Post new topic Reply to topic  [ 311 posts ] Go to page Previous  1, 2, 3, 4, 5, 6, 7 ... 13  Next
Sport quattro copy.. more parts....
 Post subject: Re: Yet another Sport Qquattro copy.. project resumed
PostPosted: Sun Jan 22, 2012 12:56 pm
Keep it up Martin, I can't even fathom a project of this magnitude! Respect
-Chris
'01 ///M5
PostPosted: Mon Jan 23, 2012 12:13 pm
Wow,
Nice progress Martin !!!!
See you this week.
Cheers,
Craig
PostPosted: Thu Feb 09, 2012 3:41 pm
Last weekend some more progress... don't have the pics but the pass side rocker and rear fender are now off...
Picked up some square tubing for the jig as well, Craig thinks 2.5" is a bit of an overkill.. oh well... live only once.
This weekend I hope to have the jig welded onto the subframe dollys and be ready to cut the car in half... ;)
Hopefully I won't forget to take pics.
Martin Pajak
www.quattro.ca
83 80 q - Euro 2-door!!
85 Ur-q - Euro with 3B
93 90q - 2.5TDI, 6-speed
94 S2 Avant, stock
PostPosted: Thu Feb 09, 2012 7:53 pm
Martin - Will you be using this same technique to cut the car in half? :D
PostPosted: Fri Feb 10, 2012 6:50 am
"and for Martins next trick, he's going to saw his thumb off"......safety first guys :wink:
Ian
1990 Audi 90 20V Quattro
VAP Coilovers : 350# Front. 400# Rear
VAP Pro-mounts with mount savers
BBSE's with Bilsteins
Deleted front sway bar.
034 Solid Subframe mounts
034 Density Line motor and transmission mounts
Urethane control arm bushings
034 Poly rear diff mount
Bilzcat short shifter
034 Injectors
My project link
PostPosted: Fri Feb 10, 2012 7:51 am
This was improvising in the bosom of nature, no time for safety
Way to post the pic Mike... shall I post some more of you? :slap:
Martin Pajak
www.quattro.ca
94 S2 Avant, stock
PostPosted: Wed Feb 15, 2012 5:47 pm
I was supposed to finish the jig last weekend, but I ran out of gas (welding) :D
So.. picked up a new bottle today and this evening finished up what I started.
Craig thinks it's a bit of an overkill, but I like it.
These Princess Auto engine stands are just great... will keep both subframes nice and square WRT each other.
This weekend hope to get some help and cut the front portion off.
Martin Pajak
www.quattro.ca
94 S2 Avant, stock
PostPosted: Wed Feb 15, 2012 6:46 pm
Looks good Martin,
It's been a long day, I'm knackered, so I may be talking dribble here........... Do you think
the fact that the sub frames which can be moved independently, could possibly affect the uni-body
alignment when the front of the 4000 mates to the back of the urq?
I understand that the subframes will be in perfect harmony, we just need to make sure the body
is aligned also.........? I guess some nice reference lines would solve that?
Cheers,
Craig
p.s if I'm talking dribble here, I'll delete in the morning
PostPosted: Thu Feb 16, 2012 7:51 am
Craig,
I thought the longitudinal square cross section tube kept the subframes aligned?
Anyway it looks good and hurry up and get it closed so I can borrow them :D
cheers, Mike
PostPosted: Thu Feb 16, 2012 8:00 am
I made sure that both sides are welded at exact same height so as they come together there is no binding up/down.
Andy Krinks uses similar design but even more heavy duty, something I can't handle in my garage by myself.. :(
Martin Pajak
www.quattro.ca
94 S2 Avant, stock
PostPosted: Thu Feb 16, 2012 8:20 am
audiurq wrote:
Craig,
cheers, Mike
Yes but the body can move on the subframe.
Because we're bringing 2 halves together using the subrames as reference, there's a chance
the subframes are not square to the body, as you know the subrames can be moved for alignment purposes.
A few degress over the length of the car can make a big difference in the body alignment, but not affect the subrame alignment,
seeing as the jig will keep the subframes square.
Some careful measuring should compensate for this...maybe I'm over thinking here....I tend to do that :?
:cheers: :drive:
PostPosted: Thu Feb 16, 2012 8:29 am
Agreed, measuring is a key, but at least you know the car will go down the road semi straight.. ;)
I have the body manual, so all the measurements are there (-320).
Plus we have the doors and rear fenders to make sure gaps are correct.
You had the luxury of having the two halves side by side before and after the cut.
I have to use something as a benchmark to start with since one of the halves is from another car.
Cheers
Martin Pajak
www.quattro.ca
94 S2 Avant, stock
PostPosted: Thu Feb 16, 2012 8:45 am
I guess there's nothing wrong with a 2 degree permanent power slide while driving straight down the highway
:lol:
PostPosted: Thu Feb 16, 2012 4:35 pm
It will be good for the media.. ;)
Martin Pajak
www.quattro.ca
94 S2 Avant, stock
PostPosted: Sun Feb 19, 2012 7:35 pm
Another productive day.
After pickin up another 90 quattro for my wife (also white), Mr Cook dropped by and gave me a hand with THE CUT.
Here is the result..
Subframe waiting for the other half.
Then just slide it 320mm into place.. ;)
Here is the left over floor section (already spoken for) hiding behind the body.
And while I had extra hands, we flipped the 4kq section so I can yet again clean the undercoating from yet another floor... boundless joy!! :frustrated:
Still plenty to go.
Martin Pajak
www.quattro.ca
94 S2 Avant, stock
PostPosted: Sun Feb 19, 2012 8:18 pm
I love the way you fit all of that in your garage. Makes me wonder
where the new white 90 quattro and blue ur-q will go? Maybe hang
one from the ceiling or stack them on their sides 8)
Good work! I have to say time spent flanging parts doesn't feel much
like progress, but I have to imagine the bigger picture.... :frustrated:
cheers, Mike
PostPosted: Sun Feb 19, 2012 8:20 pm
That's why I need to make 1 out of 2 asap.. ;)
Pics of flanging?
Martin Pajak
www.quattro.ca
94 S2 Avant, stock
PostPosted: Sun Feb 19, 2012 9:11 pm
Nice job, Martin - good to see the progress.
See you this week
Brandon
Brandon
'01 S4
'91 911 Turbo
PostPosted: Mon Feb 20, 2012 6:11 am
Itr was a productive 2 hours!!!!
I can't wait to see that front 4ooo sitting on that subframe.
good times.
Craig
PostPosted: Tue Feb 21, 2012 10:44 am
Wow! Now this is what you call overhaulin'
Chip Foose would be having a panic attack after seeing those pictures. Keep up the good work. :thumbsup:
83 urq project
PostPosted: Tue Mar 13, 2012 1:12 pm
Not as much of an update as Mr Cooks but, got couple of spare minutes and cleaned 1/2 of the floor.
Each time I do this I don't wish it on my worse enemy. :frustrated:
As you can see I didn't clean it all the way to the back, that portion will be cut away anyway.
Couple of pin holes here and there... not as nice as the original Georgia Ur-q floor... oh well.
Overall not bad for a Canadian winter beater... :o
Hope to get couple of hours on the weekend and do the other side.. then it's fliparoo time to remove the other rocker.
Lots to go.
Martin Pajak
www.quattro.ca
94 S2 Avant, stock
PostPosted: Tue Mar 13, 2012 1:47 pm
Over all the floor looks really good.
A nice easy repair
Cheers,
Craig
PostPosted: Wed Mar 21, 2012 6:14 pm
Few things showed up today, curtesy of the Polish connection.
The one on the right is the factory street part.
Incredable attention to detail.
Rear piece that will engage the sport struts I have
He sent me instructions to drill the subframe out to 12mm... rally cars used M12 hardware, learn something new everyday.
Also got these...
The lower one I did not have at all and the middle one from factory is steel and for street car.
Detail of the welds.
Tomorrow back to cleaning the damn floor.. :frustrated:
Martin Pajak
www.quattro.ca
94 S2 Avant, stock
PostPosted: Wed Mar 21, 2012 6:45 pm
Where did you get the front cross beams?
That's another thing on my to do list.
Thanks!
81' Rally Quattro,
88' Peugeot 205 GTI,
91' Lancia Delta Integrale 16v,
2015 RAM 1500 ecodiesel Quattro support vehicleImage
PostPosted: Wed Mar 21, 2012 6:52 pm
My god that's beautiful. What an ambitious project, incredible. Love those CA's
2003 TDI wagon, 63 356C, 71 NSU1200C, 1966 Dodge A100, 74 CJ5 plow jeep, tractors and junk.
  |  It is currently Sun Jun 25, 2017 12:11 am
