Hi all. First off this is my first post here so take it easy... So the reason I am posting is because I can't get my passenger side window to roll up and down. I tried putting in a new switch and it didn't work. Any thoughts as how to fix this?
I cant figure out how to get these off... any pointers?Ronald G Wainwright+ said:Check the wiring in the rubber accordion booties.
I know it isn't a Switch because I tried using a switch that I know works. If I can't find it in the wiring and I run over it with volt meter, I will PM you about the regulator.paradox11235 said:They're just like, a press fit into the door. I still say it's a switch or burnt motor... I have a passenger regulator in my parts car if you're interested.
Thanks Appreciate the help. looked at your profile, gotta say, i'm liking that Avant you have.Kliminati said:squeeze it in the middle on either side where it meets the door, then just fold it in on it self and pull out.
