1 - 3 of 3 Posts
The 034 ABZ flexplate insert came with a pilot bearing an one (1) snap ring. There are, however, two grooves machined into the center bore of the flywheel. Which groove gets the snap ring? I would suspect the side facing the crank, but I've been wrong before... Or was I supposed to get 2 snap rings with the bearing?
Thanks, I went around the corner to Ace and got a matching 2nd one.
Bearing went in ever so cockeyed :( shaved a bit of the aluminumfrom the bore, too. Seems to be seated ok now, hopefully it shouldn't be too much of an issue.
1 - 3 of 3 Posts
