Post new topic Reply to topic  [ 40 posts ] Go to page Previous  1, 2
NEW DOWNLOADS PAGE AT 034efi
PostPosted: Fri May 02, 2008 8:57 am
yeeas... floppy drive... ehxcellent...
PostPosted: Fri May 02, 2008 9:18 am
how to save to drive? right click save as not an option...
PostPosted: Fri May 02, 2008 9:23 am
if you are using internet explorer I think the option is "Save target as" when you right click.
Otherwise, download a real browser, like firefox :)
Marc Swanson
90 CQ 4.2 V8TT
83 UrQ
95.5 //S6 Avant
93 //S4
97 F250 Diesel
Can you tell I like turbos?
PostPosted: Sun May 04, 2008 4:51 pm
firefox only has options of opening, saving and bookmarking the link.
n/m got it.
PostPosted: Mon May 05, 2008 10:59 am
will a .set file formatted for 1C load correctly to my 1B? It will just have more GPO's to work with more cylinders right? That won't mess things up if I have my GPO's hooked up to the fuel pump and throttle control motor.
I guess if it isn't compatable would anyone have a 1B map for a 2.0t with Hallefffect Sensor?
PostPosted: Mon May 05, 2008 11:02 am
n/m got it.
Firefox supports "save link as".
This is what you want to use to save a file from a webpage.
PostPosted: Mon May 05, 2008 11:04 am
Absolutely not.
The map format (in particular the X and Y size) is not compatible, and there are a great many individual objects that are on the C firmware and not the B.
PostPosted: Mon May 05, 2008 6:22 pm
alright. kind of figured as much. would anyone be so kind to come forward with a 1B map?
PostPosted: Mon May 12, 2008 6:59 pm
back on top?
PostPosted: Sat May 17, 2008 3:49 pm
MrDerp wrote:
back on top?
yeah. what they said.
PostPosted: Sat May 17, 2008 7:07 pm
It would be helpful if some basic info was available for the map. For example, injector size, boost, initial timing set up for the B systems
PostPosted: Mon May 19, 2008 10:19 am
Stock 2.0 injectors although I have 310 green tops from a G60. Stock K1 Audi wastegate at 6psi. Distributor is set 30* advanced, starts retarded and advances gradually through RPM, retards into boost.
What I think I need to focus on is initial startup and off boost power. I know I'm running richer than I should, usually takes a couple cranks to get started. Something with the amount of or time open cold start pulses. Probably from 1k to 3k is overly rich and hesitates to rev up. I dunno. I could take some screen shots of my setup if necessary.
PostPosted: Tue Nov 18, 2008 9:26 pm
a4kquattro wrote:
sure, does your laptop have usb? If so a thumb drive is probably the best way. if its got a floppy drive you could probably fit the .set file onto a floppy disk no problem as well.
Wow-- like where else can a fella get this kind of information? This is way cool. If you are used-to this ,,, shame on you, it is a wonderful privilege. Thanks ..034
 Post subject: Re: NEW DOWNLOADS PAGE AT 034efi
PostPosted: Mon Oct 27, 2014 5:34 pm
Hey Javad, any chance you guys have a mild ("stock rod") IC tune for a 1.8t AEB / GT3071 / SIEMENS 630s?
TIA!
PostPosted: Wed Oct 14, 2015 11:14 pm
I've bean asking for this for couple of years now, and all my comments either get deleted or just ignored.
I purchased a RIP chip from you a few years back for my 12v V6 with MMS-200 and I've asked you guys several times to upload the stock, stage 1, and stage 1+ maps to your website PLEASE
Thank You
1993 Audi 90CS Quattro (loving it)
1975 VW bus (gone)
1973 VW Super Beetle (what was i thinking?)
1968 VW Bug (my pride and joy)
1991 GMC Sonoma RWD, manual, 4 banger (gone)
1979 Suzuki GS750EN with 31k original miles
1981 Suzuki GS750L (will be on a chopping block for a bobber)
1981 Yamaha XV920
1983 Yamaha XV750 (for g.f.)
1985 Dnepr MT10-36 (stolen)
1992 Dnepr MT11-32 (also stolen)
  |  It is currently Sun Jan 22, 2017 11:20 am
