1 - 9 of 9 Posts
Please let me know - I have a very specific request!
And FYI, B3 coupe will not work.
I may have sourced one, but in case that doesn't work out, this is what I need:
Complete, uncut harness that goes from the fuse panel and chassis connectors through the dash (connects to instrument cluster, column switches, ignition) over to the center stack (connects to the hvac air box, center stack switches, radio, lighter, ashtray light, airbag module if equipped, etc.).
Three important things:
1. It must be completely uncut, no missing connectors, broken wires, etc.
2. It must be from a manual climate control car (B3 or B4, either one, doesn't matter, I have airboxes from both).
3. If from a B3 car, it must be a late '89 build date ('90 m.y.) or newer with the rounded column stalk switches (unlike the squared-edge B2 and early B3 style that use a different style connector).
Airbag doesn't matter as its a separate sub-harness anyway.
Is that pain-in-the-ass particular enough? :p
yodasfro, do you have a good passenger side B3 fog light from that car?
It's all good, I've found one :)
1 - 9 of 9 Posts
