Post new topic Reply to topic  [ 47 posts ] Go to page 1, 2  Next
K-Mans 3b cq- hy35, spark, fuel, compression, bang! Whooo
 Post subject: K-Mans 3b cq- hy35, spark, fuel, compression, bang! Whooo
PostPosted: Tue Mar 16, 2010 7:32 pm
After 6 years of s l o w l y building i guess its time to start a thread.
The goods:
1990 Cq
Dawkins semi built (6-14) 3b motor
7a cam
MLS hg
Arp studs
spec stage 3 clutch
3b s2 wire harness (thanks Josh)
IA 3+ chip 2.5 bar pressure transducer
740cc injectors (6-14)
Innovative wide band (6-14)
044 fuel pump (6-14)
TurboSmart wg, plumed by Houdek
fancy air filter- HKS
shorty tube manifold- Happersized, cooked, 1 manni dead (6/13) O34 t-3 log manni
3" LoveFab down tube (now 3" 3MG (Frank) very custom down tube
custom 3" pipes
custom e-Bay / Local IC 18"x8"x3" & 2 1/4" piping
metal dizzy gear
k26 2.2"(smoked) now k24, (turbo no.4) HY35 (6/14)
5 lug (s2 rear- s4 front hubs)
H&R - with Bilstein urs4 sport inserts (bbse)
B4 strut brace (new 6/12)
Mance upper strut mount front
034 street upper rear
034 solid sub frame front and rear
034 street D control arm bushings
034 snub
1991 suspension swap
'92 Fox front seat mounts, for the sikness
Gray cloth "quattro" script seats (non electric)
17x8 bbs ry- 16x8 fuchs- 16-7 avus-++++
custom jack mounts (6/12)
...and some more lil bits
Question: i hope its not a stupid one.
In side the the cabin near the ecu plug is a tag that says
"Altitdude sensor" with its own plug. Where is this sensor in the 200?
I don't rember seeing it in the now 2 200's I've dismanteled, or in the 2 urs4's that i've also dismanteled. When reading about it a while back, i thought it to be in the ECU. So, where is the altitude sensor?
thanks
Cheers![/img]
90' 3B Cq, Hy35
86' 951
80' Scirocco, 8v GTI power
PostPosted: Wed Mar 17, 2010 6:55 am
http://www.sjmautotechnik.com/trouble_s ... 0valt.html
Audi 80 GTE (82 2,2 3b)
Audi 80 Quattro (83 3,6 v8 ) soon
SORRY for my English ;)
PostPosted: Wed Mar 17, 2010 7:00 am
There are no stupid questions, only stupid answers.
Here's one:
If I remeber correctly, in the 200, the altitude sensor is on the drivers side, in the footwell to the left.
Then again, maybe it was on the passenger side. Or was it under the rear seat? No no, definately not under the rear seat. Driver's side, my final answer.
PostPosted: Wed Mar 17, 2010 7:02 am
Come to think of it, I think it was mounted to the same point as the hood release lever, or at least in that vicinity.
Mike
1990 CQ 3b
PostPosted: Wed Mar 17, 2010 9:22 am
Right, exatly what i was thinking...
90' 3B Cq, Hy35
86' 951
PostPosted: Mon May 03, 2010 8:01 am
ok, so on the altitude sensor,,, the pins "1 2 3" what color wire goes to what pin? rd/bk gray purp/bk
90' 3B Cq, Hy35
86' 951
PostPosted: Mon May 03, 2010 8:14 am
intake mock
90' 3B Cq, Hy35
86' 951
 Post subject: Re: K-Mans 3b cq- pics... Alti sens Question
PostPosted: Tue Sep 07, 2010 3:35 pm
Help please!!!... can anybody identify these wires???
there is a large red/black
and green/black
and that connector looks like a turn signal or something, but this is in the same loom as MAF
90' 3B Cq, Hy35
86' 951
PostPosted: Tue Sep 07, 2010 3:44 pm
and these too please???!!!!
90' 3B Cq, Hy35
86' 951
 Post subject: Re: K-Mans 3b cq- pics... name that wire....
PostPosted: Tue Sep 07, 2010 9:07 pm
www.s2central.net ? I think has a pdf file on alot of stuff. I c o2 sensor stuff big white plastic connector, an l30 connection and i think the blue and red wires are ignition 87a. This is off the top of my head. the bottom picture I'm pretty positive is for the aux guages.
Confidence in nonsense is part of the process of the creative mind. It is only nonsense because someone else hasn't thought of it until now. Image
PostPosted: Wed Sep 08, 2010 10:46 am
dang, your on it!!!! thankyou again!!!!
90' 3B Cq, Hy35
86' 951
PostPosted: Sat Sep 11, 2010 1:56 pm
ok, its going, but slow. most wires are home but the black conector/2 blue wires at fuse panel. is this the "ignition" wire you speak of?
pump is flowing, power to the coil but no power from the coil. ( black wire is hot). (no spark btw). any thoughts? also having some trouble fittin the urs front hubs. Does tha gehetto fab involve a bit of shimming? maybe on the axel in trade for the 5mm left out? the abs ring bottoms out. took it off and still bottoms out. maybe some shimms between caliper and nuckel? please excuse tha poor spelling.
cheers
thanks
90' 3B Cq, Hy35
86' 951
cheers
thanks
90' 3B Cq, Hy35
86' 951
PostPosted: Tue Sep 21, 2010 7:51 am
mostly all together , but does not run. the 5 lug is totally gehetto at the moment, but it'll work for now. 5mm shim behind splines, and 2mm shims on the caliper carrier. lame, but it rolls. all the wires have a home, but some must be in the wrong home as it is only barn art at he moment. if there are any suggestions out there it would be greatly apperciated. geday mates
90' 3B Cq, Hy35
86' 951
PostPosted: Sat Feb 05, 2011 8:53 am
This isn't going to exactly pickup where things left, but we'll do our best to include everyone in the fun that is Quattro Building.
Snagged a couple photos spotlighting the placement of the exhaust manifold and it's custom motor mount. Kelty can add more detailed insight into the pedigree of the parts.
Ian
87 5kcs, IA, 15psi, h&r, ebaay FMIC w/fabolous BOV, 203k-248k-----PARTED AND CRUSHED, remembered in fondness forever.
91 20020vtavant, IA stg3, Wilwood bbk, H&R, Koni, 2b K24/26, under construction
91 20020vtsedan, stock, UFO's, BOSE, Minty Sport seats----- 'The death of a sedan' by Too Much Boost. 172-183k.
PostPosted: Sat Feb 05, 2011 3:38 pm
That exhaust mani looks neato...
-Ben-
-1985 Audi 4kq: PTE5857 AAN In Progress-
-2003 Audi A6 4.2 -1990 Nissan Pathfinder SEV6-
PostPosted: Sun Feb 06, 2011 6:29 pm
Has anyone tried to mount the air cleaner back in the old battery box location? I noticed that it has cold air feed holes from below the windshield(highpressure area). I was looking at some old audi racecars and there was quite a show of high-hp monsters breathing from this area. Although they also vent the hood with louvers and run an airbox back in place of the HVAC box I think this could work.
Build a decent box to shield from heat and draw air from outside.
Ian
PostPosted: Sun Feb 06, 2011 6:34 pm
The aircleaner is an old HKS model that deserves some photos as well(but they have to wait). After you remove the pancake metal shield and foam is a delightful web of plastic that controls airflow through the filter smoothing it as it passes. At the base of the filter lies the velocity stack. I thought that it was pretty neat and I love scrounging old hotrod parts such as this from friends.
Ian
PostPosted: Sun Feb 13, 2011 8:20 am
Well I'm going to start this off by saying that the thing runs and drives. Still needs to be finished but after 7yrs of silence The Little Coupe That Could is alive and well. Only makes 5psi and I already checked in on the other thread.
viewtopic.php?f=14&t=39316&view=unread#unread Hopefully I can figure it out first!
Currently setup in stg1 not-intercooled. It's winter and I just haven't settled on the 'right' design for the pieces that we have. You may notice multiple years and models of Audis Frankensteined into this vehicle. All pieces have a purpose and most are used because we had them. It's amazing what you can do with an erector-set of Audi parts. On to the pics.
The crew; Kelty(owner), Robbie, Myself
Ian
PostPosted: Sun Feb 13, 2011 10:33 am
Very cool!
I like that high end brake disc.
it saves weight.... right?
-Phil
87 5ktq - 3b swap, VEMS
05 s4 - "Daily"
PostPosted: Mon Feb 14, 2011 9:10 am
pilihp2 wrote:
Very cool!
I think that you're just jealous of my naturally occuring rust. That is a small amount of rust that will be gone after bedding in the pads. Remember that this car was built out of mainly used audi bits that where laying around. Many totalled audi's donated their organs here.
Ian
PostPosted: Tue Feb 15, 2011 8:04 am
Codes indicate problem in N75 valve. Testing at valve reveals power and switching ground under Output test. N75 shows resistance of .5ohm but does not 'click' under Output test. Time for an N75valve and we should have boost back...
Ian
PostPosted: Tue Feb 15, 2011 10:01 am
It looks like there's a giant 1/8 inch wide gash in one of the brake discs all the way around. or am I way wrong?
-Phil
05 s4 - "Daily"
 Post subject: Re: K-Mans 3b cq- pics... And the beat goes on
PostPosted: Fri Feb 18, 2011 3:31 pm
Just an illusion. Thats where the pad was draggin a bit. There Is about 30 miles in it now. The discs look better. And Lotsa leaks to tend to. Surprise!!! The turbo is f'd too. Thinking that at least 1 of the 2 spares around would work I removed the turbo, then noticed both spares are junk. Sweet. On the hunt for a k27 or some sort of k26 hybrid...
90' 3B Cq, Hy35
86' 951
PostPosted: Tue Mar 29, 2011 6:56 pm
it runs and drives
MikesShit 096.JPG [1.49 MiB]
Downloaded 115 times
90' 3B Cq, Hy35
86' 951
Users browsing this forum: Google [Bot] and 3 guests
  |  It is currently Fri Feb 24, 2017 2:43 pm
