motorgeek.com :: Board index :: The Tech Lounge :: Drivelines
How far out does 01E shaft protrude???
 Post subject: How far out does 01E shaft protrude???
PostPosted: Mon Oct 31, 2016 2:47 pm
...past the edge of the bell housing (no spacer)??? Or is it flush or recessed?
Thanks!
Laguna Seca B4 4.2 - The Smurfinator!
Buy the Smurfinator (BLAUDI): viewtopic.php?f=4&t=207618
 Post subject: Re: How far out does 01E shaft protrude???
PostPosted: Mon Oct 31, 2016 6:20 pm
It's recessed by about 10mm. I just eyballed it so don't consider that number accurate to 0.001". But probably within a couple of millimeters.
Be alert! America needs more lerts.
Eric Law
'90 80Q with AAN and Megasquirt
'97 Saab 9000 Aero: mostly stock but ECU tweaks to add fastness
'86 4KTQ: R.I.P.
PostPosted: Tue Nov 01, 2016 1:02 pm
Cool thanks! I'm trying to see if it's the same as the 01A and it looks like it is. 01A shaft is ~8mm inside the bellhousing.
PostPosted: Tue Nov 01, 2016 1:14 pm
I'd think it would be... as far as mating to the engine/clutch go, I think 01A and 01E are supposed to be interchangeable. It's the stuff like shift linkages and driveshafts (and mounts?) that get interesting...
Eric Law
'86 4KTQ: R.I.P.
PostPosted: Tue Nov 01, 2016 3:17 pm
Yes they are ^ The bellhousing of the 01E is slightly larger inside, but the geometry is exactly the same.
Racecar: noun - a hole in the road in to which money is poured
PostPosted: Sun Jun 18, 2017 6:23 am
It depends on the 01E, some have deeper bellhousings.
The Scottmeister
"With great power comes horrible fuel economy"
www.advancedautomotion.com
PostPosted: Sun Jun 18, 2017 1:31 pm
Is that why some need spacers, and others don't?
1992 80 quattro 20v /// Eventual AAN'd Winter Sled
1990 Coupe quattro /// Because Racecar
  |  It is currently Mon Jun 26, 2017 7:02 pm
