Post new topic Reply to topic  [ 311 posts ] Go to page Previous  1, 2, 3, 4, 5, 6, 7, 8 ... 13  Next
Sport quattro copy.. more parts....
 Post subject: Re: Yet another Sport Qquattro copy.. project resumed
PostPosted: Wed Mar 21, 2012 7:34 pm
ralleyquattro wrote:
At least you have peanuts.. mine is on a shoestring (used and broken) budget... at least for now ;)
One thing's for sure, the parts in your SQ will be seen as anything but "cheap". :drool: This SQ is going to be spoiled rotten with super cool parts. 8)
83 urq project
PostPosted: Wed Mar 21, 2012 7:49 pm
im about to make a similar copy of that front crossmember. ive been examining jim bufkins photo gallery.
also plan on replicating the c. arms but for stock balljoints for now... idk if i want open spherical joints atm...
very very nice schtuff tho
PM me for:
ABA > b2/b3 quattro engine mount brackets & AEB oilpans
PostPosted: Wed Mar 21, 2012 7:58 pm
btw, are u planning on making your own front/rear trailing arms to hook up to those
control arms? i was thinking some thick walled chromoly tubing w/ the ends tapped
would be way cheaper but i gotta make sure my machinist can do reverse threading....
PM me for:
PostPosted: Thu Mar 22, 2012 4:14 am
We are planning on making copies of all of the parts, Craig and Mike need a set as well ;)
Yep, going to be some kind of a tube with threaded ends.
This is Mr K's setup.
Martin Pajak
www.quattro.ca
83 80 q - Euro 2-door!!
85 Ur-q - Euro with 3B
93 90q - 2.5TDI, 6-speed
94 S2 Avant, stock
PostPosted: Thu Mar 22, 2012 4:28 am
Weld in treaded bungs are readily available for virtually any tube size. They could be cheaper than buying expensive left hand taps. :wink:
83 urq project
PostPosted: Thu Mar 22, 2012 6:00 am
Very Sexy,
I have to see them
PostPosted: Thu Mar 29, 2012 9:07 pm
those look decent... gotta atlk to my guy.
i just found a place that sells pretty close to the same looking carbon/kevlar
weave as audi used. imma buy some and see how similar it is. if it looks good
im gonna start makin rad. shrounds and charge pipes, perhaps kevlar skid plate
i gotta see how much plain kevlr is....
my old boss has a vacuum bag setup, im considering trying to make molds after
i build my steel A2 flairs...........
PM me for:
PostPosted: Thu Mar 29, 2012 9:09 pm
wtf is up w/ those sway bar ends? is that thing lopped off and the
flat blade-ish looking endpeice clamped on there???
PM me for:
PostPosted: Fri Mar 30, 2012 4:20 am
That is for adjusting the stiffness of the bar, if it's horizontal it's soft, vertical stiff, and anything in between, very cool way of adjusting.
Martin Pajak
www.quattro.ca
94 S2 Avant, stock
PostPosted: Fri Mar 30, 2012 2:34 pm
so it is clamped onto the end of the bar? was looking at bufkins and couldnt figure
it out from the angle in his pics....
PM me for:
PostPosted: Sat Apr 07, 2012 10:30 am
Another productive day, got a chance to clean the other side of the floor and one of the wheewells.
Now I need Mr Cook or Mr Hopton to help me flip it back onto the jig... ;)
Martin Pajak
www.quattro.ca
94 S2 Avant, stock
PostPosted: Sat Apr 07, 2012 2:56 pm
As well bunch of goodies showed up last week... the rear inner fenders, that will be great help.
Hope to have the B-pillar on the driver side moved back 320mm by the end of the weekend.
Martin Pajak
www.quattro.ca
94 S2 Avant, stock
PostPosted: Sat Apr 07, 2012 5:01 pm
I've been following your project. Great stuff with attention to detail. I will be following!
Rally machine
S6 Avant (daily driver)
http://www.motorgeek.com/viewtopic.php?f=6&t=56497
"Blog"
PostPosted: Sat Apr 07, 2012 7:31 pm
Yet more productivity... deskinned the the roof tonight.. look what I found under the C-pillar skin.. Craig, did your Coupe GT have this..
Martin Pajak
www.quattro.ca
94 S2 Avant, stock
PostPosted: Mon Apr 09, 2012 6:24 am
Martin, Ive seen it before with the few I've cut up.
PostPosted: Mon Apr 09, 2012 7:19 am
Parts look good Martin,
If you're making a SQ clone are you going to cut the rally light mounting Blocks off your Front Crossmembers? If so, and you want to unload them, let me know.
Rest of your stuff looks pretty straight forward.
I recommend you alter your rear differential mount location and your mounts for leading and trailing arms before you go too much farther on your chasis.
Also... Keep in mind the little hole on the Control arm, is for drilling a small M6 alignment bolt through the tongue once you get the alignment where you want it for camber and toe. Install a bolt through there and you can get back a good alignment in a hurry if you alter ride height.
PostPosted: Mon Apr 09, 2012 7:21 am
Why do that?, just go with the spherical bearings and weld a threaded stud on the bottom of your Wheel bearing housings. Much easier to do anywork on the car and a better setup.(repairable)
PostPosted: Mon Apr 09, 2012 8:10 am
james, do you know where to buy the stud for sphericals? soemone makes a stud that bolts into the knuckles for spheric ends
PostPosted: Mon Apr 09, 2012 8:17 am
I'll be using Mr K's front cross member, I have the original street version as well and will consider selling them to finance the rest of the build.
Same goes for the street control arms with ball joint.
Yep, knew about the small bolt for alignment purpose. and I have the oem floor pieces for control arm track rods.
These require the rear seat area to be stock and uncut, same as rally cars.
Martin Pajak
www.quattro.ca
94 S2 Avant, stock
PostPosted: Mon Apr 09, 2012 8:49 am
It wouldn't be an off the shelf stud, IIRC its fat in the body with a shoulder then a smaller threaded bolt head. Easy to weld to a steel bearing housing compared to the threaded block required on the aluminum bearing housings.
PostPosted: Mon Apr 09, 2012 9:06 am
the ones i had seen before for a sport had the same bump and two bolt tabs liek an oem balljoint so it recesses into the knuckle and has a tapered stud and then small male threads to retain the rose joint
trying to find a pic but cant
PostPosted: Mon Apr 09, 2012 9:46 am
What method are you using to clean the underside of the body that well? :)
1985 Coupe quattro restoration project
1995 A6 Avant 2.5 TDi
PostPosted: Mon Apr 09, 2012 10:11 am
Heavy duty wire cup brush on a grinder.
I also use a flat one for the hard to get spots
Martin Pajak
www.quattro.ca
94 S2 Avant, stock
PostPosted: Mon Apr 09, 2012 10:15 am
Just have these pieces machined, this is what Mr K supplied me with... bolts into both front and rear struts and allows rose joint use.
Martin Pajak
www.quattro.ca
94 S2 Avant, stock
PostPosted: Mon Apr 09, 2012 10:19 am
isi there anywhere i can buy them?
  |  It is currently Sun Jun 25, 2017 12:11 am
