Post new topic Reply to topic  [ 13 posts ]
Making a Graph chart out of data log
 Post subject: Making a Graph chart out of data log
PostPosted: Fri Apr 12, 2013 7:45 am
Anyone know of a way to take the spreadsheet format and make it be presented in graph form? I'd like to set it up basically to display as the plotter feature does, it seems easier to quickly spot "bumps" in a parameter. Thanks for any info. Joe
 Post subject: Re: Making a Graph chart out of data log
PostPosted: Fri Apr 12, 2013 7:56 am
Maybe this helps?
viewtopic.php?f=2&t=4357
-=Frank=-
Image <- "The Twins" Image
PostPosted: Fri Apr 12, 2013 8:50 am
If you open the logfile (CSV) in a spreadsheet program, you can plot the whatever data you want in any format the spreadsheet can support.
Just highlite the data (if you highlite the top row you will have an automatic legend), then click on graph ( or the equivalent maneuver) and go through the graph wizard to finish the graph.
PostPosted: Fri Apr 12, 2013 9:21 am
Lets get freaky 8)
I have been using this recnetly.
http://nyet.org/cars/ECUxPlot/
It works pretty well, but takes some getting used to.
Jimmy G
'89 90tq the "vomit comet"
'01 A6, the "ocho"
Original web page
PostPosted: Fri Apr 12, 2013 10:11 am
http://nyet.org/cars/ECUxPlot/" onclick="window.open(this.href);return false;
How do you import our CSV to it?
Got command line?
PostPosted: Fri Apr 12, 2013 11:18 am
master of teh modz
It's simply an app that can open/parse CSV's. It can be installed with a shell extension so you can right-click on CSV's an open them with it.
Don't Panic
- Douglas Adams
PostPosted: Wed Apr 17, 2013 9:30 am
Lets get freaky 8)
It helped me track down an unstable map sensor feed, the car runs better than it ever has now. My zeitronix was stable as can be. But the ECU needed a .030 restrictor. Since I primarily log with the zeitronix because I can instantly review them, I never knew I needed the restrictor.
Jimmy G
'01 A6, the "ocho"
Original web page
PostPosted: Wed Apr 17, 2013 12:27 pm
Okay, mini break through (for me at least). I have been manually editing my CSV data logs and viewing them in excel. It is tedious.
I found I can do some very minor tweaking to the CSV file and then import it into megalogview HD. It pumps out very nice graphs with minimum pre processing effort. The trial version is limited to 2500 lines of data for analysis but it still shows all the data in the graphics window.
Attached is a screenshot of a short drive. You can see the upshifts 1, 2, 3, 4 clearly.
Steve
ps I hope I'm not in trouble for bring a megasquirt tool to our party :)
PostPosted: Wed Apr 17, 2013 3:42 pm
Lets get freaky 8)
What tweeks? That looks like a nice program
Jimmy G
'01 A6, the "ocho"
Original web page
PostPosted: Thu Apr 18, 2013 2:00 pm
I simply deleted the first few lines that list the time and date the log was created. Edit the CSV so row 1 has the labels and the remaining rows are data with no blank lines. Then it imports directly.
PostPosted: Sun Jun 09, 2013 9:31 am
Lets get freaky 8)
I have been playing with MegaLogViewer HD for a while now and really like it. Like Steve said delete this information below from the log and it works great.
Log Begins on 03-08-2013 17:28:53
LOG_FILE V1.00.02
Here is a side by side comparison of a 1st-2nd run that I logged with my zeitronix and the 034ECU plotter dump.
Jimmy G
'01 A6, the "ocho"
Original web page
PostPosted: Sat May 21, 2016 12:32 am
เกมส์คาสิโนออนไลน์
PostPosted: Mon Jun 20, 2016 1:49 pm
It is. I wish I had it back in school it is a great value for 50 bucks if you work with large data sets.
The 3d plots are quick to setup. They take me hours in maple or matlab.
  |  It is currently Wed Mar 29, 2017 5:47 pm
