016 Speedo Gears
741 Views 3 Replies 2 Participants Last post by  Twintowers
OE part numbers 016409187 (gear) and 088409197 (pinion) inside the stock 4k transmission.
Part numbers come up for genuine VW/Audi and genuine Porsche on ECS. Porsche variants are about 1/3 the cost. Are these parts different?
1 - 4 of 4 Posts
944 speedo gears? probably some others, why are you looking for them?
Speedometer doesn't operate in the 4k. Dash and cable are okay, narrowed it down to the sending gears in the transmission.
Sending gears are hammered? That strange you should check the front differential carrier bearing make sure there is no bearing issue, normally that part should not be worn... what year is the quattro :wtf:
1 - 4 of 4 Posts
