Post new topic Reply to topic  [ 5 posts ]
Pontiac Fiero V6 Bellhousing hole pattern dimension ???
 Post subject: Pontiac Fiero V6 Bellhousing hole pattern dimension ???
PostPosted: Mon Jan 17, 2011 4:23 pm
hi all !
I am working on electric conversion for 1986 pontiac fiero, and I am looking for Pontiac Fiero V6 Bellhousing hole pattern dimension. If any of you have it, can I have a copy of it ?. Thanks you very much
 Post subject: Re: Pontiac Fiero V6 Bellhousing hole pattern dimension ???
PostPosted: Mon Jan 17, 2011 4:50 pm
Standard 60-degree V6 GM pattern. Basically, anything used in a transverse front wheel drive vehicle that wasn't a four cylinder used this pattern. (Even the front drive V8s!) Also every 2.8/3.1/3.4 RWD used it, although the RWD blocks are different (all bolts go through from trans side, starter is on other side) the physical pattern is the same.
My name is Elmer Fudd, millionaire. I have a mansion and a yacht.
PostPosted: Wed Jan 19, 2011 8:25 pm
yeah, I looking for Standard 60-degree V6 GM pattern, been searching but no luck !!!
PostPosted: Wed Jan 19, 2011 8:39 pm
so far I have dimension for the top, looking for bottom
PostPosted: Thu Jan 20, 2011 10:40 am
There is no "bottom". That's it. Full-circle bellhousings are fairly rare in the domestic world.
For the transverse automatics, GM will have a sheetmetal brace from the front-ish of the engine to the right side extension housing. This IS dependent on which engine and which transmission, so there isn't really a "pattern" there.
  |  It is currently Mon Feb 27, 2017 10:42 pm
