| Author |
Message |
quattrofrog
Post subject: A4 Ti20 Posted: Sat Oct 28, 2006 11:10 pm |
| I color outside of the lines |
Joined: Sun Nov 21, 2004 5:24 pm Posts: 2616 Location: New Jersey
Continuing from my previous projects thread... this thread is to document the build of a AEB/ABA 2008cc 20v turbo engine for my 1996 B5 A4 quattro. I need to start fresh and a new thread is as close as I'm going to get to just that. My Sedan is now converted to 034efi IIc, with complete instrument cluster functionality.
I'm building the car primarily for HPDE use. Eventually I'll add a cage, harnesses and race seats. I don't really need this kind of power IMO, but I can always run less boost for a less aggressive car for when I need to focus on my driving rather than being playful and flexing the muscle. The saving grace of this car is the published factory weight of ~3226lbs, I've removed some of that weight and shifted some of it rearwards. Post engine swap I expect the car to have an improved weight distribution which should improve the neutrality of the car's handling. I'm hoping to see a Phase 1 track weight of 3100lbs or less which provides a minimum power to weight ratio of 8.86lb / hp with a ~350hp w/ 93oct ... or as low as 7.21lb/hp at ~430hp w/104oct. We will see what the actual numbers are once the swap is complete, but it is sufficient to say that the car will be quite rapid. The Porsche 997 turbo has a power to weight ratio of 7.88lb/hp. My RPM limited top speed at 7200rpm is 174mph for 5th gear, given the ~.31cd and ~2.1m^2 frontal surface area I likely have to work with... I should have just enough wheel HP to reach that sort of speed.
Phase 1 (in progress)
AEB Engine Block bored to 83mm
ABA Crankshaft (forged 92.8mm)
AEB Cylinder Head fresh from Audi of America
Coil cover 034efi
ALT Head Gasket
AEB Main Bearing bolts
AEB Rear Main Seal
AEB Front crank flange/seal
AEB Sump gasket
AEB timing belt kit
AEB Crank Gear
AEB Oil sump
AEB Oil pump
AEB Oil filter bracket
AEB Coolant flange
AEB Radiator
AEB Upper rad hose
AEB Lower rad hose
AEB Water pump
AEB Coolant Jacket
AEB Intake Manifold
AEB Intake Mani Gasket
AEB Throttle body Gasket
AEB Fuel Rail
AEB Injector Seats
AEB Throttle body
Flywheel: aasco 1.8T Clutch: South Bend Stage 4 OFE / Sachs Race Engineering PP
AEB Vane Pump
Turbocharger: Garret GT2871R (743347-0002)
Turbo inlet pipe: Nissan S14/ Custom
Intercooler: Precision Turbo Intercooler plumbing: Custom bypass valve: Tial BOV
AEB Accessory bracket
1.8 20v NA snub mount bracket (for vehicles without A/C)
AEB L/ Engine Bracket
AEB R/ Engine Bracket
Exhaust Manifold: PES T28
Downpipe: 3" Custom
Exhaust: 3" Custom
AEB lock carrier
Hall sender ring: 034efi Spark plugs: Bosch F6DTC
AEB Hall sender
AEB Ignition coils
AEB Alternator
AEB Starter
Phase 2 (when 350-430hp gets boring)
Main bearing studs & Engine Block Girdle
Larger turbocharger & Exhaust Manifold
Lighter valvetrain components
cams (1.8 20v NA intake cam perhaps)
raised rev limiter
larger intercooler
larger throttle body
Block Specs:
Bore 83.0
Stroke 92.8
Rod Length 144.0
Wrist Pin Dia 20.0
Rod/Stroke Ratio 1.55
Displacement 2008.0
____________________________________________________________________
Pictures will be found here http://qfrog.smugmug.com/gallery/2062507
_________________ -Phil
96 A4 Ti20
Waiting for its next HPDE
98 A4 2.8qm Avant
Undergoing overhaul
Last edited by quattrofrog on Sun Jul 19, 2009 10:13 pm, edited 30 times in total.
| Top |
quattrofrog
Post subject: Posted: Sun Oct 29, 2006 2:34 pm |
20v selected, 16v no longer being considered
Wiz
I did consider the ABA 20v.
The AEB head is more expensive and is part of an engine which has sludge and timing belt issues due to maintenance manuals containing misleading information.
The 16v Turbo Manifold 034 makes should work http://www.034motorsport.com/images/thu ... 100_94.jpg should work nicely as it keeps the turbocharger centered which is a mild rearward shift from the stock manifold. If anything this provides me with more room for an air filter. The ATP manifold shifts the turbo even farther back than the 034 piece. In stock form the 1.8T manifold places the turbocharger forward to allow for a catalyst between the turbo and downpipe. Upon inspection of my father's 1.8T A4 There looks to be plenty of room to shift the turbo rearwards using a testpipe. Should the stock 034 manifold not work I could always beg to have a 034 manifold assembled with a forward shifted T3/T4 flange.
96 A4 Ti20
98 A4 2.8qm Avant
Undergoing overhaul
| Top |
quattrofrog
Post subject: Posted: Sun Oct 29, 2006 4:02 pm |
A 16v head costs less than AEB head does and with what looks like only a slight reduction in flow. I have access to an AEB core but that route would still cost me $1500 for a completely stock reman head from Audi. A 16v head of good origin and in good condition rebuilt by my machine shop with new cams, lifters and valve seals is likely ~$800. I don't think i can come close to that with an AEB head. I really don't want to buy an AEB head on ebay, I have a phobia of 1.8T engines thanks to my experience at work. I've seen 20 bent valves, failed cam tensioners, sludged heads, scored bearing caps... They're becoming cheaper because the vehicles with them are leaving the roads due to accidents and failed engines which result in repair expenses exceeding the value of the car to the owner. I think I've seen just about all the possible scenarios at work. The 1.8T is a great little engine but entirely too many examples are not maintained properly and that is going to be the demise of many a 1.8T.
96 A4 Ti20
98 A4 2.8qm Avant
Undergoing overhaul
| Top |
Wizard-of-OD
Post subject: Posted: Sun Oct 29, 2006 11:12 pm |
| I boggle like it's my bidniss |
Joined: Sun Nov 30, 2003 8:50 am Posts: 7536 Location: I see the world different thanks to my steering wheel
AEB Core + Stock cams - $150US
Aftermarket springs & retainers from 034 - 495
Aftermarket valves - 400
Put it all together and you have a nice race prepped head for under 1500.working @ the dealership doesnt mean you know where to get the best bang for buck parts
To get Stock 1.8T valves now are a joke because all those with stock are going aftermarket.
_________________ Issam N. Abed
034Motorsport of Canada
INAEngineering.Com
| Top |
quattrofrog
Post subject: Posted: Sat Nov 04, 2006 10:19 pm |
In light of the suggestion made by wizza I've been busy pricing things out for the various swap and there are several routes I can follow to a potent 4cyl turbo. There are aspects I like about all three of these potential courses of action. I'm weighing advantages / disadvantages with cost, risk and effort.
Here are my thoughts so far...
ABA 16v build
Advantages
· Piece assembly/ acquisition method
· No expensive individual components
· Proven with references to completed transverse
· 2.0L displacement
· Forged crankshaft
· Safe potential 400+ HP
Disadvantages
· Unknown fitment of exhaust manifold from transverse application
· Custom intake manifold required
· Unknown cooling, vacuum, breather system arrangement/integration
· Single custom bracket required
· Unknown exhaust downpipe fitment (angles/chassis)
· Unknown block/head height combo fitment under hood
ABA 20v build
Advantages
· Proven with reference to completed engine in B5
· 2.0L displacement
· Forged crankshaft
· High flow cylinder head
· New bearings, seals, rings in engine
· Forged rods & pistons
· Cooling, vacuum, crankcase breather, systems.
Disadvantages
· Rebuilt head from regional vendor without prior history
AEB swap
Advantages
· Complete engine assembly available
· Quick
· Direct swap/ bolt in
Disadvantages
· Expensive initial purchase
· 1.8L displacement
· Cast crankshaft
· Possible sludged engine history
· Possible broken T-belt history
· Safe potential is limited ~350hp
· Stock rods/pistons
I have more research to do before I can make a final decision and subsequently make a purchase.
96 A4 Ti20
98 A4 2.8qm Avant
Undergoing overhaul
| Top |
GTIVR62801
Post subject: Posted: Sun Nov 05, 2006 12:52 pm |
| Track Junkie |
Joined: Sat Oct 23, 2004 6:46 pm Posts: 1325 Location: West Orange, NJ
I'm going to have to vote ABA 20V on this one, its the easiest choice with best durability IMO.
_________________ Carson
'01 VW GTI VR6 (SOLD!)
'01 Audi S4 Tip (soon to be ASP Stage 2+) - Manual Conversion in the works
'06 Audi A4 2.0TQ Tiptronic (my wife's)
Audi Parts Consultant
Certified Audi Tech (ret.)
ACNA/NJ VP
Next Track Event: ???
| Top |
SilverCQ
Post subject: Posted: Sun Nov 05, 2006 1:22 pm |
| mach 2 with my hair on fire |
Joined: Wed Oct 27, 2004 10:42 am Posts: 1311 Location: Central NY
i say go aba/20v, if i get the itch farther down the road i might as im basically running all 1.8T electronics already......
i only did the 16v b/c i already had it, and i thought it'd be neat
_________________ RJ
| Top |
quattrofrog
Post subject: Posted: Sun Nov 05, 2006 2:35 pm |
I appreciate the input guys.
96 A4 Ti20
98 A4 2.8qm Avant
Undergoing overhaul
| Top |
Wizard-of-OD
Post subject: Posted: Sun Nov 05, 2006 2:55 pm |
quattrofrog wrote: Disadvantages · Rebuilt head from regional vendor without prior history · Single custom bracket required
Your going to have to rebuild the 16V head as well.You can rebuild the head yourself.Just remove the valves,change the valve seals and guides (if you know how) and clean up everything from the 100,000+ miles of carbon build up.
Check out this cheap PES manifold.
INAEngineering.Com
| Top |
quattrofrog
Post subject: Posted: Mon Nov 06, 2006 10:27 pm |
I may be able to pickup an AMB code head with <40K through work for a modest sum. I'll know tomorrow if the AMB head is going to happen. Failing that a friend has an AEB head in need of new valves and a rebuild... another friend has an AEB head with a cracked casting and a good set of valves. A+B= AEB?
The PES manifold is a nice piece and if I go with a GT28R or GT28RS I'll certainly give it consideration. However I have temptations of Holset HX35W or some other largantuan turboladder with a T3 flange. So i may have to go with a ATP manifold.
96 A4 Ti20
98 A4 2.8qm Avant
Undergoing overhaul
| Top |
quattrofrog
Post subject: Posted: Tue Nov 07, 2006 5:40 pm |
Cyl head No. 1 had scored cam bearing caps... that wont do. There is another head at work which I'll examine tomorrow. Cyl head 2 is likely in better shape, failing that I still have the AEB heads which will cost more than the AMB head.
That PES manifold and a GT2871R with a T25 hot side might be a suitable combination for my target HP of 400 crank. I don't think I'll be happy with much under 400hp given the expense of such an engine.
96 A4 Ti20
98 A4 2.8qm Avant
Undergoing overhaul
| Top |
GTIVR62801
Post subject: Posted: Tue Nov 07, 2006 5:44 pm |
| Track Junkie |
That Holset is calling your name Phil....but if you forgo that for a ball bearing Garrett I won't get mad at you.
ACNA/NJ VP
| Top |
SilverCQ
Post subject: Posted: Tue Nov 07, 2006 8:10 pm |
whats the big thing with holset turbo's anyways, i never hear anything about them except on here.....aren't they diesel truck turbos?
| Top |
GTIVR62801
Post subject: Posted: Wed Nov 08, 2006 11:03 pm |
| Track Junkie |
SilverCQ wrote: whats the big thing with holset turbo's anyways, i never hear anything about them except on here.....aren't they diesel truck turbos?
^Tom Ritt's 034'ed 1.8T with Holset
ACNA/NJ VP
| Top |
SeStone
Post subject: Posted: Thu Nov 09, 2006 12:34 am |
| I post, therefore I am |
Joined: Sat Sep 25, 2004 8:16 pm Posts: 5032 Location: Minneapolis, MN - Uptown
They're efficient as hell and spool quick. The bad part is the turbine isn't always made of the best stuff, as diesels run lower EGTs.
Sam
_________________ Sam 'Turbo' Stone
1990 80Q 20vt Running 034 IIc
Imola Motorsports Inc.
| Top |
SilverCQ
Post subject: Posted: Thu Nov 09, 2006 6:59 pm |
well now im all curious, what kind of holset did tom ritt use? i see a bunch of hx35's on ebay, how would they fair on a 4 cylinder?
also, they're flange looks like a dual scroll t3? would it bolt to a standard t3 flange, or does it require its own flange....
tia
| Top |
SilverCQ
Post subject: Posted: Sat Nov 11, 2006 4:43 pm |
SilverCQ wrote: well now im all curious, what kind of holset did tom ritt use? i see a bunch of hx35's on ebay, how would they fair on a 4 cylinder?
tia
I've been researching a lot about these, and the info's been great, im very impressed, but im still wondering about the flange....it looks very similar to the t3......anyone?
| Top |
derracuda
Post subject: Posted: Sat Nov 11, 2006 5:11 pm |
| I'm compensating for something with this |
Joined: Sat Oct 04, 2003 10:28 am Posts: 16469 Location: West Coast- silverton,OR & Sacramento,CA
they have a different flange than a T3
_________________ Ð3Я3К.... 86' 4kq~OG Alpine Weiss *Comatose* 83' URQ~project secrecy 85' 4kq 20vt~The Sniper 8) *alive* 01' A6 4.2~6spd conversion, Gallardo 19's*sold* 83' 4ks 2dr*DD protege'* 85' diamond 4kq*DD*
| Top |
SilverCQ
Post subject: Posted: Sat Nov 11, 2006 5:13 pm |
know of anyone who makes/sells the flanges?
| Top |
SilverCQ
Post subject: Posted: Sat Nov 11, 2006 5:30 pm |
lol, you dont have any idea what turbo tom ritt was running do you? hx35? i've been reading all sorts of stuff on one of the dsm turbo's i guess they really like the holset's, however, a lot of the information im looking for i cant find....still searchin though
| Top |
quattrofrog
Post subject: Posted: Sat Nov 11, 2006 7:00 pm |
http://dodgeram.org/tech/dsl/FAQ/turbo_faq.htm
In recent discussion with Tom I think he said his is a HX35. IIRc he said no more than 12cm hot side turbine. There is a HY35 which I believe spools quicker but it has a peculiar forward facing outlet which I dont think is compatible with my engine bay.
They spool quickly on small engines because a 6L turbo diesel straight six doesnt rev particularly high. Lets say 4.5k limit with a guestimate of spool by 1.2k... 6/2= 3..... 3*1.2k = 3600rpm spool with a two litre engine.
96 A4 Ti20
98 A4 2.8qm Avant
Undergoing overhaul
| Top |
