Post new topic Reply to topic  [ 21 posts ]
New guy, old car. Big power
 Post subject: New guy, old car. Big power
PostPosted: Sat Feb 13, 2016 2:12 pm
So I was recommended to come here by a previous owner of my car. Some history as I know it.
I bought this car a week ago. I bought it with it not running but it had a solid body. When turning over, I heard the unmistakable clunk of a rod issue. So I bought it for $1200 and got it loaded up on the trailer.
I have a WH1C for it to be put on. I'm looking for people's experience in which rods and pistons I need to build a reliable bottom end for 1000hp. The Holset is to tide me over till I get a 400 framed Borg.
I see some I-beams but I don't know which to buy.
Whose pistons are best for this? Stock rings or something better?
I'm assuming stock rod bearings will be fine unless you guys know otherwise.
I'm coming from the Cummins world where evening is ok up to 800hp then it's a rod change with modified stock pistons.
Thanks everyone.
Also, any good build threads to read?
 Post subject: Re: New guy, old car. Big power
PostPosted: Sat Feb 13, 2016 3:57 pm
1000hp is a lofty goal.
You'll need gear box love, engine love, and well a fat wallet.
Rods, pistons, arp hardware, headwork, 01E swap, etc
I am not going to keep a list of what I have here, it changes often.
PostPosted: Sat Feb 13, 2016 5:56 pm
I'm not above lowering the goal but I want the bottom end to be built once. I don't want to put it together and then later have to tear it apart for anything other than a refresh.
PostPosted: Sun Feb 14, 2016 9:41 am
Ok, Why not 07k Swap? Iroz is doing some great things with the newer Audi motor. The head flows much better. http://www.irozmotorsport.com/
And I am subscribing to this one...
1995.5 URS6 Avant Not Stock
1991 Audi 200 20VT SOLD
1985 k20 Suburban with a Muncie 4 spd
1930 Model A Roadster...in pieces
1953 Buick Special (sold)
1951 Chevy 3100 (sold)
PostPosted: Sun Feb 14, 2016 11:39 am
Location: Norton Shores, Mi. My cat has human-like reflexes
and coming from the cummins world you may not be happy with the powerband of a 1000hp 2.2ish.....just a wild guess on that though.
7a head/milled mc2 bottom w/holset Hx35...500hp for $500?
viewtopic.php?t=6726
PostPosted: Sun Feb 14, 2016 12:15 pm
A 1000hp Cummins is peaky. You usually only have maybe 1200rpm of power.
Doing a lot of reading, I'm lowering the goal to 600hp for now.
PostPosted: Sun Feb 14, 2016 1:22 pm
Even up to 1000hp all you need is rods, and to get your stock pistons coated.
and obviously all new bearings while youre in there, these motors need a ton of head work though.
At that power level its more about little details in block preparation and assembly than it is just components.
for 600hp IE H-beam rods are a good option, EFI express sells rifle drilled I-beams for a bit more though.
1990 Coupe quattro - AAN swap (o7k inprogress)
2007 RS4 APR1320 Supercharged
1991 90q Tornado Red 3B swapped - The hoopty - Sold back
2007 S4 Brilliant black 6 spd - SOLD
2001 A4 2.8L laser red 5 spd - SOLD
PostPosted: Sun Feb 14, 2016 1:30 pm
Got a link or dyno slip to substantiate this? :roll: What fuel?
Plenty many examples of failures around the 550hp range on stock forged pistons due to ring land failure.
1992 80 quattro 20v /// Eventual AAN'd Winter Sled
1990 Coupe quattro /// Because Racecar
PostPosted: Sun Feb 14, 2016 3:51 pm
What are you going to do about the paint job? :hide:
MRD
'84 VW GTI, crashed it
'84 VW Jetta turbo desil, sold it
'95 VW Golf, gave it to the brother
'87 5ktq, sold it
'95 S6 Avant, sold it
'01 Toyota 4Runner, current DD
'84 cgt-project car
PostPosted: Sun Feb 14, 2016 7:26 pm
:D don't say primer black....don't say primer black...
PostPosted: Sun Feb 14, 2016 7:58 pm
A good wash, buff, and polish. Gotta be unique here. :D
PostPosted: Mon Feb 15, 2016 7:12 am
Nice pick up man. I was eyeballing that for a while. I'm just across the lake in SW Michigan. I know a few people have run scat rod with good luck. I've had really good experiences with Integrated Engineering. I would spring for the extra rifle drilling too. Throw in a 7A cam in when the heads off with some studs, coat the pistons, water/meth or e85 and see where your at. Sounds like your goals are pretty close to what I was hoping for too.
p.s. build threads
viewtopic.php?f=6&t=51102" onclick="window.open(this.href);return false; (check the turbo out on page 2)
viewtopic.php?f=6&t=38644" onclick="window.open(this.href);return false;
Hope to see it around and running soon! :cheers:
PostPosted: Mon Feb 15, 2016 8:20 am
That turbo in Zachs thread is a WH1C.
PostPosted: Mon Feb 15, 2016 8:59 am
Yea. If you could get a hold of him, he might be good to bounce ideas off of, or possibly if he has any words of guidance of things he ran into or what he did, that could help out too. :thumbsup:
PostPosted: Mon Feb 15, 2016 10:01 am
hank had ringland failure at over 625 awhp, which is probably around ~750chp
//Dave
'95 S6 Avant '04 A4 Avant '95 90 quattro
PostPosted: Mon Feb 15, 2016 11:38 am
625 is too close to 600 for me.
PostPosted: Mon Feb 15, 2016 12:05 pm
For that kind of goal and already needing to replace the engine 07K seems like a no-brainer. Get Hank to build you an 07K with an EFR.
John Anderson
91 200 20V - not stock
01 S8 - stock
97 GMC Sonoma - 436rwhp
97 Grand Prix GTP
84 928S - 270rwhp
73 MGB
PostPosted: Mon Feb 15, 2016 6:06 pm
Appears to be IL plates in the background. Chicagoland was my old stomping ground.
PostPosted: Sat Feb 20, 2016 6:39 am
I bought it in Chicago and I live 2 hours west.
I-beam vs H-beam rods... Last decision I need to make before purchasing.
PostPosted: Sun Jan 08, 2017 9:01 am
what did you decide? I think John is right the 07K is a better option nowadays for a 5 cyl build
08 Audi S4 (parting out)
PostPosted: Sat Jan 21, 2017 5:49 am
I-beams for sure. Stronger design
  |  It is currently Mon Feb 27, 2017 10:41 pm
