Post new topic Reply to topic  [ 143 posts ] Go to page Previous  1, 2, 3, 4, 5, 6  Next
Ed's 1990 CQ 7aT
PostPosted: Tue Jan 27, 2009 12:41 pm
master of teh modz
Can't remember the status on the other ignition driver in that box. I know at least one was totally fried, and I jumpered it to make for a TTL output to trigger the stock coupe coil setup.
Open 'er up and look! :)
Don't Panic
Contact me with any site/registration problems: nstuart -at- 034motorsport.com
- Douglas Adams
PostPosted: Tue Jan 27, 2009 5:08 pm
Might take a peak this weekend.
Ed Hankin *All posts subject to inaccuracy due to multi-tasking and iPhone.
PostPosted: Sat Mar 14, 2009 6:08 pm
Small update:
Passed Air Care Colorado E-test! With a "Fast-Pass" no less!!!!!
Now I am good for 2 years. Hopefully the drive by program will still be around. Load a clean file & drive by the truck a few times. DONE :D
Amazing what a little E85 (3/7ths of a tank) and a fresh kitty will do.
It is running pretty well on the 4:3 91OCT:E85 ratio after a slight tweak. Might leave it this way and do a little leak fixing before swapping injectors and going 100% E85 + boost.
PostPosted: Sat Mar 14, 2009 11:48 pm
master of teh modz
Nice and clean 8)
Don't Panic
- Douglas Adams
PostPosted: Wed May 06, 2009 3:56 pm
HMmmmm
PostPosted: Wed May 06, 2009 4:26 pm
master of teh modz
Interesting, be sure to get some good pics up, haven't seen that style before.
Don't Panic
- Douglas Adams
PostPosted: Wed May 06, 2009 4:31 pm
Mcstiff wrote:
HMmmmm
Separated at birth?
//Dave
'90 E-S2 '91 CQ '00 A4 Avant
PostPosted: Wed May 06, 2009 4:46 pm
Just a sketch of what smoking would look like. I have a theory that nightshades might work over chrome. Going to have to get just junkyard chrome to test.
The H1/H4s do not leave anything to be desired. I bought a bucket with tabs to fix that issue.
Just toying around with saving the real lights. Really I should be buying a bumper to mount an intercooler behind.
PostPosted: Wed May 06, 2009 4:51 pm
Really cool that you picked this car up.
Looking forward to watching it progress :-)
Audi Coupe Quattro
PostPosted: Fri Jun 19, 2009 11:42 pm
Any tips on configuring the Turbo/Engine Flow Calc for E85?
Step 1 will be tuning for 50/50 E85 (so 9.25G of E10 + 9.25G of E85= 8.7875G E100 + 9.7125G 91OCT= 18.5 G of E47.5 @ ~ 98 OCT)
This will be an intermediate step before installation of an Intercooler.
Useful E85 calculator: http://www.intercepteft.com/calc.html
PostPosted: Sat Jun 20, 2009 9:02 am
leave afr normal in calc think lambda. 12-1 afr @ .55bsfc or 11-1 afr @ .60 bsfc. is reasonable
Educated guess 11-12 psi will be needed to get you back to sea level numbers. With ethanol should be able to beat nates dyno numbers at that 11-12 boost uncorrected
94 UrS4
01 B5 Avant NASA GTS3 Project
84 Porsche NASA Spec 944
81 "twabbit" Rabbit Truck
www.wasabiraceteam.com
www.hanksvillehotrods.com
www.autobahnpremierservice.com
PostPosted: Sat Jun 20, 2009 9:40 am
I was working under the impression that lambda for E85 = ~9 AFR. Value updated.
Just looking at the T3-60 map to see where it runs out :D
Need to get a WBO2 in before much more happens with E85.
 Post subject: E85 BSFC
PostPosted: Sun Jun 21, 2009 12:24 pm
User "Hotrod" on NASIOC thinks TC's E85 BSFC is .65 from .5 or a 1.3 correction. Formula SAE uses a factor of 1.4 to correct unleaded BSFC to E85. I hope they are doing more then guessing. I'll go with the SAE for now.
Bell cites an injector size formula of (Goal BHP*BSFC)/# of cly= #s/min of injector says that (240 bhp*.77)/5= 36.96 #/min * 10.5= 388.08 cc injectors.
If I have 42# injectors as noted on the previous dyno sheet then:
BHP= (inj x cly)/BSFC = 272.7 So, on paper, 42# injectors should max out at ~ 272 BHP with E85.
Nate, does the CQ have the 42#ers noted on the dyno sheet?
PostPosted: Mon Jun 22, 2009 11:12 am
master of teh modz
Negative, it has the stock replacement injectors, running at 4bar, so they work out to nearly 40lb or so.
Don't Panic
- Douglas Adams
PostPosted: Mon Jun 22, 2009 12:19 pm
Cool, I guess I could have just looked :wink: then I would have to open the hood and maybe turn a wrench :lol:
PostPosted: Wed Jul 08, 2009 12:24 am
Playing with another plotter:
T3-60 12 psi E85 no IC
The multiple points are nice but it seems "off" idk
PostPosted: Tue Jul 14, 2009 12:39 am
For the record, S2 xmember and IC "under" a CQ bumper.
I think a custom xmember and maybe a vertical flow IC would fit better (aux raid delete and some ducting and trimming).
PostPosted: Tue Jul 14, 2009 12:51 am
Thats actually a 3b intercooler... but yeah...
//Dave
PostPosted: Tue Jul 14, 2009 1:13 am
Lets just call them S2 parts :P
Found this example too:
Not perfect but closer to what I am thinking.
PostPosted: Tue Jul 14, 2009 7:42 am
Or you could get a S2/Euro Cabrio bumper?
John
'86 CGT
'90 20v sedan
Where we going? Why are we in this handbasket?
PostPosted: Tue Jul 14, 2009 8:59 am
Is that a question or a statement?
I have been keeping my eye out for a red S2 bumper but have not been able to find one. If I have to paint a bumper/bumpers then I may as well respray the car.
ICing is a higher priority then looks and the above options do not lock me into anything (I can get a EUDM bumper when I find one). Function > Form.
PostPosted: Tue Jul 14, 2009 10:54 am
More of a statement I guess. I have a EuroCab bumper I don't need but it's a gold colour.
John
'86 CGT
'90 20v sedan
PostPosted: Tue Jul 14, 2009 11:08 am
Early or late Cab? IIRC the cab bumper does not have much room behind it.
PostPosted: Tue Jul 14, 2009 11:54 am
There are a couple of downsides to my approach- cost and cooling. Getting the custom fabrication for that intercooler setup cost me around 1.5k. I can double-check that figure. The engine also runs pretty hot. Make sure you have a good radiator/fan setup and appropriate shrouds.
91 CQ 20vt IIc
09 Volvo V50 T5
PostPosted: Tue Jul 14, 2009 12:04 pm
Something like this (took a while to remember I had a pic):
Users browsing this forum: No registered users and 6 guests
  |  It is currently Thu Sep 09, 2010 1:30 pm
