bleeding wont help with those symptoms. Most likely your clutch master is leaking internally, and possibly leaking into the cabin. I usually replace both master cyl and slave when this happens, had it happen on a few cars, always random times and might not happen for weeks.. You can pull the carpet back under the drivers side and check for fluid inside to confirm its the master.
