MS on a 10v
 Post subject: MS on a 10v
PostPosted: Thu Feb 16, 2017 1:30 pm
To those that have gone megasquirt on 10v's, I have a question. On MS3 or MS3X, can you do single coil distributor ignition with just the 5 window dizzy as the timing sensor, or do you need to put a 60-2 timing wheel on? also, if it cant be done on MS3, can it be done on MS2?
 Post subject: Re: MS on a 10v
PostPosted: Fri Feb 17, 2017 5:28 am
That's absolutely doable, on MS2 or MS3 (even MS1 I think).
Things you lose are the timing accuracy that comes with using a crank sensor, and the ability to do sequential injection or coil-on-plug ignition. That's because separate crank and cam sensors are required for those features.
Be alert! America needs more lerts.
Eric Law
'90 80Q with AAN and Megasquirt
'97 Saab 9000 Aero: mostly stock but ECU tweaks to add fastness
'86 4KTQ: R.I.P.
PostPosted: Fri Feb 17, 2017 5:49 am
Well, this is just so I can drive the car because I haven't driven it in awhile. I need to break the clutch in and DD It a little. I will never makIngrid a new harness and doing cop and all that sometime in the summer
PostPosted: Fri Feb 17, 2017 6:51 am
Makes sense!
If you're planning on upgrading later, I'd strongly recommend going with the MS3+MS3X from the start. COP is doable with MS2 with a lot of hardware mods, sequential injection is pretty much impossible. With the MS3+MS3X, you just wire it up and go driving.
Eric Law
'86 4KTQ: R.I.P.
PostPosted: Fri Feb 17, 2017 7:09 am
Would you possibly be able to help me set it upossible firmware wise once I get to that point?
PostPosted: Fri Feb 17, 2017 7:16 am
Sure!
I don't know if you've seen this thread: http://www.motorgeek.com/viewtopic.php?f=6&t=43169 but I've been helping Dave a bit with his MS setup and it's worked out pretty well.
Eric Law
'86 4KTQ: R.I.P.
PostPosted: Fri Feb 17, 2017 9:32 am
elaw wrote:
Sure!
I'm pretty sure he has seen it... :wink:
  |  It is currently Fri Feb 24, 2017 12:58 am
