1 - 13 of 13 Posts
Best offer on all these parts. Only piece I care about will be the chipped ecu and the stock one. I won't sell them for nothing but I wont sell them for more than 500 together either!
Accordian hose
Manifold with WG (sans spring)
3b valve cover (I have two)
Stock 3b ECU
OEM passenger T44 headlight
t44 brake bomb
t44 power steering res
OEM 3b cam gear (I have two)
3b distributor ( I have two)
3b a/c bracket
3b p/s bracket
3b oil cooler housing
200 20v power steering reservoir bracket
200 20v res to pump hydraulic line
200 20v fuse panel
200 20v front OEM mud flaps
200 20v aux radiator with hoses
200 20v brake booster (hydraulic)
engine mount brackets (3b)
NEW victor reinz 3b oil pan gasket
how much for the intercooler and cross pipe, i have friend looking for one.
No prob, thanks.
A4V8swap said:
my2000apb said:
10 for the oilfilter housing?
For you, sure!
can you give it to your buddy with the smashered R? we are meeting up sunday
was the bomb functioning properly?
How much for that, the P/S pump (if you have it), reservoir, and any/all lines that are in good shape?
1 - 13 of 13 Posts
