usually it's inscribed into the bottom of the wire connector socket
usually it's inscribed into the bottom of the wire connector socketHow can you tell the difference between a 1A, 1B an 1C? is there any difference on the circuit board?
Hmmm... didn't know it was there.....It's hard to read, it has a number that's scratched out (1810?) then a "2" then what looks like "C4" then "C" and finally "VR"Rocco16V said:usually it's inscribed into the bottom of the wire connector socketHow can you tell the difference between a 1A, 1B an 1C? is there any difference on the circuit board?
So I can't use the hall sender as a tach source? or it just requires a change in the jumpers?Rocco16V said:1C set to VR
No, only as a cam sync, a multi-tooth indexed wheel on the crank must be used for the C level firmwares.DDG said:So I can't use the hall sender as a tach source? or it just requires a change in the jumpers?Rocco16V said:1C set to VR
