1 - 20 of 24 Posts
important point It is all or nothing, I will not part out anything
I totaled my racecar last year and every penny and second of time is being spent on building a new car. I have a couple of rental houses, my second daughter was just born and more car/trailer projects then I can handle. I have no time. This car needs a lot of little things to be put together and fixed but…. Everything is on the car and kinda installed.
Delivery is possible to Midwest/south/northeast. Details will need to be ironed out.
1986 QSW red
Front frame rails modified for ABH motor mounts
Grey hood with hood pins
No driver's window regulator
No front seats (I have two stock bases to mount aftermarket seats)
Minor minor rust, for New England I would say it is beautiful
Radiator support cut out and custom radiator mount installed, bolt in and out
No fuel system (tank and pump included) no lines (they were leaking)
One brake line in the back is weeping
No rear suspension (we can talk about some rabbit bilsteins) rabbit rear coil overs are bolt in ( I may have blown stock ones to roll on)
Coil overs in the front with new bearings and new bilstien HD's . The springs are 10 inch, probably need to be swapped out for 8 inch
Front sway bar removed, new front ball joints, new strut bearings
034 aluminum sub frame bushings
MR2 electric power steering pump
Functional 3 inch single exhaust but I always wanted to redo it.
Has some interesting rims on it and some nice looking tires
034 IIC with harness for ABZ with tach adapter and fuse panel
ABZ with new timing belt and resealed except for head gaskets
034 ABZ motor mounts modified to fit car
ABH headers swapped over, all studs moved to fit.
034 oil filter relocation kit
Sub frame notched
Oil pan fins removed
Oil cooler and Nascar remote mount oil filter
Griffin radiator with electric fan
034 fuel rail AN adapters
S8 authentic flywheel with 60-2 ring
SPEC RS2 clutch stage 2 or 3 plus can't remember
O1E 5 speed trans
Hank mounts
Tim (2000APB) modified shift linkage
Two front drivers side axles with custom spacer
Correct 016 axle cups
Other parts
Firewall brace
3 inch Cat
I have an ABZ stock harness
Probably others
60-2 crank trigger wheels (2 maybe)
Thanks David
Discussion Starter · #2 ·
how about 2200 if I keep the IIC?
bump if anyone cares
still here
still here
bump it up for daycare bills
this has nothing to do with buying the car, unless you have 200/v8 parts for sale... but I noticed this car has MR2 electric power steering. I was trying to find if you had a project thread on it. Do you have any info on this?
many people have done it, just switch the pumps and wire in the pump using a relay to power it. I did a search for MR2 and found a couple of different project threads
Discussion Starter · #12 ·
does anyone want everything but the chassis? we can talk about that?
Discussion Starter · #13 ·
bump from the dead
:stupid: :D
Discussion Starter · #16 ·
^ coming from the guy who just saw my car graveyard (my driveway) of lost projects.
Discussion Starter · #17 ·
I am open to offers for everything.
Discussion Starter · #18 ·
semi annual bump, no time for this or anything for that matter.
Discussion Starter · #20 ·
no I do not. the car is at my rental property in the garage. I haven't touched it since my second daughter was born.
1 - 20 of 24 Posts
