Post new topic Reply to topic  [ 250 posts ] Go to page 1, 2, 3, 4, 5 ... 10  Next
84 Audi urq AAN powered he's alive
 Post subject: 84 Audi urq AAN powered he's alive
PostPosted: Wed Oct 11, 2006 5:18 pm
Okay guys,
it's time I started my own project page for my urq.
Basically I bought a 84 Tornado urq several years ago with the intention to do a MC engine swap and freshen the car up a bit. Having lived in Scotland for the first 22 years of my life I'm no stranger to the Audi marque.
Then luckily for me I met Martin Pajak and Mike Hopton, both great guys who between them own 7 urq's!!! and they only live half an hour away from my house. After talking to Martin, I decided that 20vt was the only way to go.
After pulling the engine and interior I discovered that this poor urq had had a hard life. After careful consideration I decided that a complete overhaul was required to bring the car up to the condition that I wanted.
The plan for the engine.
Obtain 20v AAN engine.
Scat connecting rods.
Possibly lower compression to @8.5.1.
Multi layer steel head gasket.
ARP fasteners.
Make custom header.
Modify AAN intake to clear radiator.
Lightweight flywheel from 1990 Audi 200 CNC machined to make lighter.
Heavy duty clutch.
Run Motronic computer and stock K24 turbo before switching to O34 computer.
Custom oil and water lines for turbo.
Install Garrett GT 30 turbo or similar Garrett product.
Big front mount intercooler.
Install Toyota MR2 electric steering pump.
Possibly move engine back 2 inches if drive shafts will let me.
Install bigger oil cooler.
Transmission Plan:
Torsen transmission from 1990 Audi 200 quattro with standard 3:89 gears
Electronic rear diff controller from 93 S4
Misc Plan:
Rear Differential fully rebuilt and powder coated.
Front, Rear sub frames sandblasted and powder coated.
Front and rear control arms sandblasted and powder coated with new bushings installed.
Front and rear struts sandblasted and powder coated with new wheel bearings.
Front and rear drive shafts sandblasted , powder coated and rebuilt.
Aluminium sub frame bushings front and rear.
4000q front sway bar installed on the rear.
Get stock 8 inch royals refurbished.
225/50/15 tyres.
Brake Plan:
Install sport quattro front brake calipers AP Lockheed 4 piston mono-block (thanks Mike.)
Front rotors from Audi A6 2.7tt machined down to 300mm.
Install 93 S4 rear calipers and vented rotors
Stainless steel braided lines.
All new hard brake lines
Suspension Plan:
H&R lowering springs .
Bilstein HD shock absorbers.
The Unibody Plan:
Fix all the problem rust areas.
Install front, rear body strengthening channels as per Audi A2 rally car.
Install rear control arm supports as per Audi A2 rally car.
Make front end removable for ease of engine swap.
Install custom front lower control arm supports as per Audi A2 rally car.
Install custom front engine snub nose mount as per Audi A2 rally car.
Make carbon fibre front sport quattro style grill.
Modify bonnet with sport quattro style vent.
That’s all I can think of now, I’m sure there will be more to come.
Seeing as I have completed @ 80% of the list already I’ll be updating with pictures shortly.
Cheers,
Craig Cook. 8)
PostPosted: Wed Oct 11, 2006 5:23 pm
Sounds like a Great Big project Craig...
wish I had a couple guys like Martin and Mike a few minuted down the motorway!
1987 elQUANTUMino Project
1990 Pearl Coupe Quattro - Cone Killer SOLD
1994 Silver 90Q "Freeda" Snow Beater now RXer
1992 Blue Eurovan "5+5" "DasFeld"
1992 Forest Green Cabriolet Project Gone
1988 Red MR2 Supercharged
Future? 1986 AE86 Coupe 1985 GTI
Wife's Ride 2002 Saab 9-5 "Baab the Saab"
Parting 1993 90q 1996 A6Q Avant Gone
PostPosted: Wed Oct 11, 2006 5:57 pm
some pics of the trainwreck when I got her.
PostPosted: Wed Oct 11, 2006 6:12 pm
more pics.
strut brace installed. I did change it later however.
AC evaporater hole welded up
AC evaporator exit welded up
European blower motor cover installed.
PostPosted: Wed Oct 11, 2006 6:39 pm
more pics of my urq.
I made a car rotisserie from 2 heavy duty engine stands.
Here I'm making the A2 rally car strengthening channels for the floor
The seam welding is well on it's way.
Channels installed.
PostPosted: Wed Oct 11, 2006 7:01 pm
Nice. Can't wait to meet you and Martin on my next trip to Mississauga.
"Like" Quantum Mechanics Performance and Fabrication on Facebook for Audi Fox Quattro updates and other project developments.
https://www.facebook.com/VWQuantumMechanics
PostPosted: Wed Oct 11, 2006 10:32 pm
wow, i wish i could tear a car apart to that degree, looks like fun! ill have to look up some of those A2 support thingys.
Patrick, Southern Oregon University: Geology/Anthropology
-86 4kq- gettin there..... oh its getting there. one way or another
PostPosted: Thu Oct 12, 2006 3:35 am
Craig,
Great pics and post.
Love the "subframe connector" upgrade.... look at Gringo's URQ sedan project thread for what I think is a great idea for the front rad support area... you had that on your list...
looks like he has a bar that connect the front "frame" horns with tubing, bent low enough to lift motor and trans over...
I have a "cut front" 4000 with 450+hp 20v and front feels really floppy compared to a CQ...
want to do both to my car... right after it moves under it's own power again...
PostPosted: Thu Oct 12, 2006 5:12 am
Sweet project! Can't wait to see where you take it!
-Charlie XBL GamerTag: Elggur dMzil
'12 Focus *Wife's car*
'83 UrQ - Project
PostPosted: Thu Oct 12, 2006 5:20 am
here is my first mock up of the front brace.
PostPosted: Thu Oct 12, 2006 5:29 am
nice... both removable?
look like the bar's from D3R3K's grandmas bathtub! :P
PostPosted: Thu Oct 12, 2006 5:37 am
yes both removable.
don't tell Derrick about granny :D
PostPosted: Thu Oct 12, 2006 7:06 am
nice work, looking forward to watching this
Founder ADD Motorsports, Circa.....did you see that fish!
Thanks to:
www.izzyscustomcages.com
www.034motorsport.com
www.vortekz.com
PostPosted: Thu Oct 12, 2006 8:11 am
Craig:
Why is it that your 'trainwreck' urq looks just as good (if not better!) than my daily driver urq?
Arrrrragh! :frustrated:
-=Frank=-
Image <- "The Twins" Image
PostPosted: Thu Oct 12, 2006 8:13 am
I'm compensating for something with this
hey! shut it up you! :P that bar has been a great trooper. still intact with all the abuse i've put it through with chassis flexing and stiff suspension..... the next one will be way better ;)
Ð3Я3К....
86' 4kq~OG Alpine Weiss *Comatose*
83' URQ~project secrecy
85' 4kq 20vt~The Sniper 8) *alive*
01' A6 4.2~6spd conversion, Gallardo 19's*sold*
83' 4ks 2dr*DD protege'*
85' diamond 4kq*DD*
PostPosted: Thu Oct 12, 2006 9:20 am
Something about your project seems oddly familiar... Have fun!
PostPosted: Thu Oct 12, 2006 9:23 am
Katman wrote:
Craig:
Frank,
trust me there's hope for you yet. How did you make out with that floor?
Seeing as I haven't been to the last few meetings I haven't spoken to you.
Cheers,
Craig.
PostPosted: Thu Oct 12, 2006 9:26 am
Yes,
I know your car well. I love that A2 body kit. If the funds were available
I'd have one of those kits.
I live 5 minutes away from the Sprongl's, I believe they did most of the work on that car.
How is the car coming along?
Cheers,
Craig.
PostPosted: Thu Oct 12, 2006 4:13 pm
Here are some more pics of the car
The floor is finally finished, seam sealed and undercoated ready for paint.
I added some more braces for strength. I want a strong unibody without the added headache of adding a roll cage.
Rear holes for bumper welded up so I can add my euro bumper.
I also put some vents in my bonnet. Maybe a carbon one will find it's way there one day. :D
Cheers,
Craig Cook.
PostPosted: Thu Oct 12, 2006 4:39 pm
Looks very nice!
PostPosted: Thu Oct 12, 2006 5:08 pm
Jonathan wrote:
Looks very nice!
Yes indeed.
Steve
Stephen Ankney
2000 Audi TTq
1986 Audi 5ktq w/MSEFI, TO4E/K26, parts
1986 Audi 5ktq w/MSEFI, Stebro, Torsen, etc.
1999 A6q Stock.
http://www.motorgeek.com/phpBB2/viewtopic.php?t=7813
PostPosted: Thu Oct 12, 2006 5:22 pm
:stupid:
1991 Coupe Q Silver/Platinum
http://www.naaclub.org
PostPosted: Fri Oct 13, 2006 2:21 am
can you show a pic of the underside of the vent please?
Niall
Too many cars..
PostPosted: Fri Oct 13, 2006 3:38 am
As soon as I can get access to the body shop I'll take some.
It could be a while though.
Basically I cut part of the bonnet channel out from underside, then I cut the vent hole from the top side. I then hammered and dollied the lip down, made up some vent pieces and welded them in. I then added back the backbone piece, slightly modified and put it all together .
A picture says a thousand words though. :D
cheers,
Craig.
PostPosted: Fri Oct 13, 2006 4:45 am
You are fabbin' up a storm! Nice work, what kind of cutting and welding equipment are you using?
I like the "leading arms", have seen them on front of Quattro Rally cars, too...
where is the short tube brace? Have not spent enough time under my cars lately to tell for sure... front wheelhouse?...
Users browsing this forum: Yahoo [Bot] and 1 guest
  |  It is currently Tue Jun 27, 2017 8:29 pm
