AAN swap on CQ 01a transmission
644 Views 1 Reply 2 Participants Last post by  00basil00
I am doing a engine swap (I already searched but need to make sure) on my CQ, the engine is an 5 cyl turbo AAN but the issue is which clutch/flywheel combination use.
I would like to keep the dual mass and its clutch but my understanding is that wont fit on the 01a transmission.
What are the options?
7a flywheel; AAN clutch kit?
7A flywheel; 7A stage 3 disc and 7A pressure plate?
AAN flywheel and AAN clutch kit with some sore of spacer?
Which throw out bearing should I use and which pilot bearing (both for the cq 7A?)
ECU has MRC chip on it; 034 water injection; adjustable FPR and 7A cams. Dreaming with 270-280 hps!!!
Thanks in advance for any input!
1 - 2 of 2 Posts
Throw out bearings are all the same, go with the 7a fw and stage 3 disc
1 - 2 of 2 Posts
