Post new topic Reply to topic  [ 65 posts ] Go to page Previous  1, 2, 3  Next
1984 Audi 4000 quattro Chevy 350 conversion 889 hp na !!!
 Post subject: Re: 1984 Audi 4000 quattro Chevy 350 conversion 889 hp na !!
PostPosted: Tue Mar 05, 2013 12:19 pm
I'd love to see it as well. If I had an 889hp V8 laying around, a 4kq would not be my first thought. It will be a great sleeper, but the thought of what it will take to make the drivetrain and chassis stand up to that power so you can actually use it is another thing.
I have noticed NASCAR shop leftover parts are pretty cheap. Bought some myself... It would be a blast to see what you could build.
PostPosted: Tue Mar 05, 2013 1:31 pm
Streetable pump gas n/a 350's don't exist.
PostPosted: Tue Mar 05, 2013 1:58 pm
Thanks Timmmy for the inspiration.We are not
going to move the engine back we are building
a fiberglass tilt nose front end that will take care
of front end problem with the engine.And we are
not using no Nascar engine that's no fun if you didn't
build it yourself.
PostPosted: Tue Mar 05, 2013 2:06 pm
Innovating outside of the box!
PostPosted: Tue Mar 05, 2013 2:45 pm
blow me
Location: physically: NH, Mentally: A different planet!
build it yourself.
My pleasure,
I am excited to see how your project turns out. Please keep this thread up to date with lots of pictures :)
If there is anything I can do to help in terms of BTDT advice feel free to PM me or ask in your thread.
Take the disbelief with a grain of salt, this forum, as you probably know, tends to be a 'no bullshit' type of a place i.e. you'd better be able to prove it if you say it :)
Timmmy.
"Where the hell did all these worms come from?....what can?....oh yeah that can that I forced open earlier"
www.motorsport-HT.com
http://www.facebook.com/pages/HT-Motorsport/130495587028564
PostPosted: Tue Mar 05, 2013 4:51 pm
sounds like yall are using one of them 100 mile per gallon carburetors. Too bad they only work on coleman white gas or toluene.
Laguna Seca B4 4.2 - The Smurfinator!
My turbocharger is a dog.
Your argument is invalid.
PostPosted: Tue Mar 05, 2013 4:58 pm
audifreakjim wrote:
I have a co-worker that used to live by the big race shops in NC, he said you would see the most bizarre sleeper cars with old race motors swapped in.
I want to see this happen, who cares if it's 600hp or 889hp, it will be a riot in a 4k!
Totally agree... But when someone comes in making grandiose plans to make ridiculous hp with some special unheard of air/fuel homogenizer and no EFI... I need to start asking questions.
XLR8
2003 540i/6 M-Tech #1090/1265 Spring/Summer/Fall
2001 330Cic/A Fiance-mobile
1991 200 20v Winter/Utility
PostPosted: Tue Mar 05, 2013 7:59 pm
A good citizen does not ask questions.
Ignorance is strength.
PostPosted: Thu Mar 07, 2013 1:32 pm
It's about time someone else did this. Best of luck - you'll need to go dry-sump, or drop-channel the subframe to clearance the oil-pan - BTDT on the LT-1Q but it wasn't a huge deal. Watch out for the pilot bearing adapter ring from KEP - the one he made me years back was .007 out of round and that was enough to cause an input shaft wobble that would dump all tranny fluid onto the clutch. Otherwise you're going to have lots of fun once you get the teething pains sorted.
LT-1Q is still running around under the care and feeding of the person who bought it from me (the builder). He's had to do a lot to keep it together all these years as the torque does an admirable job of tearing apart the unibody spot-welds in the front-end. I would recommend you do lots of tube-steel structure improvement before that engine is in there to save yourself problems later. Cooling was easy using a pair of Passat radiators sitting side-saddle in the engine bay. With a typ-85 you are on the right track to put it in the trunk I figure.
Have fun!
Rob Dupree
2013 Audi S4
2007 VW Touareg V10 TDI
1995.5 Audi UrS6
1994 Audi 90q
PostPosted: Fri Mar 08, 2013 12:36 pm
Thanks RalleyDogRacing for the input.We are using a
dry-sump system.That homogenizer patent is cool
but that not what we are doing.You see the reason
that streetable 889 hp carb engines don't existed is
because the technology until now.The reason to use
a carb instead of efi easyer to work with but it works
with efi.We have 11 years of R&D in this.If you wanted
to make more hp you need a turbocharger,supercharger
or nitro to create a bigger explosion in the chamber by
forcing more fuel and air into the engine.But if you could
create the same end result with out forced induction then
you can create 889 hp.I know what you are say "prove it".
We are going to show to you.We will start taking pre-orders
on april 7, 2013 and shipping May 1,2013.The reason we are
using a audi 4000 is awd is cool and it should have come with
a V8.When the website goes up it will explain it all.If you can't
wait for the website.Pm me for a phone presentation or come
to a live presentation in may in Raleigh NC.
PostPosted: Fri Mar 08, 2013 1:26 pm
Location: Norton Shores, Mi. My cat has human-like reflexes
Oh, that is why I don't see 889 hp carbed engines. I was wondering what the problem was.
I think if you have an explosion in your chamber that is detonation. I think you want a burn. : )
7a head/milled mc2 bottom w/holset Hx35...500hp for $500?
viewtopic.php?t=6726
PostPosted: Fri Mar 08, 2013 1:58 pm
Technically, explosions need not be detonation. They can be either deflagration (subsonic flame front, as in a normal ICE) or detonation (supersonic flame front/pressure wave).
The Projects: eS2 Coupe /// ur quattro /// urS4 /// Diesel Vanagon
PostPosted: Fri Mar 08, 2013 3:32 pm
Oh, I get it. It's a scam to get people to send you money.
Nice try, but motorgeekers are smarter than Joe Mustang. Couple of 'em, anyway.
You'll have to find a more honest way to come up with child support payments.,
PostPosted: Fri Mar 08, 2013 10:02 pm
A little hint - anytime somebody says they are going to set the automotive world on fire, and it involves them putting this "gem" in a 25 year old audi to demonstrate, you need to really question it. I mean, other than the few of us, the rest of the world would really fail to appreciate it....and unless all of this can be purchased for like $150 or less, MG may not be place to display the wares.
PostPosted: Fri Mar 08, 2013 10:42 pm
3 easy payments of $49.95, call today! Limited time only!!!
PostPosted: Sat Mar 09, 2013 8:45 am
Could not have said it better.
PostPosted: Sat Mar 09, 2013 8:48 am
I will have some pictures of some 960hp n/a motors today.
If they will let me video the dyno pulls I will.
 Post subject: 1984 Audi 4000 quattro Chevy 350 conversion 889 hp na !!!
PostPosted: Sat Mar 09, 2013 8:59 am
blow me
Excellent, I want to see that.
PostPosted: Mon Mar 11, 2013 8:05 am
4rm,
What's the maximum VE of your engine?
Max RPM?
minimum BSFC?
Cheers, Brady
83 urq, 034 IIc'ed..[][] oooo [][] 150whp
86 4kq, MS'n'S'ed.......O O oooo O O 80whp
91 200qa20v,.......[++] oooo [++] 166whp
72 240Z 123whp
www.dynodoc.ca
PostPosted: Mon Mar 11, 2013 2:10 pm
:lol:
PostPosted: Mon Mar 11, 2013 4:23 pm
Got some cool pictures. Need to figure out how to add them.
If you follow World of Outlaws it set 15 fast qualifier last year
and is driven by a guy named Sammy.
PostPosted: Tue Mar 12, 2013 1:26 am
I heard LT-1Q was tearing up the Outback in Australia?
The Scottmeister
"With great power comes horrible fuel economy"
www.advancedautomotion.com
PostPosted: Tue Mar 12, 2013 7:40 am
MOAR PICTARS!!!
BEAST http://www.theprojectpad.com/viewtopic.php?f=11&t=193#p37887
DD '86 4kq BLAZE, swapping aba/16vT and O1E http://www.theprojectpad.com/viewtopic.php?f=11&t=201#p38264
'86 4kq - 3b'd = gone http://www.motorgeek.com/viewtopic.php?t=25432
https://www.facebook.com/profile.php?id=100007101555124
PostPosted: Mon Feb 03, 2014 9:05 pm
let me guess, nothing ever happened?
PostPosted: Tue Feb 04, 2014 5:26 pm
LoL almost a year gone by and nothing...ya I think we done skeert him off. Did anyone ever get a 'phone presentation' for this alien technology?
Time to make the effin' donuts sucka! Image
95 90q
01 S4 Avant TIPTRON BISHES!
03 Aprilia Caponord
  |  It is currently Mon Apr 24, 2017 6:16 am
