Post new topic Reply to topic  [ 94 posts ] Go to page 1, 2, 3, 4  Next
Lotus Esprit S3 on Air and V8 Power!
 Post subject: Lotus Esprit S3 on Air and V8 Power!
PostPosted: Fri Jul 18, 2014 5:23 pm
My Series 3 project before the modifications started……..
This will never do! Time to fit a V8!
I have done a massive amount of mods already, just wanted to do a thread to show my project, the engine install was done over a year ago.
They do say “don’t meet your hero’s” well I was very disappointed with the 4 pot engine, it really does not fit in with the look of the car.
My old series I that came with the rover v8 conversion parts, the engine was an old P6 lump, I was going to do some major upgrades but the s1 chassis, rear suspension. Drive shafts would never cope! So I pulled the engine out and sold the s1 and kept the conversion parts.
I brought the s3 with a cracked exhaust manifold, it had a really nice body and paint work, but it was a horrible driver, no problem I had big plans ahead……
my new engine, TVR 4.5 v8 built by Rovertec (V8 developments) stage 3 heads, cosworth pistons, etc, fitted in a ex hill climb car.
Gearbox adaptor
New Input shaft to fit the esprit gearbox to rover v8
Longer input shaft fitted in gearbox
Alternator is a tight fit, has to go down low
Front housing was way to close to bulkhead, so the cutting begins!
From under the car you can see how close it fits, you have to use a remote oil filter and a P6 crank pulley
Bulkhead done
Cosworth nice surprise bonus
TVR (Range rover) sump will not fit you need to use SD1 sump.
I used the water pump bypass, poor pictures but that’s all I have. It still touched on the bulkhead lip, was just to tight to work with.
Lightened steel flywheel and adaptor fitted
Original conversion kit used a modified P6 starter, it was huge and heavy, so I cut the gearbox bell housing to fit a normal V8 starter motor, have seen this done before so must be ok?
Its in at last
Nice porting on the heads
I fitted John Eales head stud kit (better than ARP) and billet rocker posts, also ported the inlet and gas flowed it to match the heads
1UZ-FE V8 Slammed Scimitar build
http://retrorides.proboards.com/thre...imitar-project
 Post subject: Re: Lotus Esprit S3 on Air and V8 Power!
PostPosted: Fri Jul 18, 2014 5:24 pm
Made the exhaust from scratch, TVR manifolds (reversed) and the rest all big bore stainless steel, had to redo it twice as It was very, very loud! So had to fit some extra baffles, may take them out latter!
Image Image
Lots more cutting………
I may be a sinner in the eyes of some Lotus Purest!
Still need to finish the rear floor, but its taking shape
It works! and the sound of a V8 is Awesome!
Some more work on the boot floor, I don`t plan on hiding the engine, but I will have a carpet boot.
This was what I had to work with, she`s not seen many spanners or love….
Wheels brought online, 17 inch, 9j rears and 8j fronts. 3 piece split rims made in japan from a Mercedes.
The offset for the fronts were perfect.
The hubs had to be re-drilled to correct PCD for the new wheels. The rears needed spacers.
Now have a much better choice in tyres, and no longer stuck with the sad 225 width rears.
PostPosted: Fri Jul 18, 2014 5:25 pm
not content with using the spacers, I didn`t like seeing them through the wheels.
Pulled the rears apart, and got some new outers made with image wheels.
That`s 11 ½ j wide! and now I have 315/35/17 rear tyres! again another ebay find, the chap I brought them from also has a Rover V8 esprit (twin turbo) and I got a full roll cage from him, I may need it!
Yes I am running air suspension, more on that latter………
Lets do the brakes then, as the ones fitted are hardly man enough even with the stock motor.
The rear discs were very worn, and are very expensive to buy. My solution Ford Mondeo rear discs.
They are near the same size and offset and a little thicker, plus you can get them very cheap.
I had to re-drill for the 3 lug fitting.
Carriers had to be ground wider, but as you may know now I`m not afraid to hack away what`s not needed!
The rear calipers I rebuilt, the hand brake mech was sticking, all fixed now and a lick of paint.
PostPosted: Fri Jul 18, 2014 5:26 pm
Fronts are much bigger 312 x 30mm from a Audi, I cross drilled them, god that took for ever! and the hubs machined to fit.
Front calipers from a Porsche 996, don’t think this setup would fit inside those little stock 15” wheels….
Many hours have been spent searching on the internet for parts which I can use, I have a small budget and little spare time to work on the car, so its been a long and stressful time.
Ok so lets look at the rear suspension, the shocks/dampers were rusty and old when I got the car so time for some upgrades.
I had already wasted time by cleaning and painting the old dampers, but they really needed changing. I got some Protec units from sjsports cars,
They looked nice but as you can see they are made wrong? They are longer and have less articulation, you can not lower the car by much and that was very disappointing. I was planning to use air springs/bags and wanted to lower the car very low when parked.
The bags are easy to fit with some work to the lower spring seat.
I have hacked the top spring mount off to allow the bag to bolt direct to the chassis.
That’s the rear bag sorted.
That’s with about 30 psi, should be able to get it drive like a dream with some final tweaking with pressures, and of course can adjust the ride height to what ever I like. well that’s the plan.
Air line fitted, good to go.
The front was a nightmare!
anti-roll bar all painted up, new poly bushes and hardware at ends
Mine is a 1981 model so had the horrible trunion upright, all fixed now with a Canley classic setup. Still not perfect as the lower mount has issues of rocking in the lower arm, and no rubber boots to protect the bearing. Can`t say I am 100% happy with it but it will do for now until I fit the latter arms and uprights. I have the uprights so if anyone has some lower arms going cheap?
Ok so lets get to the ball ache of the front suspension, lost lots of pics so will have to make do with what I have.
Front lower arms, I cut the lower rubber spring seat off to mount the air spring direct to the lower arm.
So far things are looking good, platform perfect size this is going to be too easy, or so I thought.
Still looking easy, all though top mount looks tricky as no access to bolt the top mount.
Here is when it all starts to go pair shaped, raising the lower arm to check suspension travel things go to shite!
This pic you can see the angle is all wrong.
Even the dampers clashed with the lower spring seat.
Even cutting access for the adjuster don’t help as the air spring also hits the adjuster.
I also found the front Protec dampers still longer than my original front items, Steve at sjsportscars was great in taking these back, and a Special set was ordered. This took ages and when I did get them they were still wrong! hassle I didn’t need, Gaz sell them on ebay so brought some.
These turned out to be wrong again!!! They were not the type or size I ordered!! Fcuk wits! Ok so lets get them fitted regardless, wasted way too much time. Near 2 months.
Top spring seat again had to be hacked off, and inspection hole cut in chassis to gain access to top mounting bolts, this was a total arse and still is a nightmare to do the bolts up. I am not happy with it and will look into a better solution another day. Loss of photos again so gaps again.
Lower arms, cut the spring seat off completely and now using the coilover to mount the bag, cut hole to gain access to anti-roll bar nut.
Ever fitted the anti-roll bar to a 81 Esprit? If so you know what a total sod it is! This hole makes it a piece of cake.
Canley classic lower joint tacked in place, she`s not going to move now, also helps put some strength back into the arm.
I also welded the top of the lower arm to box it up to make it stronger as seen in the arrow highlight.
Top arms just touched the air bag, this again was a lot of work to fix. They are pressed plate steel.
First I boxed the outside.
Then had to cut the inner section out, hence why I welded the outside first. I welded some tube half into the arm.
They are now double skinned and boxed so should be stronger than the originals in my opinion, no doubt some people sure to chime in if they disagree.
Not pretty but they work, new bushes fitted. Not really happy with the homemade look. Will get some custom made latter.
Some heat shielding from the exhaust, twin 3” bore is not easy to route in a small space.
The rats nest! Still lots to sort out…….
Water pump moved to the front, now electric.
PostPosted: Fri Jul 18, 2014 5:27 pm
No photoshop this is her sat on the deck with no air.
Still have massive amount left to do, when will it end………..
Ok after work today got the switches wired up, I made this panel to go in place of the stereo I won’t need one my entertainment will be bellowing out the tailpipes! I have one switch for each air spring, and one master which will do all four, and compressor on/off. I also have a digital display panel for tank pressure, and each bag so will be able to fine tune the system, I know this has caused a lot controversy and people to believe this is going to handle like crap? But to be honest I really don’t know? Never done it before and it looks pretty cool to me. I like a challenge and to learn new stuff. Some people have said that they ride crap, some say they ride fantastic, way too much hearsay on the internet so wanted to find out myself. I don’t plan on driving it really low like some do, that’s the most likely cause of them riding crap as they are probably riding on the damper bump stops. Also some are not set up right with all four springs separate; some have them in pairs like front and rear, essentially making an independent suspension like having two live axles (backward tech in my eyes and never going to handle right?) I have changed wheels on cars many times over the years and going up a wheel size has always made the ride harsh. I have adjustable dampers and adjustable springs it has a chance of being a good drivable car, if not I have never closed the door to going back to the springs it came with. You never know it may be epic! Or drive like a dog like when I first got it. Had a little play with raising and dropping the car today was great fun and looked cool!
It gave me a bit of a boost to crack on, as I am struggling with motivation with many things not going right at the moment, and taking too much time to do. Especially in the hot weather. also forgot how low the cars is after having it on stands for ages!
PostPosted: Fri Jul 18, 2014 6:05 pm
fucking stunning. LOVE this build. Awesome job.
Dan McBoost
McBoost.comMA70.COMFB: DanMcBoostPSN: DanMcBoost
Audis: ● 04 A8L ● 97 A8Q ● 91 200 QTA ● 90 CQ ● 85 4000Q
Supras:88T87T87T85P
Other:06 XC90 V8 ● 04 Evo8 ● 99 V70R ● 91 Celica All-Trac ● 90 JDM MR2 GT ● 78 Toyota Pickup
death 4kqt wrote:
i was glancing through the pics and saw some girl hiked up on heels in a short skirt, my very first thought was "oh, McBoost was there" :lol:
PostPosted: Fri Jul 18, 2014 6:31 pm
Well done, awesome stuff. Thanks for sharing
Colin
1982 Porsche 911 SC
1983 Audi UR Quattro project
1987 Audi 4000 Quattro
1990 Audi Coupe Quattro
PostPosted: Sat Jul 19, 2014 2:24 am
thanks guys, glad to share
PostPosted: Sat Jul 19, 2014 3:20 am
Great project! Love the wheels - Speedline Mistrals?
How come the exhaust diameter reduces at the tailpipes? Is that to reduce noise?
Racecar: noun - a hole in the road in to which money is poured
PostPosted: Sat Jul 19, 2014 3:28 am
reading that was a good start to the day, especially one that will be spent driving to pick up more parts!
05 Audi A4 - Backup.
08 VW GTI - Daily.
06 BMW 530xi Wagon - Couch
PostPosted: Sat Jul 19, 2014 9:13 am
Location: Norton Shores, Mi. My cat has human-like reflexes
JAMES BOND
7a head/milled mc2 bottom w/holset Hx35...500hp for $500?
viewtopic.php?t=6726
PostPosted: Sat Jul 19, 2014 11:44 am
COOL! :thumbsup:
pkw wrote:
JAMES BOND
LOL!! I was thinking the same the thing. The pic of it up on jack stands with no wheels on it looks like its in submarine mode!
MRD
'84 VW GTI, crashed it
'84 VW Jetta turbo desil, sold it
'95 VW Golf, gave it to the brother
'87 5ktq, sold it
'95 S6 Avant, sold it
'01 Toyota 4Runner, current DD
'84 cgt-project car
PostPosted: Sat Jul 19, 2014 12:37 pm
wheels are Superstar made in Japan. Exhaust was made smaller so I could still fit twin pipes out the original hole.
It was still very loud! I had to fit more removable baffles until the neighbours warm to the V8 thunder, will take them out latter.
PostPosted: Sat Jul 19, 2014 2:05 pm
following, awesome lotus!
VW '79 Scirocco Rotrex 16V
Chumpcar
PostPosted: Sat Jul 19, 2014 2:06 pm
The pictures aren't working for me
2008 Audi S5
1989 BMW 325iS
PostPosted: Sat Jul 19, 2014 7:02 pm
very nice, surprised no ones asked for vids/sound vids yet :D
PostPosted: Sun Jul 20, 2014 6:02 am
:stupid:
1971 Ghia ratrod
2001 TT 225 6sp 80K
47 Dodge truck
96 Impala SS 91K
97 Suburban 200K and rusting out
98 Suburban 217k
99 Suburban 3/4t
PostPosted: Sun Jul 20, 2014 1:57 pm
sorry guys will have to wait for updates, busy sorting out loads of things to get it back on the road, will do a vid when its done..........
Rob
PostPosted: Sun Jul 20, 2014 3:32 pm
V8-ESPRITS3 wrote:
(airride) I know this has caused a lot controversy and people to believe this is going to handle like crap? But to be honest I really don’t know? Never done it before and it looks pretty cool to me. I like a challenge and to learn new stuff. Some people have said that they ride crap, some say they ride fantastic, way too much hearsay on the internet so wanted to find out myself.
I have done some searching and found that the typical air spring has a working active spring rate of about 100lb/in, that is in its middle working range. as you near bottoming out the spring rate rises some. This makes for a comfortable ride, but isnt ideal for performance where we want more spring rate to control body motions. there are some kits that have a ramp and collar to provide a rising spring rate for better handling.
Your car being light and with a very low CG should handle good with light springs and firm shocks, and have a very comfortable ride when the shocks are set to soft. it wont have the razor sharp back busting handling of a race car, but is that fun to drive on the street anyway? not IMO.
Chumpcar
PostPosted: Sun Jul 20, 2014 4:21 pm
As you may know I have been having issues with the pneumatic air solenoid valves. They are leaking air around the body joint and solenoid.
Red arrows in pic.
I brought a pair on ebay from a uk seller cheapish, and a pair from china on ebay even cheaper, yes I know buy cheap buy twice! Well yes its true they are crap!
They did work to start with but have got worse over a short period of time to the point of not working at all just clicking.
They other pair are following the same route and I expect them to die any day soon! Does any one use this type at work? Or use them at all on cars? I would be interested to still use this type if you can get them in a reliable quality. I think the other pair I brought most likely came from china as well. They work really fast and can have the car off the deck and ready to go in around 2 seconds! The kids love it! and so do I looks pretty cool!
The problem I found after taking them apart is a small O ring leaks and also around the whole solenoid body joint.
I tried to seal them with some silicone, but I don’t know if it would have worked as its still just clicking when I fitted it back onto the car.
really appreciate any info on these if some one has any knowledge they could share?
PostPosted: Sun Jul 20, 2014 7:47 pm
probably best trying to get some o rings that size rather than the silicone.
Try halfrauds they do some quite small o rings.
The other option is to keep an eye on some of the vw sites (edition 38/uk passats facebook group) and put wanteds up as they are all into air ride and sell spares, uk passats facebook group i've seen quite a lot of cheap air ride stuff.
PostPosted: Mon Jul 21, 2014 12:42 am
its not just the O rings they leak from the body, and are just clicking now and not working.
I have seen these used on other builds so thought they would be ok?
and may be some are ok just what brand? we know the Chinese are copying everything so some one must make these to a good quality as they are used in industry. They do work very well when working.
Rob
PostPosted: Tue Jul 22, 2014 9:46 am
Ok few updates, brought a new solenoid valve unit. Accuair aa-vu4 looks a really nice bit of kit, have used up a few Christmas and birthday presents to get it! But its all for a good cause I hope?
All fitted and looks much better not quite the rats nest that it was. but still needs some more tidying. That can wait in line with other unimportant jobs.
Got the old carpet out also, that was a job in its self why did it have to be stuck in with 50 tins of glue? Most of the carpet parts all ripped to bits trying to get them out. I did manage to use what was left to make a new set so hope to get that done tomorrow.
PostPosted: Tue Jul 22, 2014 7:05 pm
Nice work man!
If you have a 5 cylinder, you don't need a stereo
Homologation car junkie.
  |  It is currently Thu Jun 29, 2017 12:13 am
