1 - 9 of 9 Posts
What all do I need to run these wheels? There 18x8 et45. Car is a94 urs4 all stock suspension and brakes.
Thanks guys.
to be honest you don't "need" to run any, but.......they look like 4 spares. 20mm spacers are prob a little much esp for the rear (I say that because the front is flared). 20mm are a little big in my book for a stock car. 10's would be more suitable, don't forget to see if you need longer bolts too, you should bet about 7 or more turns, if not you'll need longer
If I'm running 235-40-18 on the front could I run 255-40-18 on the rear? Would they fit the 8 inch wheel?
On a Quattro you really need the same rolling radius otherwise you'll destroy the centre diff. Vortex will tell you 3% difference is ok - 255/40 is 2.5% bigger than 235/40. Personally, I wouldn't risk it.
Technically you could fit 255s on an 8" rim - the C5 S6 does stock - but they'll bulge a little.
thats a HEAVY WHEEL. you are looking at 50-55 pounds per wheel and tire...
I have decided to sell the wheels, ill run my b5 s4 wheels instead. I only paid 100 for the b6 wheels and sold them last night for 400.
1 - 9 of 9 Posts
