 8:06 pm
I'm wondering if anyone else is experiencing something similar to this. I have a IIc on my 200 running V1.01.00 firmware. Once every couple days (car is daily driven) the ECU does something funny. It's like it hiccups momentarily and totally turns off the engine for what feels like one loop of control. Depending on how you are driving, you get different results. Sometimes you hardly notice. Other times if you are making 25psi of boost, it's violent. I used to chalk this up to crappy tuning on my part. However, the car is finally dialed in pretty well. It still does this. Anyone else seen this or am I special? :bashtard:
John Anderson
91 200 20V - not stock
01 S8 - stock
97 GMC Sonoma - 436rwhp
97 Grand Prix GTP
84 928S - 270rwhp
73 MGB
PostPosted: Tue Sep 25, 2007 8:11 pm
experience the same thing, havent figured it out yet but a few people have mentioned it! Its kinda like a nasty Jult when ur on it, but if ur just cruzing sometimes u wont even feel it but u see the RPMs drop and bounce back up rite///
1990 Coupe 20vt
Power is nothing without quattro
Faster then a Speeding Ticket
-Ashesh
PostPosted: Tue Sep 25, 2007 8:49 pm
I color outside of the lines
Have you logged your engine doing this yet? Based on what I'm going through I suggest you check the WDBG log for errors... anything other than 59(if that is your norm) at the time of stall/cut out.
-Phil
96 A4 Ti20
Waiting for its next HPDE
98 A4 2.8qm Avant
Undergoing overhaul
PostPosted: Tue Sep 25, 2007 8:59 pm
Nope, I haven't got a log of it. It's never happened while I was tuning. It seems completely random. The only piece I've noticed is I don't think it's ever happened more than once in a key cycle.
John Anderson
01 S8 - stock
97 Grand Prix GTP
84 928S - 270rwhp
73 MGB
PostPosted: Tue Sep 25, 2007 11:15 pm
same thing happened to mine...the trigger wheel sensor is loosing sync with the wheel momentarily...check the gap you have between the sensor and the trigger wheel, but it pretty much always happens regardless...just the way it is with the 60-2 trigger wheel.
95' S6 - Hoppen/MTM Stage IV
PostPosted: Wed Sep 26, 2007 5:17 am
Seems if you had a gap problem it would happen much more often. Once every couple days on a daily driven car seems like too much drive time between 'hiccup' events to be a mechanical issue.
Preston Schipper
Calibrator for hire
90tq track car on the way
PostPosted: Wed Sep 26, 2007 7:29 am
Location: Norton Shores, Mi. My cat has human-like reflexes
my iic has it too. i think marc's does too.
7a head/milled mc2 bottom w/holset Hx35...500hp for $500?
viewtopic.php?t=6726
PostPosted: Thu Sep 27, 2007 6:30 pm
So any other ideas of what the issue is here? Is this something I should watch out for with my IIc?
Dan
1986 4kq Daily/winter beater
1987 4kvr6tq Project / track car
2001.5 S4 Daily driver
PostPosted: Mon Oct 15, 2007 5:55 pm
I have the exact same problem. Car is daily driven as well and it never does it more than once every key cycle, if i'm on it its a HARD jolt, otherwise its just a tiny hicup.
The cur acctually shuts off for a split second and i can hear the relays clicking back in.
I checked everything i can't figure out why is doing it.
Car is 1.8T AWW w/ IIC
PostPosted: Mon Oct 15, 2007 7:16 pm
Same here, although its all fresh on my setup....but I drove 300 miles yesterday and it did it about 4-5 times each way, ~150 miles. Haven't logged it yet. It happened 2-3 times before around town. Sometimes its nothing, some time very hard.
Brian, I don't think the setup itself is an issue because old BMW's use this. My old e30 325i had the VR sesnor on the 60-2 wheel up front but never did this.
I am also on the old firmware.
Peter
PostPosted: Mon Oct 15, 2007 7:18 pm
Im dying to get to the cause of this, cuz that by far is the most embarassing thing when your car jerks...Its bad enough women think loud cars are crap :bashtard: getting jerked around driving just adds to it :frustrated:
1990 Coupe 20vt
-Ashesh
PostPosted: Mon Oct 15, 2007 7:23 pm
Hmmm...I'm watching this with great intent. It would suck to have the rallycrosser just shut itself off for a second whenever it feels like.
'89 90q Rallycross car
'86 CGT G2 Rally car
'11 Jeep Wrangler Unlimited
'00 Jeep Cherokee
'86 Honda Magna 2 wheeled kergigger
http://www.flickr.com/photos/47757586@N00/
PostPosted: Mon Oct 15, 2007 7:25 pm
Meh, I don't care about that....it would just suck to happen at low speeds, in traffic where it could technically completely die on you, like mid intersection or something...
Peter
PostPosted: Mon Oct 15, 2007 7:29 pm
master of teh modz
The more logs you guys can get for us with the hiccup the better. It's cropped up from time to time on some cars, but not others. We're working on tracking it down. It's never shut a car down, especially under load, only light cruising, and around 3k rpms. I drive my coupe on a Ic daily in tons of bay area stop and go, the car has never once died, though I have had the aforementioned hiccup. So I wouldn't worry about that aspect. But yes it is something we're hunting down.
If the car is cutting out repeatedly, and/or under load definitely get some logs done, it's likely not the same hiccup as being discussed here.
Don't Panic
- Douglas Adams
PostPosted: Mon Oct 15, 2007 7:32 pm
to be honest, its one of those issues that you get used too after a while.....but as long as ur not accelerating when it happens 90% of the time you wont feel it.....But i agree, i would like to know the reason too....I just upgraded to the new firmware a few months ago, and the problems still there
1990 Coupe 20vt
-Ashesh
PostPosted: Mon Oct 15, 2007 7:47 pm
I'll work on it Nate. I pretty much have the laptop hardwired in the car for ow so it won't be hard to log it....and to be clear, it hasn't shut down the car on me either.
I got it once, the very 1st time actually, going about 30mph in 2nd gear, driving to an exhaust shop and it was pretty hard. All other times it was on the highway, at cruising speeds...and yeah, revs drop for a second, small backfire and you just keep going. Yesterday, at one time it was harder and Nathan said(he was driving behind me) car shot fire outta exhaust and other time a big puff of black smoke.
Peter
PostPosted: Mon Oct 15, 2007 7:52 pm
my experience is similar to Peter's. completely random as to when it happens (load/throttle position/etc) and it doesn't happen very often. When it happens under load its.. definitely noticable, but no relays cutting out or anything like that. Its pretty clear from the logs in my case that when it occurs, WDBG drops momentarily to 0.
Marc Swanson
90 CQ 4.2 V8TT
83 UrQ
95.5 //S6 Avant
93 //S4
97 F250 Diesel
Can you tell I like turbos?
PostPosted: Mon Oct 15, 2007 7:53 pm
def will log it for you guys when i get my car back together
1990 Coupe 20vt
-Ashesh
PostPosted: Mon Oct 15, 2007 9:06 pm
master of teh modz
Yeah, those sound a lot more like a sync issue than a software hiccup. Everything we've seen here has never happened under load, no backfiring, no total shutdowns, just a tiny, like one revolution, dip in power.
Don't Panic
- Douglas Adams
PostPosted: Tue Oct 16, 2007 7:32 am
I've felt it on an old 80tq I did with the old firmware and also felt it on multiple cars with the new firmware. Its very fast and its easy to miss. John and I were on the way to the drag strip last weekend and he said there was the hiccup and I didn't even notice as we did a light cruise on the highway. Its easier to notice with more load or at idle where the engine stumbles more noticeably. I've also noticed it only seems to happen once per key cycle.
Preston Schipper
Calibrator for hire
PostPosted: Tue Oct 16, 2007 8:08 am
so far all i have noticed is at cruises, often when i am 2 blocks away from my house and just start my cruise, i get one hiccup. 034 display tach drops to 0 for only a fraction of a second (.5 my guess).
PostPosted: Tue Oct 16, 2007 8:50 am
My car does this within the first 5mins of warm up but not every time, if at low idle (800-900) it will stall the car. I have had it logged and it will read;
59
59
59
59
59
32
59
59
59
It will only miss 1 time and then never do it again for hours of driving. I'm guessing it has something to do with metal bracket shifting during warm up in my case.
PostPosted: Tue Oct 16, 2007 5:58 pm
I logged my rpm on the way to work as well and same thing, split second drop of rpm to ZERO, just as i thought
I have all the sympthoms described above, light load its almost insignificant, under hard acceleration it give you a pretty good jolt.
Only does it once per keycycle, and the car can be super cold or fully warmed up.
Friday i'm going to the DYNO i hope it doesn't do it while i'm doing a pull.
PostPosted: Tue Oct 16, 2007 8:04 pm
I boggle like it's my bidniss
Cant if the 1.8T users are having the same issue.They have a 60-2 wheel on the crank so no play there.
Issam N. Abed
iABEDIndustries.com
PostPosted: Tue Oct 16, 2007 9:11 pm
I'm having a similar issue on a 1.8t run by a IIc. Happens once or twice a day, usually under no or light load. I haven't had an opportunity to log it, but the tach (driven off of IIc) will drop a few hundred RPMs for a second or so.
  |  It is currently Tue Jan 24, 2017 10:09 am
