Post new topic Reply to topic  [ 509 posts ] Go to page Previous  1 ... 17, 18, 19, 20, 21  Next
ABZ Fiero
 Post subject: Re: ABZ Fiero
PostPosted: Wed Dec 14, 2016 8:05 pm
now i am going to work on getting more belt wrap on the crank pulley and have a good idea on how to get much more wrap
PostPosted: Fri Dec 16, 2016 5:52 pm
today i had a few minutes so i started making a new belt adjuster and it just needs the adjusting slot
PostPosted: Sat Dec 17, 2016 2:32 pm
New belt tensioner pulley bracket the pulley has 2 places to bolt to for small pulley and the large 3 inch pulley . as you can see i didn't have a mill to make the adjustment slot so i dilled multiple holes then i cut and filed now i have great belt wrap and belt tension . funny thing that happened when running the car t sounded great but t dropped a few cylinders so now think hurt the engine so i start checking it out and it is popping so i keep checking thing and it ends up a ignition module that has gone bad so it was down 2 cylinders as it is a wasted spark system
PostPosted: Mon Dec 19, 2016 12:35 pm
Well with just getting better belt wrap i have gone from 3 psi of boost with a bad slipping belt to right around 10 psi and i think the belt is slipping just a little and i have found i needed to take some coil dwell time out so the ignition module wont over heat as it does in the video and drops a few cylinders at the end http://www.youtube.com/watch?v=wiexq2LdiFM" onclick="window.open(this.href);return false; after watching the video i see 11 pounds of boost and i think there is 2 to 3 pounds more boost once i get rd of the rest of the belt slip
PostPosted: Sun Dec 25, 2016 8:01 am
Merry Christmas
PostPosted: Sun Dec 25, 2016 1:07 pm
Likewise :)
PostPosted: Wed Dec 28, 2016 6:55 pm
I just keep on doing body work it seems like just spread body filler to sand most of it off
PostPosted: Thu Dec 29, 2016 6:22 am
Video says it's private :(
Sent from my SM-G930P using Tapatalk
PostPosted: Thu Dec 29, 2016 6:53 am
oops sorry about that i just went and fixed it now it is public
PostPosted: Thu Dec 29, 2016 2:38 pm
well have been dong research on the finishing of the body work with high build polyester primer then block sand to make it nice and straight then lay down some more primer wet sand then paint or wrap so lots more work ahead to make it right
PostPosted: Mon Jan 02, 2017 11:24 am
Yaaa the body filler work is done now i need to just sand the whole car with 220 then since i am trying to do a really nice paint job i am going to spray high build polyester primer then block sand with guide coat to get it as flat as i can then use regular primer sand and put down color . I must really get the floor swept up and all the dust off the car and i will wet the floor to keep the dust down when i spray the color and the clear
PostPosted: Mon Jan 02, 2017 5:24 pm
OK just want every one to know what i am thinking since i have red paint and red chrome vinyl i am going to paint the car and clear coat it if i don't like it i will wrap it but if I do like the way the paint job comes out i will give some one the vinyl
PostPosted: Tue Jan 03, 2017 4:07 pm
Today i put some spray can primer on the car to see how t is looking and i will say it is looking good
PostPosted: Wed Jan 04, 2017 11:30 am
It is coming along nicely. Good to see you removed the ribs in the side panels. You have a much cleaner look with out them. They were also a little dated.
Greg W.
PostPosted: Wed Jan 04, 2017 7:59 pm
yes taking the ribs out makes it look better plus they where a pain and in bad shape i am hoping to get it all into primer this weekend then block sand it next week
PostPosted: Mon Jan 09, 2017 4:14 pm
getting ready for primer
PostPosted: Mon Jan 16, 2017 7:19 pm
I have put some slick sand on the car and now am block sanding it but i needed 1 more quart as i didn't get every thing primed
PostPosted: Thu Jan 19, 2017 5:17 pm
well the car has come a long way from what i started with as i do some sanding i find small things every time i look so get the spot putty out and fix it and now i am finally feeling good about the body work not that i am great at it but that i finished it and gave it my best and i feel it looks good
PostPosted: Fri Jan 20, 2017 4:26 pm
today i had someone who said they would paint the car for me we would just swap work and at first i thought great then i got thinking maybe he wont do a good job as i have never seen his work and i don't want to waste my hard work for someone to do no better than can do or worse and there is the pride thing where i can say i did it all
PostPosted: Sun Jan 22, 2017 4:50 pm
it s all primed but i have a few things that need work like the top of the door has some pin holes that didn't fill and the front end need more massaging
PostPosted: Sun Jan 22, 2017 5:14 pm
your webhost is down
Laguna Seca B4 4.2 - The Smurfinator!
My turbocharger is a dog.
Your argument is invalid.
PostPosted: Mon Jan 23, 2017 5:43 pm
the next pictures you will see is this car panted Blaze red
PostPosted: Fri Jan 27, 2017 6:58 am
all sanded and ready for paint i will be painting this weekend
PostPosted: Fri Jan 27, 2017 2:37 pm
:thumbsup:
PostPosted: Fri Jan 27, 2017 8:12 pm
i got a good tip and it was to re-tape so i get rid of any sanding dust that was on the paper so i have done some of it and will finish saturday morning as i cant spray the car until the afternoon when every one is out of the building as my friend who rents me the shop has a parts store up front and closes at 1
  |  It is currently Wed Feb 22, 2017 3:49 am
