81 - 100 of 723 Posts
Discussion Starter · #82 ·
80qtdi said:
Quick question for you, how thick was the frame (on the b3 cutoff) where the frame motor mounts are? Kind of funny, I want to go to the B4 style mounts on my 80.
Not very thick, thinner than the actual metal for the mount bracket.
I can take pic for you, still have the cut off pieces.
Cheers
Discussion Starter · #84 ·
Here is how the battery looks in it's new spot.
I used the stock V6 battery try with some mods.
The S2 avant/sedan and RS2 also use the same location.
And the original S2 bracket and cover, if I can find one now.
Martin,
Is that a standard piece for the battery cover, or did you have to make/purchase it separately?
Eric
Discussion Starter · #87 ·
It is a standard piece for the S2 sedan, wish I had one, but like all other parts from that vintage they are NLA.
Don't suppose I'll see an S2 sedan being parted out soon either, there were only 306 made!
The cabin vent is just underneath the battery, I can run a standard batery vent hose (like the ur-q or 5ktq) if I find it to stink too much.
Cheers
1wheelpeel said:
Quattro Krant said:
My contribution to this build will come when I give you the relay Thursday. Also, I want to RAPE Shannon in return for the relay. I'm talking bound and gagged in a french maids outfit style of raping
I hope this ends up on youtube for all to see. :lol:
I'm not talking literally, I'm talking figuratively. I want to get that bitch into a 4 wheel drift, smoke pouring off all 4, then put her away all wet and hot and bothered. Or maybe I do want to have sexual relations with his car, it is that good looking.
Discussion Starter · #90 ·
Very productive Saturday and morning today.
Friday I received the bulkhead connector which allowed me to hook up the battery cable on the inside and reinstall the HVAC... the momentum was there so the dash went in as well.. I must say, this job is a major PITA, the typ 85 cars are soooo much simpler in that department.
On Sunday I was able to borrow John A's (1wheelpeel) Ur-q downpipe.
Never been so dissapointed in my life! Doesn't fit. Too close to the manifold and hits the subframe
Ur-q
Stock
So.. for now stock it is. BTW stock is 2.25" while the Ur-q one is more line 2.5"
More on Wednesday, my son is going to have his toncils and adnoids removed tomorrow, not looking forward to it. :(
Cheers
Discussion Starter · #91 ·
More progress:
Finished the downpipe and connected rest of the exhust, the ear section still needs to be welded, but it's tacked together for now.
If you must know the pipe came from Ur-q it's the center section with the muffler cut off before the bend, can't believe how well it fits ;)
Also interior is looking more like an interior should.
For all the b3 guys, am I missing something??
And WTF is this plug?
That's all folks.
ralleyquattro said:
I added those myself, even though my car has the 1BE sport option it did not have the gauges, just the sport suspension and rear spoiler.
Does the new engine have the sensors for those gauges? Like oil pressure and oil temp?
Also, re battery relocation, did you use any circuit breaker? And where did you buy cables?
Discussion Starter · #95 ·
Craig (Highlander) got the cables for me long time ago, no clue where.
No circuit breaker, at least for now.
Yep, the engine has sensors for the gauges, previous owner added them in, stock 1T harness did not have the connections for the gauges so I'll have to run some seperate wires for the two sensors only.
The early IDI's got the tach signal from the alternator. Later TDI's had a crank sensor. I would imagine this 2.5 has a setup just like the gasser I-5's with the sensor on the flywheel ring gear.
Brendan
Discussion Starter · #100 ·
Brendan
Yep, flywheel sensor and the TDI Motronic (same 55 pin connector) sends the signal to the tachometer.
Pretty neat, just need to find out if the signal is generic i.e. no matter if it's 4-5 or 6 cyl or will I need to get a 5 cyl tacho from a B3.
Time will tell... hoping to start this engine by the end of the week.
Cheers
