Post new topic Reply to topic  [ 134 posts ] Go to page Previous  1, 2, 3, 4, 5, 6
3B Swap Hy35 Vems (5 lug conversion!)
 Post subject: Re: 3B Swap Hy35 Vems (5 lug conversion!)
PostPosted: Tue Apr 18, 2017 6:19 am
Online
car looks great man, I like those wheels on the b3, gives it the meat it should have had from the start. How are you likeing the hy35? I really loved the power delivery from it on my car.
Dana
-4kq efi'd 10vt
-1990 90q 20vt: 3b swap
-1990 90q 20vt: 11.7 @124.5
PostPosted: Tue Apr 18, 2017 6:29 am
Very nice work on the 5 lug swap! Now I don't have to search to find the info!
As for the intercooler, it looks to be the same one most of us cram behind the US spec bumper. 27"x7"x2.5". To get it to fit with the fog lights, I welded on a pair of shortened cast tight 90°s.
PostPosted: Tue Apr 18, 2017 8:13 am
The hy is awsome. It sounds unreal especially running it without a bov or bpv. There is more lag compared to the k24 but It's overall more fun to drive.
The only downside to this 5 lug set up is having to redrill rotors every time you get new ones. Also when I do get larger calipers in the future I can't just use the rs2 brackets I'll have to get custom ones made. But for the price you can't beat it, I think I paid more for tires than all the parts for the swap.
PostPosted: Tue Apr 18, 2017 8:29 am
Online
what kind of boost are you running? I suggest you work it up towards 30psi ASAP :D
Dana
-4kq efi'd 10vt
PostPosted: Tue Apr 18, 2017 8:39 am
I still have distributor ignition, stock bottom end, and no way to tune the ignition map on vems safely at the moment. I'm only doing 15psi right now out of fear of messing anything up.
PostPosted: Sun Apr 23, 2017 7:02 pm
Few things painted. Here are a couple well lit engine bay shots.
PostPosted: Mon Apr 24, 2017 4:53 am
Nice and clean! but is that brace strong enough to support the way of the turbo without much flexing or what is that holding?
08 Audi S4 (parting out)
PostPosted: Mon Apr 24, 2017 5:05 am
There is a third arm that's welded to the underside of the triangular plate. It bolts to the aluminum engine mount arm. Very solid.
PostPosted: Tue Apr 25, 2017 4:23 am
cool design! at least from the last photo I can see it better that i will serve its purpose for sure
Users browsing this forum: No registered users and 6 guests
  |  It is currently Wed Apr 26, 2017 4:51 am
