Post new topic Reply to topic  [ 540 posts ] Go to page Previous  1, 2, 3, 4, 5, 6 ... 22  Next
ABZ Fiero
 Post subject: Re: ABZ Fiero
PostPosted: Wed Sep 19, 2012 5:18 pm
Eh, they would need to put matching wheels and headlights on it! :)
Eric
Born4Rings is my little brother
:.: Vorsprung Durch Technik :.: Audi Quattro :.: The Unfair Advantage :.:
Good judgement comes from experience, and a lot of that comes from bad judgement. - Arthur Bishop "The Mechanic"
Dyed in the wool, washed in the blood : μολὼν λαβέ starting a collection
PostPosted: Thu Sep 20, 2012 3:03 pm
Well things are looking good for the new job just need to do the drug testing and background check and that shouldn't be a problem . I will get everything i need to do done then i think i will have EFI Express do the wiring since they do this kinda thing all the time and i want it done right the first time
PostPosted: Thu Oct 04, 2012 4:09 pm
Well i finally got my knuckles back from the machine shop now they accept Audi wheel bearings and wheel hubs so the axle issue is solved. I have ordered new fasteners through fastenall
PostPosted: Sat Oct 06, 2012 4:19 am
I see that in Europe they had the S8 in the 1990's and they made 340 hp so what was different about the engine?
PostPosted: Sat Oct 06, 2012 5:06 am
higher compression, 11.5:1
PostPosted: Sat Oct 06, 2012 9:13 am
Yes i see that it has higher compression but not even one full point more it must have some better cams to go along with the compression due to it's kinda hard for me to believe you would get 40 HP from less than one point of compression
PostPosted: Sat Oct 06, 2012 9:58 am
There is also the better tune they used on the ecu.
York PA
PostPosted: Sat Oct 06, 2012 10:37 am
Maybe so but the s8 functions and performs with s6 harness/ecu. Btdt
Also it has 11.5:1 where other 40v's hav 10 so its actually 1.5 difference.
PostPosted: Sat Oct 06, 2012 10:52 am
10:1 vs 11.5:1 makes for a quite large difference.
York PA
PostPosted: Sat Oct 06, 2012 5:59 pm
hmm i thought it was 10.8 for a A8 but since it is a 1.5 points difference yes that would explain. what has any one got for HP out of a 32 Valve 4.2 V8 with the 10 to1 compression with like headers , cams and intake or individual throttle bodies and still be streetable
PostPosted: Sun Oct 07, 2012 4:01 am
any one know what the intake port spacing is i am just wonder how close the Hayabusa throttle bodies are that i have they look really close and are about 3.125 inches center to center spacing
PostPosted: Sun Oct 07, 2012 7:26 am
The 32V S8 has much more valve lift than the others, to the extent that is has specially machined heads to clear the cam lobes and solid lifters on the inlet valves.
Nice work on the hubs btw. Did they already use a bolt-in bearing?
PostPosted: Sun Oct 07, 2012 7:53 am
yes they did use bolt on hub bearing assemblies
PostPosted: Mon Oct 08, 2012 8:40 am
Hi guy's i have looked at this car of mine and at some time would like to put turbos on this engine what size turbos and how much boost have you seen run on the street . the software that i used said a pair of Garrett gt25 300 hp versions for 12 psi of boost at 6600 rpm with a intercooler what are your thoughts?
PostPosted: Sun Oct 14, 2012 5:24 pm
well the fair weather garage is closing i am just trying to finish the rear suspension up so i can get the wheels on then i will wait for spring to finish it up
PostPosted: Mon Nov 05, 2012 9:10 am
dam it is starting to snow out i just want it to hold off for a few more weeks so i can buy what i need to make this a roller then i might be able to bring it over to a friends shop and work on it but i will need to be able to push it in and out of the shop.
PostPosted: Fri Nov 16, 2012 10:35 am
well i now have all the parts to finish the rear suspension but the hubs need to be re-drilled to 5 x100 bolt pattern
PostPosted: Fri Nov 16, 2012 2:59 pm
great project, will you be running vw mk4/tt wheels on the fiero with the 5x100 pattern?
____Bill_____
1986 VW Scirocco 16vt..9" hole in block
2000 Golf TDI 2.5" straightpiped
drz400e dualsport
1981vw Scirocco.g60turbo.192whp 222wtq.RIP.5.2.05 :(
PostPosted: Fri Nov 16, 2012 3:40 pm
If you're going 5x100 its worth noting that most 5x100 rotors will not fit on the 5x112 hubs. The diameter of the hub is larger than the inside mounting surface of the rotor. Iirc the centre bore is also different.
Unless you turn down the hubs to suit, you may have to run re-drilled 5x112 rotors.
Just thought I'd mention it in case it turns out to be important :cheers:
PostPosted: Fri Nov 16, 2012 10:18 pm
ya i need to get the hubs machined to work with my Fiero rotors. i will have them turned down on a lathe then it will be all good.
PostPosted: Fri Nov 23, 2012 3:12 pm
well went out today and put the rear suspension back together with out the hubs due to i have not brought them to the machine shop yet but i will do that Monday .
PostPosted: Sun Feb 03, 2013 6:42 pm
well the hubs are all done just need to put them on and get some money up for the Vems
PostPosted: Sun Feb 03, 2013 6:48 pm
Jeez, back from the dead. Im glad to hear this is going to move forward. Should be interesting to see if finalized!
York PA
PostPosted: Mon Feb 04, 2013 5:01 pm
ya its kinda cold to work on it outside right now but it will get done sooner or later
PostPosted: Thu Mar 21, 2013 5:18 pm
I have a question with some of the the GM ECU like a 7730 can be made to run many different GM engine is there one from Bosch Motronic that can do that
Users browsing this forum: Bing [Bot] and 4 guests
  |  It is currently Sun Jun 25, 2017 12:13 pm
