Post new topic Reply to topic  [ 160 posts ] Go to page Previous  1, 2, 3, 4, 5, 6, 7  Next
My Audi 90 (B4) VR6 Turbo build
 Post subject: My Audi 90 (B4) VR6 Turbo build
PostPosted: Wed Mar 30, 2011 11:35 am
Sorry I have been away from the forum for a while...I promise to keep more up to date with progress from now on...I have tapatalk on my phone so it's easy to check at work now
But to the car...unfortunately I blew the motor on the dyno last year...the motor was stock with only a gasket and head studs...it made 396 whp and 369 wtq before it went...so I have started ordering the parts to rebuild and some goodies have come in...
JE pistons fully coated 9:1
IE brand new rods...really nice
PostPosted: Wed Mar 30, 2011 11:39 am
Also..I have a precision 6262 ball bearing turbo with a T4 .68 hotside...I plan on revving to about 8k...motor will be a 2.9...and really agressive cams...do you think I should go to the T4 .82 hotside or will I be ok with the .68?
 Post subject: Re: My Audi 90 (B4) VR6 Turbo build
PostPosted: Wed Mar 30, 2011 11:52 am
I think you should go .82. That .68 is going to choke you in the long run.
-Chris
'01 ///M5
PostPosted: Wed Mar 30, 2011 12:24 pm
big vr6 + big hotside= big smile!
Dana
no more audis for me
-4kq efi 10vt<- sold
-99.5 f250 6-speed superdooty diesel
-1990 90q 20vt: 3b swap >sold
-1990 90q 20vt: 11.7 @124.5 >sold
lots of other audis that are long gone
PostPosted: Wed Mar 30, 2011 1:00 pm
:stupid:
.82 minimum.
Mark Siggelkow
'90 CQ-R - NASA GTS-4
'13 Toyota Tundra CrewMax Platinum
'12 TT-RS (Wife's DD)
'00 A4 1.8TQ
'62 356B (vintage racer)
PostPosted: Wed Mar 30, 2011 2:11 pm
Yeah, for that power level you will be happy with the .82. Who coated the pistons?
Dan
1986 4kq Daily/winter beater
1987 4kvr6tq Project / track car
2001.5 S4 Daily driver
PostPosted: Wed Mar 30, 2011 5:39 pm
I have to say the paint and body work are stunning, care to tell whats involved with shaving the trim and/or where you took it?
Thanks,
Jon
1991 Audi 80q 20vt :project:
Other lame cars
PostPosted: Wed Mar 30, 2011 7:11 pm
yes .82 atleast, that would seem to be the smallest you could go without feeling choked up top
BEAST http://www.motorgeek.com/viewtopic.php?f=6&t=40366
DD '86 4kq BLAZE, swapping aba/16vT and O1E http://www.motorgeek.com/viewtopic.php?t=34308
PostPosted: Wed Mar 30, 2011 8:21 pm
I got them from IE...not sure if they are the ones coating them or if it comes from JE like that
Thanks,
Jon
It was a lot of work...he used a lot of 1 min plastic repair...AMS Autowerks in Linden, NJ
Now here is another question...should I stick with the 6262 or go with something bigger and better...such as a 6765...I am not a big fan of a lot of lag, but I would like to make some good hp...just to keep in mind, I will have horrible low end power because of the cams but it will be amazing up top
PostPosted: Wed Mar 30, 2011 8:32 pm
what cams are in teh car? 272?
PostPosted: Wed Mar 30, 2011 9:05 pm
Going with either 284 or 288
PostPosted: Wed Apr 06, 2011 5:03 pm
i think i would be good with the T4 .68 man its about the same size as a t3 .82 housing, and that is perfect for a vr, the .82 will work also but little more lag, but i doubt u would notice the 68 choking, try them both and see what kind of power differences u get out of them,
and 288's will do work also, just make sure u got some major head work and check ur valve clearances and make sure u let the lifters bleed down for a little while before u crank it or it wont be pretty
PostPosted: Wed Apr 06, 2011 5:54 pm
Awesome, thanks for the help!!! Just to see what u think...I can sell my 6262 for a good price, it it worth getting the 6765? And what would be a good hotside for that turbo
PostPosted: Wed Apr 06, 2011 6:03 pm
personally i would just get like a holset hx52 but im cheap lol casue u can get them for less than 300 bucks, but id stick with the same hot side on the 67mm and i think u would be good, gonna need to keep it in the efficiency range cause a vr is not gonna flow up top anyways, and i bet it will hit full boost by 4500 ish,
PostPosted: Wed Jul 27, 2011 6:13 am
Well I have finally got all my engine rebuild parts in and I have sent out the motor to the machine shop...hopefully it won't take to long because I am eager to get this thing on the road again...
Just one quick question...I have searched about the 01e swap but all the results I find are for coupes...anyone know what needs to be done to fit it in a B4...thanks in advance and once I get the motor back I will post up pics
PostPosted: Wed Jul 27, 2011 7:32 am
i talked to a guy with a hx52 12v vr6
15 psi @4700 , max of 24 psi around 5500
PostPosted: Wed Jul 27, 2011 7:51 am
Basically, theh b4 is the chassis the rs2 is based off of. The subframe is the same as the rs2, so mounts from that car will work on your car. The rear diff is 3.89, so you will either need to find an uber rare over here tdi box, or swap rear ends. The later is easier. The b5 s4 rear diff should fit without any modification, and then you just need to get the driveshaft from the same said vehicle IIRC. There is an guy on audizine that parts out s4s all the time, and I want to say they charge around 250 for the rear diff and 125 for the drive shaft. I'll try and dig up the link to the guy for you.
Good luck!
Hank
81 URQ 20vt 612whp/527wtq
PostPosted: Wed Jul 27, 2011 8:14 am
Isn't the 2.7T gearbox from the A6 Allroad 3.89?
96 Audi S6 20vt sedan automatic, breathed on.
95 Audi 80 2.0 sedan automatic
PostPosted: Wed Jul 27, 2011 8:23 am
nah its even higher than 4.11
buddy has a chipped 2.7tt allroad and 1st gear is almost unusable
-Ken
1983 Audi Quattro
1995.5 S6 Avant -daily-
PostPosted: Wed Jul 27, 2011 8:59 am
Yeah...I have a 2000 s4 trans, dif, driveshaft, And front and rear axles...I am just not optimistic about the driveshaft and axles working...as far as mounts go, I was just thinking about custom mounting...I figure that finding rs2 parts will be extremely hard
Do you guys think I need to get custom axles made?
PostPosted: Wed Jul 27, 2011 9:30 am
If you have the s4 stuff there, it should be pretty easy. If the axles do not fit up front, then you can do what the b3 and b4 guys do, and just use either rs2 axles, or use 100mm cups from an older 016 transmission with your existing axles. The 01a you have in there now just differs in length, not width. Big power will eventually distroy the inner CV on your current axles, but you could do that as it comes up.
Make sure you grab the linkage from the b5 s4 as well. A simple cut flip and weld makes that go into the b3 and b4 chassis really easily.
Remember, the b4 is the hybrid of the b3 and b5. THe B4 has a b5 rear end with a b3 front end.
Hank
PostPosted: Wed Jul 27, 2011 11:06 am
Awesome...thanks for the detailed write-up
PostPosted: Wed Jul 27, 2011 7:32 pm
In my b3 i used all b5s4 stuff and a JHM shifter and I actually needed to to some shifter tunnel clearanceing to get reverse and fifth to both work properly. Just a heads up.
||-1990 Audi90Q-||-2.0L20v-||-6765 .81 T4-||-LugTronic-||-ID 2kCC's-||-e85-||-32psi-||
||-10.7@136-||-1.76 60FT-||-32psi-||-255/40/17 street tires-||
http://www.youtube.com/user/zerbmedia
PostPosted: Sun Jul 31, 2011 6:59 am
When you say you used all b5s4 stuff, what did that include?
PostPosted: Thu Aug 18, 2011 5:17 am
Well the block and crank is back from the machine shop...freshly bored and cleaned up...should be getting the head back soon too....can't wait, super excited!!
Users browsing this forum: No registered users and 28 guests
  |  It is currently Wed Jun 19, 2013 5:21 pm
