Best place to get complete VAG parts other than stealerships
2K views 9 replies 6 participants last post by  cupas
#1 ·
Anyone have access to VAG parts bin special order parts audi/vw, I am rebuiding my sunroof would like to use a few new parts this time, the local dealership wants way to much for small parts like 100% markup, I need small parts for a 4000kq sunroof assembly, and few backup parts for future problems, and would like to get a sunroof seal for my ur quattro though VAG catalog now says NLA??? :? :?
#3 ·
And Google Chrome will now translate I hope...!
I know that the coupe / ur quattro sunroof seals are still being made in Europe from what I read, a old supplier is making this seal still, and I think some Mk1, and or Mk2 VW Scirocco had this same wider sunroof seal material that the coupes, and ur quattro's used. I am almost certain that early Scirocco Mk2's had the same seal that the Audi's did, like 1981 82 to mid 83 then they made the change over to the later style that can be had for about $80.00 from Mk1 VW... This later style seal is still available for about $80.00 from the stealer dealer also I believe.
Any one that works for a dealership out there want to give me their nice price on these parts..
321 877 157 x2
321 877 158 x2 NLA supposedly IMPEX???
191 837 199 x2
443 877 729 x2
443 877 730 x2
443 877 721B x2
N 014 120 1 x2
321 877 209 x1 Audi 4000 80 90 VW mk2 golf/jetta sunroof seal NLA?
855 877 297 Audi coupe sunroof seal x1 supposedly NLA?
Those seam to be the most common parts that break on these roofs, I have repaired all three of my cars once, two are broken now would like to double up on the parts bin while the are still available by the time I need to fix them again I will have nice steel not die-cast pot metal ones made.
443 877 729 & 443 877 730 Bushings LEFT AN RIGHT or as VAG refers to as the 'Shoe'
These are the part that fail all the time leading to damage to your unit, resulting in further dammage to more expensive parts! I think this time I will use JB Weld to hold the busing on the hinge, there is a reason for low availability, and NLA I suppose, they break all the time when the bushing pops off....... :wtf: :wtf:
#4 ·
Audi Tradition....
SEAL FOR sunroof
View details
[1] [2]
YOU REVISITED: SEAL FOR sunroof
Katnr. 008 Duration: 10.80> 07.87 Description: Audi Coupe
Katnr. 072 Duration: 08.87> 12.87 Description: Audi Coupe
Katnr. 061 Duration: 08.84> 12.87 Description: Audi Coupé quattro
Katnr. 046 Duration: 07.80> 07.91 Description: Audi quattro / sport quattro
Your price: 68,90 EUR
Article ID: 855877297 2AT
(Code: Z011641)
Condition: NEW
#8 ·
Ecs Tuning ;-)
#9 ·
For the NLA parts, you can try classic parts in Germany or Audi tradition, however if they are NLA there's a high likelihood your SOL and will have to make parts or go used. You might be able to get lucky and find NOS, but in that case you will pay out the nose for the parts.
You might be able to send samples to China and have them reproduced or 034 might be able to help you with that as well.
