1 - 20 of 29 Posts
check it out
Discussion Starter · #2 ·
s'more
Damn fine work Derek! looks really good :woowoo:
here's a couple more.
oh, and here's my fuel rail :D
the end of it was made to accept a stock fuel pressure regulator. the coolest thing about it is, I got to watch the guy make it!! way cool!it still needs to be polished and i need to get the feed line fitted up.
Hey D
Nice work! I hope you can make the stock style fuel pres reg to work.
I welded a bracket on my rail,but the reg hit the wastegate. If your doing a
tube header it should'nt be a problem.
Aaron
yeah, i did the wrinkle paint myself. i have the touch on how to get good results with that stuff. it's super durable for spray paint too.
as for the welding, i had a welder whose shop is right by my dad's do that part of the work.
hey aaron, the pressure regulator will work, the funky thing was, that the bracket shoulda been welded on 90 degrees from where it is now...lol.. i was so enamored with the machining process that I blanked when it came time to weld it onto the rail. no biggie though. I'll just have it cut on a bandsaw and have it rewelded. smooth the welds and polish to mirror shine...easy as pie :wink:
Hey Derek,
Nice work! What kind of paint is that on the intake and valve covers? Was that a rattle can application or did you use a gun? Do you have any experience with durability of this product in an engine bay environment? Thanks for any infor and keep up the great work.
Hey Cuda,
Make sure you fire sleeve that fuel line! Or did I misunderstand you?
Aaron
Discussion Starter · #13 ·
ok ok, here's a secret i've come across on applying the wrinkle paint...I spray a flat black base coat before laying the wrinkle on, that let's you see that your area will not have any fish eyes. i've tried cleaning a metal surface with laquer thinner and applying the WP strait to a metal surface, but always end up with problem areas. the base coat enures a nice work area. it takes a few tries to get laying the WP coats on even all over the entire object being painted to make sure it all wrinkles the same. if the paint is thicker in one area the paint will wrinkle deeper and thinner the opposite.
as to durability, I've had it on my oil pan,valve cover,fan shroud and brake booster for almost a year now and there has been no flaking anywhere. the only thing that it didn't hold up to (and i can't blame it) is i had a small brake fluid leak from my prop. valve under the master cylinder and it softened some of it up on the bottom of the booster.
and aaron, yes, i fire sleeve fuel lines that travel over the hot parts of the manifold. i get this fabric stuff from an electrical supplier near my dads shop that can withstand up to like 1200 degrees and it comes in a big roll that i can buy by the foot. it's a really nice white fabric and it's only about $1.50 a foot, so if anyone wants some lemme know. i'll post a pic of some of it tonight or tommorrow.
hey,
Yea post a pic if you can. The Aeroquip stuff is EXPENSIVE.
Aaron
Discussion Starter · #16 ·
here's the sleeving. it's not too abrasion resistant, but if your reasonable with it it works fine. it flares open to almost an inch inside diameter, and can be stretched out to make it ago down to about a half inch inside.
Derek,
The intercooler looks real nice. Just out of curiousity, how did you form the endtanks. Did you use half sections of tubing or did you put the crown in flat sheet? -Thanks.
Discussion Starter · #18 ·
hee hee hee, the bottom tank is half of a 3 inch round aluminum driveshaft that i found at the recylers, and the top tank is from a square peice that i cut at an angle on our bandsaw. nothing special, just mostly junk parts of stuff, i think with the welding and all the intercooler will cost me about $110 or so. not too bad.
Discussion Starter · #19 ·
well, after a little modification to the fuel rail so the FPR would clear the wastegate shield, i got the thing slipped in tonight with nary a glitch... i mean, it fit's like it was meant to go there! check it out.
Hey cuda,
Looks great! Did you make the FPR adaptor?
Aaron
1 - 20 of 29 Posts
