Post new topic Reply to topic  [ 68 posts ] Go to page 1, 2, 3  Next
Barry's '90 200TQA - TB job update, and a daily driver!
 Post subject: Barry's '90 200TQA - TB job update, and a daily driver!
PostPosted: Wed Oct 28, 2009 11:41 am
Well, it's about time I formally introduce myself. Here's the beast in question, a 1990 Audi 200 Turbo Quattro Avant (I heart the Avants). I've been into old VWs since I could drive, and Audis since I stopped loving that buzzing in my ass while driving . . :)
OBJECTIVE: A nice, stealthy and attractive GT driver with hauling capacity and enough power to surprise the Hondas floating on neon.
SECONDARY OBJECTIVE: Keep the beast running reliably :)
OBSTACLES: No garage space (but in sunny Tucson rain is rare), Porsche 944 project that takes all my time and cash! :P
DONE SO FAR:
  • Eibach lowering springs and Koni struts (photos on page 3)
  • 034 LW flywheel and South Bend Stage 1 clutch
  • 034 engine and trans mounts - street density
  • 2.5" exhaust
  • New bushings for the entire front end including an upgrade to C4 upper strut mounts
  • Vacuum brake boost conversion - writeup on QuattroWorld forums HERE
  • Chip and spring installed by SJM (previous owner)
  • Euro headlights (previous owner)
  • Euro smoked rear tail lenses (previous owner)
  • 2004 A4 16x7 wheels with 215/55/16 tires - temp rollers
  • Swepco in the tranny and the engine
  • All dash bulbs replaced, 'check engine' light activated for pulling codes
  • Basic tune-up and repair: cap, rotor, plugs, grounds fix, sensor tests, MM hose, O2 sensor, fuel filter, all coolant hoses & heater valve, new master cylinder, etc
  • Roof rails removal
PLANS:
  • Engine: 20V intercooler upgrade with silicone hoses, BPV install (that's it FOR NOW :))
  • Suspension: continue the rebuild - rear bushings, possible rear sway bar
  • Brakes: upgrades all around!
  • Stereo: a high-end upgraded stereo that's totally hidden (not an easy task on the Type44 Avant)
  • Cosmetics: Front lip spoiler perhaps
PICS (Two weeks ago right after a detail):
2010 Audi A4 Avant - the daily driver
1990 Audi 200 Turbo Quattro Avant - project thread, evident addiction
1984 Porsche 944 - 'Mathilda' the needy
PostPosted: Wed Oct 28, 2009 11:45 am
How do you do with emissions in az? I loved it there, even in july but I was horrified when I saw mostly brand new cars driving around.
[img]http://i206.photobucket.com/albums/bb159/Mange3586/th12423-2.jpg[/img]
The Scirocco...
http://www.motorgeek.com/viewtopic.php?f=6&t=29296
And the Avant.
http://www.motorgeek.com/viewtopic.php?f=6&t=30868&view=unread#unread
1995 S6 Wagon
1985 Scirocco (#14) 16vt on 034
2003 Ford F250 7.3l Diesel
2007 FJ Cruiser
Hyundai of some sort.
Eric really long last name
PostPosted: Wed Oct 28, 2009 1:16 pm
So far emissions haven't been a problem. I have an '89 200TQA that I tested last year too before I took it off the road, and even at 250k miles it passed. That being said, when they see you've got AWD they only make you run the idle test, you don't have to do load tests - they don't have an AWD test rig in my district. Should make future mods easier :D.
Nice S6 Avant, BTW - sweet ride!
PostPosted: Wed Oct 28, 2009 2:36 pm
How much for your roof rails?? I think that if you're removin them I would love to have them. I like the utility and I think they add a nice touch when shined up.
Ian
kalamazoo, mi 49009
PostPosted: Wed Oct 28, 2009 4:47 pm
Ha thanks man...
The Scirocco...
And the Avant.
1995 S6 Wagon
2007 FJ Cruiser
PostPosted: Wed Oct 28, 2009 5:31 pm
Very!!! nice MCII...
Looks like a nice mod list. the 20V IC is a nice upgrade but my suggestion is to keep this ride as clean without going crazy on the engine mods unless you have another ride and she'll treat you well and run strong for a long time.
I've done virtually every bit of suspension and brake work on mine and it handles amazing. I personally like the HD Audi springs better than HR's.
I envy your paint. Hopefully I'll repaint mine in the spring.
Very nice ride...
95.5 S6 Avant
98 A6 Avant
72 Firebird Esprit
Moots Gristle 96er
Moots Vamoots
PostPosted: Wed Oct 28, 2009 5:39 pm
Very nice looking car!
1988 90 quattro Clearcoat Black
1990 90 quattro 20v Tornado Red- Crushed before she should have been :(
1978 Yamaha XS500
PostPosted: Fri Oct 30, 2009 7:52 am
Hmm, not sure but I might have a box for them. I've got two sets anyway. PM me.
Ian
kalamazoo, mi 49009
PostPosted: Fri Oct 30, 2009 7:54 am
Thanks! She has been repainted. And I'm waxing her regularly and keeping her under cover, as red paint doesn't last long in the AZ sun!
Very nice ride...
 Post subject: Stereo switching mod (with windows & interior lights)
PostPosted: Thu Nov 05, 2009 9:27 am
Like so many early VAG owners, I want my stereo to turn off with the key. I told my girlfriend I could make the stereo stay ON when the key was removed, but turn OFF when the door was opened. Of course I had MISREAD Richard Hoffman's previous post on the AudiFans Archives (see it HERE - http://www.audifans.com/pipermail/200q20v/2008-February/025285.html), as he mentions getting the stereo to turn off w/ the key. Not to miss an opportunity to outshine the girlfriend's 2007 Jetta, I went to work. I figured if the power windows still ran w/ the key out and door closed, all I would have to do was tap into that wire for accessory power to the stereo. Right?
The solution: Terminal 87 on the power window control relay (the big dual relay under the driver's kick panel). BINGO. A thick red wire with a blue stripe (pic below).
Now the stereo stays on when you turn the car off, and even when you pull the key. You've got 30 seconds before the lights, windows, and now the stereo turn off. But once you open the door, everything turns off. Perfect.
The girlfriend is jealous :D.
PostPosted: Thu Nov 05, 2009 9:53 am
BTW, the head unit I'm using is an Eclipse CD7000. Switchable illumination helps it integrate into the dash. It's still a bit more flashy than I'd like, but I can't argue with really clean power, three sets of RCA outs, selectable crossovers on every channel, a parametric EQ, and their ESN key CD security. Eclipse has always been one of my favorites. Here's a pic of the illumination:
PostPosted: Thu Nov 05, 2009 9:56 am
Nice...The Blaupunkt I installed turns on/off with the key OR by it's own power button. I may move where I picked up switched power so it's key-on/door-off...
http://coupe.gofergusons.org
'07 Q7 4.2
'07 Q7 3.6
'98 A4tq
'90 CQ
'90 CQ
PostPosted: Thu Nov 05, 2009 12:09 pm
Very cool idea.. im gonna go switch that wire right now!
Tommy O
1990 Crystal Silver CQ with a ton of new OEM parts!!!
PostPosted: Thu Nov 05, 2009 2:04 pm
My windows stay on all the time, the terminal 87 drops to 1.3v after about 15 secs, but as soon as I hit the window switch, it goes right back up to 12v, even if the car has been sitting for hours.
2001 Boxster S, black, loaded "New Hotness" - Keeping it around for a while!
1991 Factory 5speed V8q w/4.2 and ABT chip, AKA "The Sled" - Sold
1989 200 quattro, pearl white, 17" A4 rims - Sold
2000 S4, black, tip, blew the turbos, bad trans - Sold
1983 5000 turbo (auto, FWD, POS) - Sold (thank gawd)
1990 80 quattro, white, never ran right - Sold
1984 4000 quattro, white - Sold
1984 4000 quattro, Gobi Beige Metallic - RIP
PostPosted: Thu Nov 05, 2009 2:39 pm
My 200 does that too unless the door is opened. Then there is no power available. Do yours still work when you open the door, at least if you try to use the windows?
PostPosted: Thu Nov 05, 2009 3:26 pm
Yup, I can open the doors and still roll the windows down. Occasionally the windows don't work until after I turn the key, but that is very rare. Lemme look at the Bentley and see what controls the delay.
PostPosted: Thu Nov 05, 2009 4:06 pm
Should be the relay itself that controls this. I wonder if there are different relays, especially older T44 vs. newer. My relay is marked '286' on the top I believe.
PostPosted: Thu Nov 05, 2009 8:48 pm
Tracing the wiring, everything seems to come back to the Anti-Theft Alarm Control Unit and that gets info from the central locking switches, of which my LF doesn't work. After a quick test, the module stays OFF if I open the RF door after removing the key. This is just one more reason to fix the LF lock switch. Who would have thought that the door locks are tied into the power windows?
PostPosted: Fri Nov 06, 2009 7:59 am
Right, that makes sense.
 Post subject: Fuel pressure tests - the power is back!
PostPosted: Sun Nov 08, 2009 3:46 pm
I finally bought a CIS fuel pressure tester after years of VAG ownership. Got around to testing control and system pressure on the '90 TQA yesterday. We had a little trouble - mostly the directions on 1) where to hook it up, and 2) what adapters to use were rubbish. No problem though, after a bit of fiddling around we got it figured out.
During the trouble, we swapped in the WUR off my parts car (just made it easier to swap connections). So, system pressure is at a respectable 6.1 bar, and warm control pressure is at 3.6 bar.
So we installed the replacement WUR since it tested OK, and now my power is back! Obviously my old WUR was bunk - we hadn't got any readings before we switched, so I don't know exactly what is wrong with it. Maybe I'll take it apart and rebuild it down the road. But for now I'm happy.
Haven't had a chance to see if my cold-start issue is any better, as it's seeping just a very little bit now at the fuel line connections on the WUR. Crappy aluminum washers! So, I've got to procure some new ones tomorrow. More later . .
 Post subject: Re: Fuel pressure tests - the power is back!
PostPosted: Mon Nov 09, 2009 1:32 pm
Were you leaning out towards the top end while accelerating?
Corey
http://www.justfourrings.com
88 5KTQ "White Widow"
95.5 S6 Avant NOW the *SRS* RIP
03 S8 Exclusive package
PostPosted: Mon Nov 09, 2009 1:37 pm
I had no gauge data to verify this, but yeah, that's what it acted like. Actually, it seemed a little restricted over the whole range - the car is much more responsive again.
I popped over to the local import parts shop at lunch today and got my new copper crush washers, so I'll be back in business tonight!
PostPosted: Mon Nov 09, 2009 1:42 pm
Hmm this is very interesting.
I dont if the 90' 200's dash has it but there is a knock light on my 88 5ktq. Did you get any indication like that, with the loss of 'power/ fuel'?
Corey
PostPosted: Mon Nov 09, 2009 2:17 pm
I've just recently activated my 'Check Engine' bulb, is that the light that blings on knock? I did hear some pinging the few times I took it to WOT. Since then I took it easy on the car to prevent any possible damage. I didn't actually rev the car up that hard once I had the Check light activated.
PostPosted: Mon Nov 09, 2009 5:18 pm
I think that is the light. Im not 100% sure as we have different clusters but my best guess is yes that is the light in question. I am surprised you were able to hear a ping w/ this car (there is a lot of background noise w/ the T44).
Corey
  |  It is currently Mon Jun 26, 2017 5:22 pm
