Standard relay's don't toggle. Latching relays would "toggle" or be "maintained" until the coil/contacts are reset.
Wait, what? To switch maps do you put the map sel input to ground momentarily? i thought it would be on the second map only when the input was connected to ground.WAUG0806 said:I am re-installing my llc and want to hook up momentary ground MAP SEL map switch function...
That's what I'm asking. IS the map select a momentary trigger?cuatrokoop said:If it is momentary, ...
then later in the manual034 IIc tuning manual said:Map# - This shows the status of the map select input, either map #1 or #2. To
change maps, ground the appropriate ECU pinout (see the wiring diagram
provided).
this would make me believe it is not a momentary trigger but uses the second map whenever the input is grounded.034 IIc tuning manual said:MapSel - Shows the state of the Map Select pin LOW/HIGH
Rocco16V said:You could use a DPST (Double Pole Single Throw) switch and have a light lit when using map B and unlit when using map A
Absolutely not, it is a switched input and must be pulled to ground, or left open to select between the two maps.Rocco16V said:?? is it a momentary input?
