Post new topic Reply to topic  [ 394 posts ] Go to page Previous  1 ... 12, 13, 14, 15, 16
85 URQ Joins
 Post subject: Re: 85 URQ Joins
PostPosted: Thu Aug 04, 2016 2:24 pm
Not had much time to work on the car lately what with work and domestic activities but here's a little video Winding Road did of the car a few years ago as motivation for us and a teaser for you. Soon be doing this again.
https://www.youtube.com/watch?v=UCaySv1Blok
[video] https://www.youtube.com/watch?v=UCaySv1Blok[/video]
<iframe width="560" height="315" src="https://www.youtube.com/embed/UCaySv1Blok" frameborder="0" allowfullscreen></iframe>
Paul Eddleston
TIM Team Illuminata Motorsport
http://www.teamilluminata.com
PostPosted: Sun Aug 21, 2016 11:36 am
When we left you we were trying to figure out where the little spring went in the distributor and contemplating reinstalling the ignition system. Well, just prior to our trip to Pebble Beach for the car events and elsewhere we did just that:
We pulled the distributor from our 83 and it turns out it goes right here:
Imageimage by Team Illuminata Motorsport, on Flickr
So we popped it in, reassembled the distributor and installed it on the engine. Timimg was still set so it was a doddle to line up at TDC.
Then we turned our attention to the spark plug wires. The car is supposed to have a plastic tube to carry and support the wires but ours never had one. Fortunately we had picked up one in a parts haul a while back and now seemed the time to install it. This meant pulling the ends of each lead and pushing through it's a appropriate hole then reattaching the end. We used our old leads after testing them as the spare ones we showed you earlier proved not to be compatible.
The carrier is attached to the valve cover screws with two plastic-clad metal brackets. We didn't have these and they are NLA but a trip to the hardware store produced something almost identical so we went with those.
So now we have an ignition system:
This week, schedule permitting, we'll start on the fuel inject system. Almost done!
Paul Eddleston
PostPosted: Tue Aug 30, 2016 9:54 am
YAY. Our pictures are back!
We had all our early pictures hosted on some servers that went away. Now we have them hosted more securely and have replaced all the broken links. As a bonus you can also see full size images for this and all our other builds here: https://www.flickr.com/photos/team_illuminata/albums
Paul Eddleston
PostPosted: Fri Sep 02, 2016 3:24 pm
Feels like we are very close. Also feels like winter is approaching. Better get cracking.
Started cleaning the fuel injection system. Decided not to dismantle it and just leave well alone.
Air filter housing:
New injectors and seals
Battery!
Paul Eddleston
PostPosted: Sun Sep 04, 2016 2:58 pm
On a roll now :)
Jumped the fuel pump relay to drain some old fuel.
New filter
Had to come up with a way to mount this thingy-me-jig as the mounting tabs were long gone.
Turbo inlet. Tight down there.
and fuel distributor
Our parts shelf is look quite bare now.
Paul Eddleston
PostPosted: Sat Sep 10, 2016 10:56 am
Today's progress. Hopefully not this weekend's progress.
Connected the fuel lines to the warm up regulator.
New fuel filters:
There really isn't much left to do. At least to get it running:
CRANK BOLT
THROTTLE BODY
WIRING ISSUES
SPARK PLUGS
TRANS FLUID
Then once it works:
COOLANT
REAR BRAKE LINE
BLEED BRAKES, CLUTCH
PS STEERING FLUID
WIPERS
BUMPER
HEADLIGHT
INJECTOR BLOWER
TIGHTEN CONTROL ARMS
ADJUST SHIFT LINKAGE
ALIGNMENT
DETAIL
Then we put it away for the winter.
Paul Eddleston
PostPosted: Sat Sep 10, 2016 9:49 pm
Get er' done!
Sent from my XT1254 using Tapatalk
81' Rally Quattro,
88' Peugeot 205 GTI,
91' Lancia Delta Integrale 16v,
2015 RAM 1500 ecodiesel Quattro support vehicleImage
PostPosted: Wed Sep 21, 2016 10:39 am
So, assembly continues as we edge nearer to the momentous day when it drives itself off the hoist, hopefully down the road and not into winter storage.
Got the throttle body cleaned, adjusted and back on.
Then had to fix the inlet air temperature sensor.
Fortunately our 83 has one that looks like it was a replacement once. Ohms check check out too.
A bit of electrical shenanigans and it's in.
Then there was nothing left to do but call my Audi expert, Werner then fire it up!
https://www.youtube.com/attribution_link?a=NyeANWMZo7U&u=/watch%3Fv%3D_4JomNrdCRo%26feature%3Dem-upload_owner
<iframe width="560" height="315" src="https://www.youtube.com/embed/_4JomNrdCRo" frameborder="0" allowfullscreen></iframe>
Doesn't idle yet and still needs coolant but we had a little celebration anyway.
Paul Eddleston
PostPosted: Fri Sep 30, 2016 12:38 pm
As this project is sort of wrapping up we started another one we thought you might like. Introducing the Audi UR Quattro Rally Build http://www.motorgeek.com/viewtopic.php?f=6&t=151922
Imagetransformation by Team Illuminata Motorsport, on Flickr
Paul Eddleston
PostPosted: Sun Oct 09, 2016 8:51 am
So, a lot of work but not a lot of updates. Here's why.
Bled the brakes.
Reinstalled the grill and the bumper.
and put it back on all fours for the first time in years.
Then got it to idle and run quiet.
https://youtu.be/4aqI0iT-wP8
<iframe width="560" height="315" src="https://www.youtube.com/embed/4aqI0iT-wP8" frameborder="0" allowfullscreen></iframe>
Then drove it off the lift.
https://youtu.be/Qp0ASTHZ-V8
<iframe width="560" height="315" src="https://www.youtube.com/embed/Qp0ASTHZ-V8" frameborder="0" allowfullscreen></iframe>
Then took it for a drive.
https://youtu.be/ypoHY6EsoyQ
<iframe width="560" height="315" src="https://www.youtube.com/embed/ypoHY6EsoyQ" frameborder="0" allowfullscreen></iframe>
Then stood back and admired it
https://youtu.be/FfhyveNAIPI
<iframe width="560" height="315" src="https://www.youtube.com/embed/FfhyveNAIPI" frameborder="0" allowfullscreen></iframe>
Happy birthday to me!
Paul Eddleston
PostPosted: Mon Oct 10, 2016 7:36 am
Looks great!! Well done.
Martin Pajak
www.quattro.ca
82 4000 2-door
83 80 q - Euro 2-door!!
85 Ur-q - Euro with 3B
86 4000 quattro with 59,000km on the clock
86 5000CD quattro avant, all original
91 CQ winter sled
93 90q - 2.5TDI, 6-speed
94 S2 Avant, stock
PostPosted: Mon Oct 10, 2016 9:23 pm
nice
They can have my car when they pry my cold dead fingers from the steering wheel.
PostPosted: Mon Oct 24, 2016 7:31 pm
Sorry about the lack of updates. Got distracted by some work related events not the least of which was attending LSPR with our 911 and other assorted old rally cars.
Image14695439_1305247436187424_7489908328833138150_n by Team Illuminata Motorsport, on Flickr
Since I got back I haven't worked on the car but taken every opportunity I could to drive it. This included a funeral, a couple of cars and coffee events, an open house and running to Autozone for parts for our ailing Allroad.
I'd forgotten how much I enjoy driving this car and how much attention it gets. I'm going to try to enjoy it as much as possible before it goes away for the winter. It drives very well, is smooth and quiet but does have a slight hesitation under load though it pulls strong. I can figure that out and put the remaining few parts back on this winter. For now LET"S DRIVE!
Paul Eddleston
PostPosted: Tue Oct 25, 2016 6:20 pm
What's up with the brown, Pinto look'n car behind the URQ?? It's got something poking out of the engine hood.
MRD
'84 VW GTI, crashed it
'84 VW Jetta turbo desil, sold it
'95 VW Golf, gave it to the brother
'87 5ktq, sold it
'95 S6 Avant, sold it
'01 Toyota 4Runner, current DD
'84 cgt-project car
PostPosted: Wed Oct 26, 2016 5:48 am
No idea. It's a Detroit thing.
Paul Eddleston
PostPosted: Thu Oct 27, 2016 11:27 am
I believe it is a Chevette with probably a small block. Kinda of like this:
Greg W.
PostPosted: Thu Nov 03, 2016 1:16 pm
Been looking for opportunities to show of the car and have some fun with it before we run out of season.
The demise of our A3 left us with some 17" BRAID Fullrace A wheels and 225 tires lying around and with the help of the spacers that our ALLROAD doesn't need with it's winter wheels it soon became obvious what we must do. Throw them on the quattro!
This is only for fun mind you. They are a little contemporary and the 225/45-17 tires are about an inch to tall but it was well received in this state at our local meet Saturday.
You can feel the extra weight and diameter when driving and there is s slight rub somewhere on full lock but they are about the same diameter as the package we are planning to use on our 83 build so worth the trouble. 15" BRAIDs go back on soon.
The car is starting to srtuggle to start again now. Runs great once warmed up exept for a slight hesitation around 4000 rpm. Maybe the cold start valve? It is also pissing out hydraulic fluid still. We replaced everything around the bomb except the pressure switches so we suspect those. New ones are on the way.
We have also been tidying up the mess we gad left over from the project. This consists of mostly parts that need to go into boxes and parts that still need to go on the car.Tok care of inventorying and boxing parts and installed the plastic underbody stuff.
So just the cruise control actuator and injector blower to reinstall when we get chance. Holding off for now until we diagnose the starting issue though.
Paul Eddleston
PostPosted: Fri Nov 04, 2016 7:10 pm
I like the wheels.
Greg W.
PostPosted: Wed Feb 15, 2017 4:45 pm
It's been winter for too long already so no driving the 85. No working on it either as our 83 rally build and wheel sales have been keeping us busy. We have been picking away at the hydraulic system leaks however. We easily sourced some new pressure switches for the hydraulic bomb and quickly replaced the one on the side. However we did manage to disconnect a wire in the process.
The one underneath was a different prospect requiring us to access it from below. This, of course, took many, many weeks to get round to until recently when we finally drove it onto some ramps in the showroom.
where it sat for another couple of weeks till we had time to crawl under it. It soon became anther classic Audi "unscrew the simplest thing, if you can" project until we found just the right 24mm deep socket to get the switch off. At first we tried loosening the bomb from it's moorings but you cant undue these two nuts even though you can see them:
Finally found a thin wall socket that fit.
This still left the wiring issue to fix.
Think this is where it came from.
This puppy cost $35! Well, it was free, but we had to buy $35 worth of zip ties to liberate it from the box of 100 we were supposed to buy.
Soon had it on and back on the switch.
Of course we can't tell if it's solved the leaks till we drive it and it's still too salty outside. Never mind, now we can fix the leaky rear diff. However, this involves putting it on the lift and you now how long it took to get it off there last time! Wish us luck.
Paul Eddleston
Users browsing this forum: Bing [Bot] and 1 guest
  |  It is currently Fri Feb 24, 2017 7:48 am
