Post new topic Reply to topic  [ 8 posts ]
B4 Steering rack Rebuilt kit - How To
 Post subject: B4 Steering rack Rebuilt kit - How To
PostPosted: Sat Apr 21, 2012 4:10 pm
Figured I'd share this since the only relevant post I found had no picture.
This re-seal procedure is actually easier than removing the damn thing from the engine bay...
Disassemble steps:
1) Boot
2) Outboard Cap
3) Spline shaft cover (3 bolt)
4) Spline Shaft (hold it in your hand and tap on the rack body)
5) Adjustment Cap (2 bolt)
6) Spring retainer cap and the 2 wedged parts
7) Pull the Rod thru the outboard side.
Seal kit came from these guys:
http://www.pskits.com/catalog/-c-21_24.html
No special tools needed.
Guess images are worth a 1000 words, in the re-assembly order.
File comment: O-ring under the Blue "Glider" rings.
File comment: Had to keep the old white glider ring as it was not include in the kit.
File comment: The little blue ring was a bitch to install
File comment: Use a 15mm socket to drive it out and a 21mm socket to drive it back in.
File comment: New vs Old
File comment: The kit didn't had this one, good thing anyway 'cause I wasn't able to remove it.
1993 B490Q Daily Driver
2005 A4Q 1.8T Avant 6MT, familly hauler.
2006 JW TDI --> death by fire.
 Post subject: Re: B4 Steering rack Rebuilt kit - How To
PostPosted: Sat Apr 21, 2012 10:23 pm
Sweet. Bookmarked.
1990 CQ 190k silver/black
PostPosted: Mon Jan 23, 2017 1:09 pm
thanks bookmarked!
08 Audi S4 (parting out)
PostPosted: Tue Jan 24, 2017 11:00 am
Very nice
1990 Coupe quattro - AAN swap (o7k inprogress)
2007 RS4 APR1320 Supercharged
1991 90q Tornado Red 3B swapped - The hoopty - Sold back
2007 S4 Brilliant black 6 spd - SOLD
2001 A4 2.8L laser red 5 spd - SOLD
PostPosted: Fri Jan 27, 2017 9:27 am
I have a complete kit with everything to reseal a steering rack, including new boot. 8A1498020 is the kit number. usually go for over $100
Ill sell my kit w/boot for $50 shipped if anyone interested in sealing their rack.
email me coreyj03@gmail.com for fastest response.
PostPosted: Sun Feb 12, 2017 3:21 pm
I might need to be doing this in the near future. Stupid newb question, is the b3 rack the same as b4? (90 20v sedan).
PostPosted: Tue Feb 14, 2017 9:43 pm
there is a difference. an early b3 will be different from b4. a late b3 might be the same. pay close attention to the power steering hard line fitting location on the rack and you can tell the difference.
this is the reason i have an extra reseal kit. i bought the wrong one. fits b4 rack but not 1989 build date b3.
PostPosted: Wed Feb 15, 2017 10:14 am
Gotcha. Mine is an 02/90 build date. Still have to get the toe in fixed on the rear so I can drive it home, then I'll look into it!
  |  It is currently Fri Feb 24, 2017 7:50 am
