Post new topic Reply to topic  [ 511 posts ] Go to page Previous  1 ... 14, 15, 16, 17, 18, 19, 20, 21  Next
ABZ Fiero
 Post subject: Re: ABZ Fiero
PostPosted: Mon Jan 18, 2016 5:30 pm
new hard top chassis that i am switching to so i have less flex pictures of the front that i just painted with poe-15
PostPosted: Thu Feb 04, 2016 5:53 pm
I am thinking of changing to the Vems ecu and has anyone made a cheat sheet for wiring up to the original harness for the ABZ V8
PostPosted: Fri Feb 12, 2016 3:08 am
I'd still with MS if you've got it working OK, don't think VEMS really adds anything in terms of capabilities.
I only went for VEMS on mine as Hilly (of Lotus Esprit fame) was able to supply me with a preconfigured unit and also the housing and connectors are a bit more robust than the MS. In terms of their ability to run the engine I very much doubt you would see any benefit in changing over. The one thing that made the biggest difference on mine was getting it properly mapped on a rolling road, it transformed the way it ran. IMHO, with the supercharger on it and the higher levels of boost on yours, there is just too much chance of destroying the engine trying to map it any other way.
PostPosted: Sat Feb 13, 2016 11:06 am
thanks for the input and i will take what you have said as good advice and more than likley not change from the MS but i still want to redo the harness and i would like to know what wire on each of the ecu plugs need to go where and wish there was a easy cheat sheet for this instead of having to look at the wiring diagram witch is a pain in the A$$
PostPosted: Mon Feb 15, 2016 5:51 am
I didn't use the Audi wiring diagram that much as it wasn't that easy to read. The way I went about it was to untape the engine loom so that I could actually see what wires went to each of the sensors/injectors that I needed, removed anything that wasn't needed and extended any wires that were too short (using wires from the loom off a spare engine so the colors were still right). I then went through it a wire at a time connecting up to the ECU using the ECU connector pinout drawings to work out where to connect to and the ECU reference diagrams for how to connect in the relays.
If you do decide to switch to VEMS it would be worth contacting Hilly. When he did mine he offered to supply a full kit including a loom, relays, fuses and instructions on how to hook it up (I ended up just getting the bare ECU without the loom from him though) - he may still be doing the looms?
PostPosted: Mon Feb 15, 2016 12:07 pm
wires have been cut even a few i dint want to cut opps :D
PostPosted: Fri Mar 25, 2016 9:59 am
I am at a bit of a dilemma i just pulled the GT in and looked at it and not sure of what i really want to do, do i put the engine in it or take it all apart and do the notch back it is less work to do the GT and it is in just as good a shape as the notch back but it has a bit of flex due to the T Tops so i would need to address that
PostPosted: Sat Mar 26, 2016 3:37 pm
well the engine & transaxle are now out and i will take the front end out to put in the notchie as i have decided to go with the notchie
PostPosted: Thu Apr 07, 2016 3:32 pm
the new engine is on the cradle with transmission installed
PostPosted: Fri Apr 08, 2016 12:41 pm
it looks right at home in the car
PostPosted: Fri Apr 08, 2016 2:36 pm
Sweet :D
PostPosted: Fri Apr 08, 2016 3:03 pm
thanks cant wait to hear it run and take it for a drive it should be intresting :D
PostPosted: Sat Apr 09, 2016 12:33 pm
worked on the wiring and i now have the injectors wired to the megasquirt i will wire up the ignition coils tomorrow
PostPosted: Tue Apr 12, 2016 4:58 pm
well working on the harness a little at a time it should come out good i am tring to make it look factory and that takes time
PostPosted: Thu Apr 14, 2016 6:16 pm
Have any of you tried Extreme tape it is rated to 500 degrees F and it has no glue and you heat it to get it to bond i am going to try it on the wiring harness i am hoping for good results
PostPosted: Fri Apr 15, 2016 4:15 am
Never heard of that before, but it sounds interesting :)
PostPosted: Fri Apr 15, 2016 7:30 pm
well i tried some of the tape and it work good i will finish putting the harness together and then use it . the only thing i dont like about it is you have to cut off a length of it to be able to wrap the wiring it is hard to use right off the roll but i will take pictures off the harness when done
PostPosted: Tue Apr 26, 2016 3:00 pm
well i am getting the wiring done just a little more to do
PostPosted: Thu Apr 28, 2016 3:30 pm
today i tested the megasquirt and wiring the only thing i have wrong is 2 wires on the tps just need to swap the ground and 5 volt positive and i need to run a injector and ignition test
PostPosted: Sun May 01, 2016 3:11 pm
well i fixed the 2 wires on the tps and the wiring is done and i put the exhaust on so now i just need to plumb up the fuel lines and coolant lines and vacuum line then add some oil and battery and start it up
PostPosted: Wed May 04, 2016 3:17 pm
A few new pictures of the wiring
PostPosted: Sun May 08, 2016 4:53 pm
I am getting really close to firing this up i should have it running some time this week i am getting excited about it now
PostPosted: Mon May 09, 2016 2:26 pm
Good stuff. Nearly there :thumbsup:
PostPosted: Fri May 13, 2016 7:48 pm
finished up on the wiring hoping to start it up this weekend
PostPosted: Sat May 14, 2016 10:36 am
it starts on starting fluid now i need to put fuel in it and plug in the fuel pumps and get it to run
Users browsing this forum: DE80q and 3 guests
  |  It is currently Wed Mar 29, 2017 5:46 pm
