hi, I've been on here for a while and it's time to finally start my project thread. I bought my 1986 4000 cs quattro at the beginning of last summer. I bought the car from guy in mass. who brought it up from south carolina who bought it from the orig owner in texas. The car is extremely clean, inside and out, top and underside. the car had 2B coilovers on it when i got it, along with the Recaro's, upgraded pads, lines and rotors.
Quick pic from Carlisle 2010
loving it
SUPPORT MY SWAPPAGE!!!! buy some parts
phpBB2/viewtopic.php?t=33758
I've since gone through and replaced all the inner and outer tie rods and ends, ball joints, strut inserts, strut mounts, engine mounts, trans and dif mounts, and a fresh set of toyo t1r's round out the handling nicely.
I finally got my hands on a '91 200 20v and plan on removing the motor and trans shortly for transplant into the 4kq, the car will be sold as is or parted in teh upcoming weeks. i plan to put the 3b in the 4k cheaply and to build my AAF eurovan motor on the side while i enjoy my new found power over the stock JT
Summary of Modifications to be done
Engine/trans
1991 200 20vT swap
Rebuilt 3b head
'91 200 20v 016 torsen trans w/ fresh seals
speedo sensor swap
Intended Acceleration Chipped ecu
isuzu fmic with modded ins/outs
dahlback racing bpv
ARP Headstuds
034 metal HG
timing belt / roller / water pump / timing cog
AAN windage tray
7A oil pan
new expansion tank
new washer fluid tank
gaskets / seals galore
sandblasting / powder coating
rear mount battery box and breaker
034 fuel pressure gauge w/ aan adapter
Innovate Lc1 WB O2 w/ x16 gauge
walbro 255 lph pump
fresh primary + secondary fuel filters and lines/clamps
PC'd fuel pump/filters tray
Nub Works custom catch can / breather setup w/ 3b VC
AEM DryFlow air filter
RC flow matched oem 3b injectors
034 silicone couplers all the way around
Chassis
034 Alum Subframe bushings F & R
034 Delrin C arm bushings F & R
034 track density strut bushings F & R
Bilstein sport inserts
remove both subframes, engine, trans, diff, catback, etc for wire brushing and reapplication of rubberized coating on underbody of car
Exterior
repaint oem SQ grill and trim
paint hood
Interior
fwd 4k aux gauges
vdo boost gauge
red led gauge back lights
new cluster lights
innovate lc1 w / xd-16 gauge
diy spheric bearing short shifter
innovate boost gauge
clean / fix / prep CE red leather door panels
mk III radio install
3b wiring :tard:
any ways on to the pics
rebuild, refresh, parts cleaning and fresh hardware a plenty!!!
loving it
Engine/trans
1991 200 20vT swap
Rebuilt 3b head
speedo sensor swap
dahlback racing bpv
ARP Headstuds
034 metal HG
AAN windage tray
7A oil pan
new expansion tank
walbro 255 lph pump
Chassis
Exterior
paint hood
Interior
fwd 4k aux gauges
vdo boost gauge
new cluster lights
3b wiring :tard:
