Post new topic Reply to topic  [ 6 posts ]
Audi A4 B6 Engine swap with 034efi
 Post subject: Audi A4 B6 Engine swap with 034efi
PostPosted: Sat Jan 07, 2017 11:07 pm
I just finished up the wiring on my Audi A4 b6 2.7 L engine swap.
I'm at a loss. I'm running a AEM wide band o2 sensor and using the 5 volt signal to the ecu.
I checked the injectors and they are working, I'm not getting anything with rpm...
The fuel pump is firing up and I'm getting pressure to the fuel lines. I going to be checking the ignition coils this weekend.
I'm second guessing myself now and I'm wondering if there is something I'm missing. any input would be get.
 Post subject: Re: Audi A4 B6 Engine swap with 034efi
PostPosted: Sat Jan 07, 2017 11:46 pm
PostPosted: Sun Jan 08, 2017 12:10 am
On the monitor screen, the box that says #trigs says 0. Your ecu is not reading rpms and will not fire the coils or injectors. What do you have for a crankshaft sensor and has it been correctly configured in the ECU settings?
Chris H.
1991 CQ (AAN, 01E, 034IIC)
1999 A4.2 (ABZ)
2007 RS4 (Stock)
PostPosted: Sun Jan 08, 2017 1:04 pm
I'm using the stock crank sensor reading the teeth off the flywheel.
the cam position I'm using the stock sensor.
PostPosted: Sun Jan 08, 2017 1:06 pm
the two things I\m not too sure about is the number of teeth on the flywheel, and the number of missing teeth before tdc.
PostPosted: Mon Jan 09, 2017 9:39 pm
The fuel pump turns off after a few seconds of not seeing a rpm reading.
For my cam/hall sensor I'm using the stock sensor.
Pin 1- hall sensor positive
Pin 2- cam shafts TDC trigger index phase angle
Pin 3- hall negative / shield
I'm second guessing the crank position sensor
Pin 1-
Pin 2-
Pin 3-
On this
Pin 1- VR output
Pin 2-VR Negative
Pin 3- Shield
Pin 1- (220) Ground connections
Pin 2- blue wire
Pin 3-gray wire
  |  It is currently Tue Jan 24, 2017 8:10 am
