1 - 2 of 2 Posts
Will it fit? Has it been done? I gleaned from different threads that the rear toe links are longer on a B5 chassis. Any BTDTs?
TIA, Chris
yep, rear B5 tie-rod are about 1in longer than the B4. see my thread:
viewtopic.php?f=6&t=46160&start=25
As for the rear of the part, to my knoledge, knuckles, upper spring perch and upper A-arm are the same. As for the lower control arm and th subframe, one or the other have to be different that the B4 to accomodate a larger track width.
1 - 2 of 2 Posts
