1 - 5 of 5 Posts
Does anyone know what is the part numbers for the following?
1. The pin for the EFI connectors (red ones)
2. The pin for a regular Audi harness. The ones that are square and has that metal clip on top.
The reason for these parts:
1. I broke one pin when I assembled the connector.
2. I'm using a TB from a V6, and I got a brand bew housing for it. I just need the pins.
Project Update.
I replaced the o-rings and tested it with success using 60 psi of air.
The only major steps needed are the engine part of the harness and the intake. Hopefully I'll be cranking it on Sunday.
Later, and thanks for the constant help.
Carlos
Looks like this is the connector for the ECU:
Link to PDF
Digikey Part number: 770680-1-ND
Plus Javad can get them for you
Thanks.
I have a distributor in town. Let's see if I talk them to sell, or giver me, some "samples". But in order to work I must have the part #'s.
I'll check Digikey out.
Thanks again,
Carlos
Carlos, if you need a few pins I'll be happy to send a few out to you no charge.
Thanks!
I have some connectors that I'm going to steal the 3 connectors for the TPS.
Let me try it, if I'm not successful I'll take your offer.
Later,
Carlos.
1 - 5 of 5 Posts
