Post new topic Reply to topic  [ 526 posts ] Go to page Previous  1, 2, 3, 4, 5, 6, 7 ... 22  Next
ABZ Fiero
 Post subject: Re: ABZ Fiero
PostPosted: Sun Apr 21, 2013 1:14 pm
Hi every one how you doing i have a ? can some one tell me what tooth on the trigger wheel is TDC
PostPosted: Sat May 25, 2013 5:24 pm
well it is time to start working on this again so i have bought a Porsche boxster shifter to go along with all the other Porsche linkage parts to make it shift, the funny thing is the boxster ,VW's and Audis all used this 012 transaxle but the ones that come out of a Porsche or so they say they want $1000 for
PostPosted: Sun May 26, 2013 12:18 am
Hi,
have you found tooth on trigger wheel?
I too swop ABZ and was stuck on the flywheel.
viewtopic.php?f=10&t=52155&view=unread#unread
sorry for my english, I am Russian
PostPosted: Sun May 26, 2013 8:22 am
I am using the stock automatic flexplate with trigger wheel and the 034 motor sport flywheel insert
PostPosted: Sun May 26, 2013 11:32 am
Have you already placed the sensor?
Сould you please count the number of teeth?
PostPosted: Sun May 26, 2013 7:35 pm
it is in the trans bellhousing in its stock location that it was from the VW passat that it came out of
PostPosted: Fri May 31, 2013 4:51 pm
Boxster shifter and new cable end due to the cable end was no good
PostPosted: Fri May 31, 2013 4:55 pm
I see this car everyday on my way to work, I'll stop in one of these days if i see you out there.
2003 TDI wagon, 63 356C, 71 NSU1200C, 1966 Dodge A100, 74 CJ5 plow jeep, tractors and junk.
PostPosted: Fri May 31, 2013 5:17 pm
ya right now i am working on the boat so i can sell it so i can buy parts for the car and next week i should be working on the house out side so there will be a good chance i will be out there so stop and say hi and i will show you what i have done
PostPosted: Sat Jul 06, 2013 9:18 pm
?what is the stock crank position sensor that is found in a 2000 vw passat as this is what the transaxle came from are they VR i need to know since i am going with the megasquirt due to i don't have the money for the vems like i want infarct i am building the megasquirt and this is one of the things i need to know thanks guys
PostPosted: Sun Jul 07, 2013 3:26 am
Yes it is a VR sensor :thumbsup:
PostPosted: Sun Jul 07, 2013 7:33 pm
thanks
PostPosted: Thu Jul 18, 2013 6:00 pm
OK now i am looking at if i use 5v or 12v pull down for the coils wired for wasted spark on the ms 2 i hope some 1 ca help with this
PostPosted: Thu Jul 18, 2013 6:36 pm
12V
VW '79 Scirocco Rotrex 16V
Chumpcar
PostPosted: Tue Jul 30, 2013 7:26 pm
the Megasquirt is built now i just need to do the wiring
PostPosted: Thu Aug 29, 2013 12:39 pm
Ok i am now starting to do wiring and wondering if any of you can tell me what wires are what on the engine or i suppose i can trace each wire since i can get rid of all that i dont need
PostPosted: Wed Sep 25, 2013 4:12 am
I have all most have the wiring aal done now i just need to work on it for and put the plug ends on
PostPosted: Fri Oct 11, 2013 10:28 am
Ok i am looking for some help with wiring the sensors i need to know what wires are what on the Audi plugs like the TPS plug what wire is the signal & 5V referance and ground plug what wire is the signal wire on the idle valve plug thanks for all the help you give me
PostPosted: Fri Oct 11, 2013 10:50 am
Wiring diagram here for you: http://www.corradov8.com/pics/ABZ%204.2V8%20Wiring.pdf
:cheers:
PostPosted: Fri Oct 11, 2013 4:40 pm
the wiring diagram is nice but i still dont know what wires are ground or signal or 5v referance and all i am doing is puttting the plug ends on a megasquirt harness and that wiring diagram shows where the wire go but not what each wire does
PostPosted: Wed Oct 16, 2013 1:27 pm
I'm using VEMS rather than MS but I'm guessing the wiring will be very similar so
Throttle pot:
+5V : black/white (the thin wire, there is another thicker black/white wire in the standard loom that is a coil pack supply so make sure you get the right one)
GND : black/brown
signal : blue/brown
Idle Valve:
fused supply : brown/red
earth via ECU (this may be different on MS!) : brown/blue
Great project BTW
PostPosted: Fri Oct 18, 2013 2:49 pm
thanks for the info and i am starting to understand that wiring diagram
PostPosted: Fri Oct 18, 2013 6:48 pm
good project, just sat and read it all, keep it up
PostPosted: Fri Oct 18, 2013 8:47 pm
I'm watching this because Im basically doing the same thing...and I have no clue as to where to start when wiring my ECU.
Well, it's not really a fake. It's just not authentic.
PostPosted: Sat Oct 19, 2013 9:56 am
not to much left to solder what needs doing is Crank Postion Sensor,Temp Sensor,Knock Sensor & Idle Valve
  |  It is currently Sun May 28, 2017 8:47 pm
