Yes sorry I am asking about both the IAC Stepper motor AND the TPS...
3 of the 4 white/____ wires were found in a twisted/shielded (white wrapper) cable into the harness... there is another Twisted/Shielded wire on the flying lead harness I got with one wire + shield that I assumed is the VR cable...
We stripped it way back and found only 3 wires inside????
Here is the TPS I have, pretty sure it's from AAN. Pinout does not refer clearly to which of these marked 1-2-3-4-5-6 on my TPS pictured, or the connector I got, which fits and has the same 1-2-3-4-5-6 markings... which should I connect to??? I assume from the "034 Connector B" pinout that I will use 3 of them and not use 3 of them, don't know how to guess which ones... :?
6 TPS GND - Black TPS Groung, outside pin = pin # ________???
13 TPS Purple - TPS Signal, usually TPS Center Pin = pin # ________???
20 TPS VCC Yellow-Red TPS Positive to outside pin. = pin # ________???
Also... while I am asking questions, which connector on the IAT and CLT sensors are + or - ??? sensors/connectors not marked that way, MAY have 1-2 on them, maybe it does not matter which way the current flows????.
And should I use the CLT sensor back of the block or in the water mani??? Does it matter?
