Post new topic Reply to topic  [ 540 posts ] Go to page Previous  1, 2, 3, 4, 5, 6, 7, 8 ... 22  Next
ABZ Fiero
 Post subject: Re: ABZ Fiero
PostPosted: Sun Dec 29, 2013 5:08 pm
well just siting and watching it snow out i have the wiring harness almost done just need to rout it in the car but i have to wait for spring
PostPosted: Sun Jan 26, 2014 8:38 am
I love tax returns i should be able to rent some space and get what i need to finish this up or be very very close to being done
PostPosted: Sun Apr 20, 2014 12:54 pm
I did rent some space infact i opend a repair shop in Enfield NH . I havent worked on the project yet but i will tomorrow since i am closed on mondays. hopfully i should have it up and running in a few weeks but it wont be on the road untill i can pay to have some axle spacers made for it where they bolt up o the transmission axle flange.
PostPosted: Sun Apr 20, 2014 2:28 pm
:thumbsup:
PostPosted: Sun Apr 20, 2014 6:59 pm
I can probably make you some spacers, I'm down In Unity NH. Let me know if I can help you out.
02 S6
1990 coupe (project)
03 golf
00 Dodge Cummins
PostPosted: Mon May 05, 2014 5:50 pm
thanks kickin' tires'n lightin fires i will contact you when I am ready for them but right now i need to know what tooth is TDC so i know what to set in the megasquirt is it 72 degrees or what it is stock flywhel stock sensor posission
PostPosted: Mon May 12, 2014 5:10 pm
though i would post a few pics showing the wiring has been taped up so it is not a rats nest
PostPosted: Wed Jul 09, 2014 12:36 pm
Hi I haven't been working on the car to much due to opening a shop but I have gotten the clutch hooked up along with the shifter installed the wiring is about done and 1 axle is in I just need to buy the other side. I need to do exhaust , alternator, cooling hose's , knock sensor , o2 sensor and a few other things . I am shooting for the end of August to complete it
PostPosted: Mon Jul 28, 2014 7:29 pm
just some pictures of what i have been working on and the project is still alive
PostPosted: Sun Aug 10, 2014 10:16 am
back to work on the car tomorrow i am hoping to get alot done i would like to get it running soon
PostPosted: Mon Aug 11, 2014 6:01 pm
I Worked on the car today i might get it running next monday
PostPosted: Wed Aug 13, 2014 5:38 pm
I have found that 66 degrees BTDC is the one trigger wheels #1 tooth angle can any confirm this for stock location
PostPosted: Tue Aug 19, 2014 5:22 pm
I played with the car today and it spuderd but would not run i am going to check TDC #1 and go from there i also have a fuel leak i need to repair
PostPosted: Wed Aug 20, 2014 10:19 am
You have to be *very* close to getting it running! Keep at it! :-)
-=Frank=-
Image <- "The Twins" Image
PostPosted: Wed Aug 20, 2014 4:17 pm
thanks Katman I will have it running by the weekend I am not taking any work in Saturday and am going to get it running
PostPosted: Sat Aug 23, 2014 2:37 pm
video of it running on 6 cylinders due to 2 busted coils https://www.youtube.com/watch?v=mMqHBSR ... e=youtu.be the sound sucks but i am so happy to get it running
PostPosted: Sun Aug 24, 2014 2:10 am
Great progress :cheers:
PostPosted: Wed Aug 27, 2014 5:14 pm
thanks every 1 i am trying to get it out on the road by next week things seem to be coming along faster right now
PostPosted: Fri Aug 29, 2014 4:51 pm
any 1 have any tips on adjusting porsche boxster shift linkage
PostPosted: Sat Aug 30, 2014 1:32 pm
I took it out for a ride in the field today it's not running realy good though now it is time to start working on tunning it
PostPosted: Sun Aug 31, 2014 12:43 pm
I need some help guys i need the ohm values for the IAT sensor and the coolant temp sensor for a stock ABZ 4.2 V8 thanks
PostPosted: Mon Sep 01, 2014 9:31 am
Intresting no 1 on a Audi forum can even direct me to the info i seek on a IAT sensor resistance for the ABZ engine
PostPosted: Tue Sep 02, 2014 7:42 pm
Is this what you are looking for?
– Connect multimeter and check resistance across terminals on IAC valve.
Specified value: 7.0-11.0 Ω
Note
At room temperature the resistance is in the lower part of the specified range. At operating temperature the resistance is in the upper part of the range.
PostPosted: Wed Sep 03, 2014 8:24 am
thanks but i am looking for the Intake Air Temp sensor and how many ohms a certian temps so the ECU know how much fuel to give it as i am useing speed density
PostPosted: Wed Sep 03, 2014 8:57 pm
Are you trying to test it, or setup the range on the ecu?
York PA
Users browsing this forum: Yahoo [Bot] and 3 guests
  |  It is currently Sun Jun 25, 2017 12:17 pm
